Wyze Indoor Cam Pan
Wyze Indoor Cam Pan
Meet your budget-friendly, robotic security guard that spins, stalks, and secures your space in stunning 2K HD resolution. With a full 360° pan and 103° tilt, it leaves absolutely zero blind spots for mischief, using advanced AI to track the puppy turning your rug into confetti while completely ignoring the swaying curtains. Add in fast Bluetooth pairing for frustration-free setup on 2.4 GHz Wi-Fi. Plus clear two-way audio with a built-in siren to send snoops packing, and 24/7 continuous microSD recording, and you’ve got a powerhouse smart camera that works overtime so you don't have to.
Features
Features
Specs
Specs
Color & Materials
- Color: White
- Finish: Matte
- Body: Polycarbonate
- Lens: Glass + plastic
- CPU: 1.5 GHz
- Image Sensor: 1/2.9'' CMOS
- LED indicator: Front. Red + Blue
- Night Vision: 4 IR LEDs (850 nm)
Dimensions & Weight
- 124mm (H) x 60mm (W) x 63mm (D)
- 11.29 oz (320 g)
Video
- Video Encoding: H.264
- Video FPS: Daytime - 20 fps; Nighttime - 15 fps
- Video Resolution: 1920 x 1080 (1080p)
View Range
- 360° horizontal, 180° vertical
Field-of-view
- 120° FOV
Additional Details
- Digital Zoom: 8x
- Mount: Screw 1/4" - 20
- Circular Base: Diameter 1.69" (43mm)
- Ports: 1 micro USB
- Memory: 128 Mb
- Rotation Speed: Up to 110° per second
- Audio: Built-in speaker and microphone; 2-way audio; Noise & Echo cancellation
- Alerts: Push notifications
- Night Vision and Color Night Vision
Power
- Power Cable Length: 6" (1.8 m)
- Power Adapter Input: 100-240V AC, Output: 5V DC, 1.5A
Connectivity & Compatibility
- 802.11 b/g/n, 2.4GHz (5GHz Wi-Fi not supported)
- Phone Compatibility: Android 9.0+, iOS 15.0+
- Integrations: Alexa, Google Assistant, IFTTT
- Upload speed 1.0 Mbps for SD, 1.5 Mbps for HD
Storage
- Supports up to 256 GB microSD in ExFAT format
Weather & Temperature
- Operating temp: -20°C - 50°C (-4°F - 122°F)
- IP65 Water Resistance
Certifications
- FCC, IC, UL, TSCA, IP65
Language
- English
Warranty
- 1-Year
Important note
- Wyze Cam Pan v3 comes with one of two versions of the Mounting Kit, as shown here. The Mounting Kit pictured on the product packaging is currently of the original design but the package could contain the new design. Both mounts allow you to install the Pan v3 upside down.
In the box
In the box
Wyze Indoor Cam Pan x 1
USB Cable x 1
Indoor Power Adapter (5V, 1.5A) x 1
Mounting Kit x 1
Wall Bracket x 1
Quick Start Guide x 1
FAQ
FAQ
Q: What’s new with Wyze Indoor Cam Pan?
A: Wyze Indoor Cam Pan is your affordable, indoor-only monitoring solution.
Q: Is Wyze Indoor Cam Pan wireless?
A: No, Wyze Indoor Cam is not wireless and is powered via a 1.8 m/6ft USB-A to USB-C cable.
Q: What is the resolution of Wyze Indoor Cam Pan?
A: 2K (2304 x 1296).
Q: If I turn off Privacy Mode, will my camera go back to where it was?
A: Yes, the camera lens will return to its previous position.
Q: What is the frame rate of Wyze Indoor Cam Pan?
A: Day: 20 FPS + 10 FPS for low light; Night: 15 FPS.
Q: Can I use Wyze Indoor Cam Pan outdoors?
A: No, Wyze Indoor Cam Pan is designed for indoor-use only. It is not IP-rated.
Q: Does Wyze Indoor Cam Pan support 5 GHz?
