1 of 18
Wyze Palm Lock
Wyze Palm Lock
The key is the palm of your hand.
Style
Low stock
  • Contactless entry with palm vein recognition.
  • Numbered keypad with access codes.
  • Control from anywhere with Wi-Fi.
  • Up to 6 months of battery life.
  • Manual lock and key option.
  • Peace of mind with auto lock.
Features
Specs
Wyze Palm Lock Specs
Colors & Materials
Model: WPLCK1
Finish: Matte
Color: Black
Materials - Frame: Aluminum Alloy and Steel
Materials - Panel: Tempered Glass
Dimensions
External Assembly: 6.14inx2.89inx 1.28in (156x73.5x32.5 mm)
Internal Assembly: 7.16in x 2.93in x 1.18in (182mm x 74.5mm x 30mm)
Weight: 4 lbs (64 oz)
Power
Power Source: Wyze Removable Battery Pack, backup battery
Battery Life: Up to 6 months with normal use (10-20 lock/unlock per day)
Emergency Power: USB-C port (USB-C cable not included)
Weather & Operating Temps
Weather Resistance: IP53
Operating Temperature
Exterior assembly: -4℉-122℉ (-20℃-50℃)
Interior assembly: 32℉-122℉ (0℃-50℃)
Storage Temperature: -22℉-158℉ (-30℃-70℃)
Certifications
Certifications: FCC ID+IC, TSCA+CA65, ANSI-BHMA, ROHS, REACH, SVHC, PFAS, IEC62133
Connectivity & Compatibility
Communication Method: Bluetooth® 5.0, 2.4 GHz Wi-Fi, Wi-Fi 6
Compatibility: Wyze app 3.7+, Android 10.0+ or iOS 16.0+
Door Compatibility
Compatible with most standard US doors. Replaces existing single-cylinder deadbolt.
Warranty
1-Year
In the box
1x Wyze Palm Lock
1x Exterior Assembly
1x Interior Assembly
1x Mounting Plate
1x Deadbolt
1x Strike Plate
1x Dust Box
1x Main Battery
1x Backup Battery
1x Silicone Plug
1x Drilling Template
1x Quick Start Guide
2x Mechanical Keys
4x Wood Screws
3x Interior Panel Screws
4x Mounting Screws
FAQ
Q: How is Wyze Palm Lock different than other Wyze Lock devices?
A: Wyze Palm Lock stands out in virtually every way imaginable, with a sleek new form-factor unlike any other. Wyze Palm Lock uses palm vein recognition for contact-free access, a person-detecting radar for optimized battery life, and it connects to Wi-Fi so you can control it from anywhere using the Wyze app or Alexa/Google Assistant. Yes - you can control the lock with your voice! Wyze Palm Lock also has 2 batteries to ensure your lock is always up and running.
Q: How does Wyze Palm Lock work?
A: Wyze Palm Lock uses palm vein recognition to securely and touchlessly unlock your door. Simply hold your hand up to the lock screen, and it will unlock automatically.
Q: What is Palm Vein Recognition?
A: Palm vein recognition is widely used biometric technology in the security industry. It provides secure authentication and unlocking by identifying the unique features of the user’s palm vein pattern. Palm vein scanning smart locks are highly secure, convenient, and completely contactless.
Q: How does Wyze Palm Lock learn my palm?
A: Wyze Palm Lock scans your vein pattern using infrared light and saves it locally to the device. When unlocking, the lock compares the scan result with your pre-saved vein patterns. If there’s a successful match, the lock will automatically open.
Q: What is the palm detection range?
A: Hold your hand between 3-7 inches from the lock screen, pointed directly at the screen.
Q: How secure is Wyze Palm Lock?
A: Extremely secure. Your palm vein pattern is a unique characteristic of the human body and cannot be copied or forged. Compared to traditional fingerprint recognition or a PIN code, palm vein recognition has a lower false acceptance and rejection rate. Additionally, palm vein features are not affected by growth and aging, or physical damage to the skin. No matter how your palm changes over time, your palm vein pattern remains the same. Finally, your palm scans are stored and encrypted locally on the lock - never exported or uploaded to the cloud.
Q: Is installing Wyze Palm Lock complicated?
A: No, installing your Wyze Palm Lock is the same as any other smart lock, with a standard deadbolt and latch assembly. Contactless palm recognition simply replaces your fingerprint, PIN, or key-based entry, making it convenient and user-friendly.
Q: What if my palm is injured or covered?
A: Even if your palm is slightly injured or scarred, Wyze Palm Lock can still recognize your vein pattern and unlock. If your hand is covered or you’re wearing gloves, simply remove the gloves to use the lock normally. You can also unlock using the Wyze app, PIN, and the included physical keys.
Q: What is the Wyze Palm Lock battery life?
A: The main battery within the lock has a battery life of up to 6 months, when you average 10 unlocks per day.
Q: How does Auto-Lock work?
A: Wyze Palm Lock is equipped with a new generation gyroscope, which detects the position of the door and automatically locks the door when it’s closed. The gyroscope ensures that the deadbolt is only extended when the door is completely closed, avoiding door jams and false locks.
Q: How many ways can I unlock Wyze Palm Lock?
A: With Wyze Palm Lock, you can unlock the door using 5 different methods: Palm scan, with a PIN code using the touchscreen, Wyze app, Alexa & Google Assistant, or by using an included physical key.
Q: How do I lock Wyze Palm Lock?
