Wyze Window Cam
Wyze Window Cam
Outdoor monitoring with no glare.
Low stock
- No Tools, Just Stick It
- Upgraded Color Night Vision
- Specialized Design to Reduce Glare
- AI-Powered Motion Detection & Alerts
- 24/7 Local Recording with MicroSD Card
- Easy Setup with Bluetooth®
- Timelapse Video Mode
- Alexa, Google Assistant, IFTTT Support
Features
Features
-No Tools, Just Stick It - The secure hook-and-loop fastener mounting sticker makes installation simple. Just peel, stick, and plug in the camera. We've included an extra-long 10 ft micro USB to USB-A cable with cable clips for tidy mounting.
-Upgraded Color Night Vision - Our iconic Color Night Vision just leveled up. Powered by an f1.0 aperture lens and an advanced BSI sensor, it becomes Pro Color Night Vision — delivering day-like clarity from just a whisper of moonlight or starlight.
-Specialized Design to Reduce Glare - Glare beware. Wyze Window Cam is specially designed to prevent glare on the inside of your window. A bigger mounting sticker removes reflections to give you the clearest footage possible through a window.
-AI-Powered Motion Detection - Movement triggers instant alerts sent to your Wyze app. Upgrade to Cam Unlimited to get Descriptive Alerts that tell you exactly what the camera sees. It will take less effort to review event footage than it took you to read this.
-24/7 Local Recording with MicroSD Card* - Don’t miss a thing with continuous local recordingto a microSD card up to 512 GB. No subscription required.
-Easy Setup with Bluetooth® - No need to scan a QR code during a long setup process. Enjoy hassle-free setup with Bluetooth.
-Timelapse Video (Long Story, Short) - Our Timelapse feature lets you turn hours of slow action—like a glorious sunrise or watching a construction project finish—into short, satisfying clips. Select the recording duration in the Wyze app.
-Alexa, Google Assistant, IFTTT Support - Convenience and customization at your fingertips with integrations like Amazon Alexa, Google Assistant, IFTTT, and Wyze Automations.
Specs
Specs
Color & Materials
-Color: White
-Finish: Textured Matte
-Model: WYZECWC
-Image Sensor: 1/2.9' CMOS (1920 x 1080)
Dimensions
-2.05 in x 2.05 in x 2.05 in (52 mm x 52mm x 52mm)
Weight
-2.75 oz (76 g)
Power
-Power Adapter: Input - 100-240V ~50/60Hz Output - 5V/1A
Additional Details
-Power Cable Length: 10 ft (3 m)
-Ports: 1 micro USB
-Digital Zoom: 8x
-Field-of-View: 120°(DFOV), 101°(HFOV), 53.9°(VFOV)
-Audio: Built-in 100dB Speaker & Microphone; Noise & Echo Cancellation
-Local Storage: Supports up to 512 GB microSD in exFAT format
Connectivity & Compatibility
-802.11 b/g/n, 2.4 GHz Wi-Fi, Wi-Fi 4/5/6
-Phone Compatibility: Android 9.0+, iOS 15.0+
-Integrations: Alexa, Google Assistant, IFTTT
Weather & Temperature
-Weather Resistance: Indoor Only
-Operating: -14°F - 113°F (-10°C - 45°C)
-Storage: --40°F-158°F (-40°C-70°C)
In the box
In the box
1x Wyze Window Cam
2x Mounting Stickers
1x Cable Clips
1x 10' USB Cable
1x Indoor Power Adapter
1x Quick Start Guide
FAQ
FAQ
Q: How does it compare to other Wyze Cams and our existing window mount?
A: Wyze Window Cam is built specifically to be used behind window glass. Unlike our other Wyze Cams, we removed the IR lights and the spotlight entirely to reduce glare and reflections that cause poor image quality at night. We made installation as simple as peeling, sticking, and pressing it onto a clean window. Last, we included an extra-long micro USB cable and cable clips for neat and tidy mounting.
Q: How do I safely remove the mounting sticker from the window?
A: To remove the adhesive from a window, start by applying heat from a hair dryer to soften the adhesive, then use a plastic scraper or a card to gently pry it away. For stubborn residue, a solvent like isopropyl alcohol can dissolve the sticky material. Finish by wiping the area with a clean cloth and washing with soap and water.
Q: Is the mounting sticker reusable or re-stickable?
A: No, the mounting sticker is for single-use only, and cannot be moved and reused after mounting. However, Wyze Window Cam comes with two mounting stickers in case you want to mount it somewhere else.
Q: What do I do if the adhesive loses it's stickiness?
A: Always thoroughly wipe clean and dry the area on your window before axing the sticker. Or replace with the spare window sticker that comes in the box.
Q: Can I mount Wyze Window Cam on a window with screen?
A: We do not recommend placing the camera behind a screened window as it will negatively impact video quality.
Q: Why is the mounting sticker bigger than the camera?
A: The bigger sticker is to minimize glare caused by indoor lighting behind Wyze Window Cam. Please make sure you mount the sticker horizontally for best results. Do not trim the sticker.
Upgraded Colour Night Vision
Easily Mount Inside Window
Local Recording to MicroSD Card
Outdoor security. Inside.
See in full colour. even in near-darkness.
With a super wide F1.0 aperture and BSI sensor, it delivers astonishing, full‑colour night vision using just streetlights or moonlight.
Easy window mount system.
Peel. Stick. Plug. Protected.
No Tools. Just Stick.
No drilling. No permanent hardware. The secure hook-and-loop fastener mounting sticker makes installation simple.
Anti-Glare Design.
Glare beware. Engineered to eliminate glare and reflections for crisp & clear window footage.
AI-powered detection & alerts.
Window cam knows what matters
Timelapse video.
Create stunning time-lapse videos of a sunset or track project progress.
Extended Power Cable
We've included an extra-long 10 ft power cable with cable clips for tidy mounting.
24/7 Recording with Wyze MicroSD card
Store days, weeks, or months of footage locally.* No subscriptions. No cloud requirements. Ever.
*microSD card required (sold separately)
Easy Bluetooth Setup & WiFi 6
Easy Bluetooth pairing and Wifi 6 performance means faster pairing, stronger connection, and rock-solid streaming —even on busy networks.
Wyze microSD Card
Add a Wyze MircoSD Card to capture days worth of local recordings.
More to Love
Review Video Events in the Wyze App
Motion Detection Zones
Alexa, Google Assistant, IFTTT support
Setup takes seconds.