A: No, Wyze Indoor Cam Pan supports 2.4 GHz networks only.
Q: Is Wyze Indoor Cam Pan compatible with Wyze Web View?
A: Yes, Wyze Indoor Cam Pan supports Wyze Web View. (Requires a subscription to Cam Plus, Cam Unlimited, or Cam Unlimited Pro)
Q: Does Wyze Indoor Cam Pan work with Wyze Lamp Socket or Wyze Lamp Socket v2?
A: Wyze Indoor Cam Pan is compatible with Wyze Lamp Socket v2, not v1. However, this camera is for indoor-use only, and should not be installed outdoors or exposed to the elements.
Q: How do I turn on Color Night Viewing?
A: Wyze Indoor Cam Pan can show more natural color detail in low-light environments when there is enough ambient light. To try this, turn off Night Vision in the Wyze app.
Q: Is the camera always on or can you turn it off from the Wyze app?
A: You can turn the camera off in the Wyze app. You can also create a schedule to have the camera turn off automatically at a set time.
2K HD Resolution
See everything in crystal-clear HD quality.
360° Pan/103° Tilt Range
Leave no blind spots unmonitored.
Quiet AI Motion Tracking
Won't disturb your child even in the middle of the night.
Two-Way Audio and Loud Siren
Speak clearly and warn intruders.
So quiet it's almost invisible.
Perfect for naptime and quieter than a whisper. It's smooth, startle-free tracking keeps your child or pet in frame without sudden jerks or grinding noises, ensuring your peace of mind and their uninterrupted rest.
Keep an eye on your little one no matter where you are.
Living Room
Kitchen
One little camera, a dozen jobs.
Playroom patrol
Keep half an eye on the kids in the next room while you get dinner going.
Entryway watch
Point it at the front hall to see deliveries land and the door open.
Pet check
Confirm their habits and catch the troublemaker — no hovering required.
Follow every movement.
Most cameras see one corner of the room. This one turns — left, right, up, down — so a crawling baby or a sprinting puppy never slips out of frame.
Check the nap without cracking the door.
✔️ Pan across the whole crib. Tilt down for a sleeping face, sweep the room when they're up and exploring.
✔️ Hum a lullaby from the kitchen. Two-way audio lets you soothe them before you even reach the stairs.
✔️ See clearly in the dark. Night vision keeps the lights off and the little one asleep.
Watch the zoomies from your desk.
✔️ Follow them room to room. They don't stay in one spot, and neither does the camera. Pan to wherever the noise is coming from.
✔️ Say "off the couch" from the office. Two-way audio lets you talk them down before the cushion's a goner.
✔️ The lights-off hours are covered too. Night vision shows you the whole overnight story without disturbing them.
Peace of mind, even in the quietest hours.
When the lights are off and the house is still, Enhanced IR Night Vision lets you keep track of what matters most to you.
Crisp 2K view
Sharp, detailed video for everyday peace of mind — clear enough to read the room, efficient enough to not eat up your Wi-Fi bandwidth.
360° Pan/103° Tilt AI Motion Tracking
A camera staring blankly at a single wall is useless when the dog is actively destroying a throw pillow just off-screen. With a 360° horizontal pan and a 103° vertical tilt, absolutely nothing escapes its gaze.
Built to follow every move. Loaded with every feature.
Doesn't just see. It understands.
Ai Motion Detection and smart alerts that tell you what the camera actually saw — not just 'something moved.' Upgrade to Cam Unlimited for AI-powered descriptive alerts.
24/7 local recording. Your own microSD card.
No cloud or subscription required. Up to 512 GB.
Patrol your room with Pan Scan and custom waypoints.
Set up to four custom waypoints in the app and let Wyze Indoor Cam Pan patrol the room automatically.
Faster pairing. Reliable streaming.
Wi-Fi 6 + Bluetooth stays connected even on congested networks and instantly set up your camera without scanning a single QR code.
Set up in 3 easy steps.
Plug it in.
Set it on a shelf, point it at what matters, and you're live from anywhere.
Pair via Bluetooth.
Place & watch.