A: There are 5 ways to lock Wyze Palm Lock: Use Auto-Lock to lock the door automatically, tap the lock icon on the touchscreen, tap to lock in the Wyze app, command Alexa & Google Assistant to lock the door, or use the physical key.
Q: Why does Wyze Palm Lock have two batteries?
A: This ensures that when the main battery is removed and being charged, the backup battery keeps your Wyze Palm Lock working normally. If the main battery is removed and not reinstalled within 24 hours, you’ll receive a push notification to do so. Once the main battery is reinstalled, it will automatically re-charge the backup battery.
Q: Which Wyze Video Doorbells does Wyze Palm Lock work with?
A: Wyze Palm Lock is compatible with Wyze Video Doorbell v2, Wyze Video Doorbell Pro, and Wyze Duo Cam Doorbell. This lets you lock and unlock the door from your doorbell’s live stream.
  • Touchless Palm Scan Unlock
  • 6 Entry Methods + Wi-Fi Control
  • No Down Time with Dual Battery System
  • Replaces Existing Deadbolt
1 of 4
Highly secure, contactless biometric tech identifies you based on the unique pattern of veins beneath the surface of your palm. Just hover your palm near the reader, and voilà, the door unlocks. It’s like a secret handshake with your front door.
Access for all types of hands.
Palm vein recognition is more accurate than fingerprints and is reliable despite different hand conditions.
  • Palm Scan
  • Access Codes
  • App Control
  • Manual Key
  • Voice Control
  • Manual Latch
1 of 6
Check for door compatibility.
The Wyze Palm Lock replaces your existing lock bolt and will work on most standard residential doors sized between SPECS. Click to see more details.
A bright, numbered keypad illuminates with a simple tap. Set and store up to 50 unique access codes, or create one-time guest passcodes that expire on a schedule.
Dual Battery System
The main is a removable lithium-ion battery that provides up to 6 months of battery life. A secondary backup battery keeps things running for up to two weeks while you charge the main.
A built-in gyroscope detects the angle and movement of the door in real time. Once it senses the door has closed then it automatically locks, preventing false or jammed locks.
Featuring anti-peep technology.
With anti-peep technology, you don't have to worry if someone watches you enter your code.
Simply add extra digits before or after your code and Wyze Palm Lock will still unlock.
Discreet manual lock and key option.
Still yearning for the comfort of a traditional key? We got you covered. Simply slide down the damping cover and manually unlock the old-fashioned way (set of keys included).
Hey Luke, who's your deadbolt daddy?
OK, maybe don't ask him that. Instead, see what this modern day Skywalker had to say when we asked him about Wyze Palm Lock.
Works with Wyze video doorbells.
Lock and unlock directly from the live view of your Wyze video doorbell without switching between screens to open the door for family and friends.
IP53 weather-resistant & BHMA certified.
Backed by the Builders Hardware Manufacturers Association, this lock has been tested, slammed, twisted, and splashed thousands of times to make sure it can handle real life. It meets rigorous standards for security, durability, and performance. It’s not just smart, it’s strong.
BHMA Logo
Backed by industry-best security features.
  • Palm Vein Recognition
    Unlike fingerprints, palm vein pattern is an internal characteristic of the human body and cannot be copied or forged.
  • Hardware Encryption
    Your palms and passcodes are encrypted and stored locally on the lock so no one can access your data.
  • Security Siren & Alerts
    An alarm sounds from excessive incorrect unlock attempts, and if you leave the door open (customizable in the Wyze app).
1 of 3
Unlock even more goodness.
Control from anywhere & view access history.
Control and monitor the lock status from anywhere, anytime with Wi-Fi. See the full access history in the Wyze app. View how it was unlocked, the exact time, and if there were any failed passcode attempts.
Share access and create codes.
Type-C emergency power port.
If the batteries die while you're away, the USB-C port allows for a charge from a power bank so you can enter your access code for entry.
Control with your voice.
Works with smart assistants like Amazon Alexa and Google Assistant. Use your voice commands to lock, unlock, and check the status of their door. For security, unlocking via voice command requires a PIN which authorizes the action.
  • Try saying "Alexa, unlock the front door."
  • Try saying "Google, lock the side door."
  • Try asking "Alexa, is my front door open?"
  • Wyze Palm Lock NEW
    Release date: September 2025
    Unlock the door with your palm
    Secure Palm ID unlock
    6 total ways to unlock, including the app
    Wyze automations or Alexa/Google support
    Replaces existing deadbolt
    Smart Auto-Lock
    Auto-Unlock (available)
    Keypad built-in
    Status: Available
    Buy it now
  • Wyze Lock Bolt
    Release date: 2022
    Unlock the door with your fingerprint
    Fingerprint unlock
    Local app access only
    No Wyze automations or Alexa/Google support
    Basic Auto-Lock
    No Auto-Unlock
    Keypad built-in
    Status: Available, limited stock
    Learn more
  • Wyze Lock
    Release date: 2020
    Monitor and access your door from anywhere
    No fingerprint unlock
    Access the app from anywhere
    Wyze automations & Alexa/Google support
    Attaches to existing deadbolt
    Advanced door position Auto-Lock
    Auto-Unlock
    Optional keypad sold separately
    Learn More
1 of 3
Watch and learn. It's super easy to install.
Wyze Palm Lock is compatible with almost all exterior doors and replaces your existing deadbolt lock in about 20 minutes. Watch our unboxing and install demo below.
