Wyze Light Strip
Wyze Light Strip
Color your world with brilliant LED accent lighting.
                        Features
                        Features
                    Sync To The Music
Sync your lights to the beat of the music with a built-in microphone.
Scenes
Group strips together and explore default scenes or save your own to match your mood.
Voice Control
Use Alexa or Google Assistant to control your Wyze Light Strips by voice.
Timers
Set a timer to turn your device on or off.
Vacation Mode
Have Wyze Light Strip turn on and off to make it look like someone is home.
Wake Up Gently
Set Wyze Light Strip to gently turn on in the morning to help you wake up or fade out in the evening to help you fall asleep.
16 Million Colors
Explore all the colors of the rainbow or different shades of white.
WiFi App Control
Control your lights directly from the controller on the strip or from anywhere in the world with the Wyze app.
Easy Setup
Peel and stick Wyze Light Strip directly onto your desired location and use the optional clips for extra strength. You can pair multiple light strips to the Wyze app at the same time for a quick and easy setup.
                        Specs
                        Specs
                    Weight
1.01 lbs
Dimensions (inches)
5.11 x 5.03 x 3.5
Length
32.8 ft
Common Key Features
Colors
16 million
Single or Multicolor
Single
Customizable Zones
Power Source
Corded Electric
Power Adapter Output
12 Volts
Wattage
32.8 ft
48 watts
Power Adapter Input
100-240V
Usage
Indoor Use Only
Communication Mode
802.11 b/g/n, 2.4 GHz, Bluetooth
Lumens Per Meter
Blue(0.8lm/LED at 20mA) *30pcs/meter
Red(1.0lm/LED at 20mA) *30pcs/meter
Green(2.5lm/LED at 20mA) *30pcs/meter
Operating Temperature
-20°C - 50°C
Storage Temperature
-40°C - 70°C
Life Expectancy
25,000 Hours
                        In the box
                        In the box
                    Wyze Light Strip x2
Controller x 1
Adhesive Clips x20
Power Adapter x 1
Quick Start Guide x 1
Alcohol Wipe x 4
                        FAQ
                        FAQ
                    Can you connect Wyze Light Strips together?
No, Wyze Light Strips are sold in two lengths, 16.4 feet and 32.8 feet, and are not built to be connected end-to-end. The 32.8” version is actually two 16.4” strips that have the controller in the middle.
Can you connect different models together?
No, you cannot connect different models together physically, but they can be grouped together in the Wyze app.
Is Wyze Light Strip weatherproof?
No, both Wyze Light Strip and Wyze Light Strip Pro are meant for indoor-use only.
Can I group Wyze Light Strips together and with Wyze Bulbs?
Not yet, but we’re working on that for the near future.
How do I mount Wyze Light Strip?
With the adhesive backing. Wyze Light Strip has an adhesive back and additional clips that can be used to attach the strip to a variety of surfaces. Make sure to clean the mounting area before installation to ensure the best hold.
Can I cut Wyze Light Strip?
Yes, you can cut both Wyze Light Strip and Wyze Light Strip Pro at designated cutting marks on the strip to fit your desired location.
How does the music feature work?
Using the built-in microphone. The controller for Wyze Light Strip and Wyze Light Strip Pro has a built-in microphone used to match the lights to the beat of the music.
What’s the difference between Wyze Light Strip and Wyze Light Strip Pro?
Wyze Light Strip Pro can have multiple colors on the same strip while Wyze Light Strip can only have one color at a time. This means Wyze Light Strip Pro can have different colors across the strip and has more advanced lighting effects. Both versions have a microphone and can be grouped together.
16 Million Colors
RGB and tunable white
Music Mode
Sync lights to the beat of the music
Sun Match
Automatically adjust color to match the time of day
Trimmable Design
Cut to fit any space
16 million colors for every corner
Add a splash of color to backlight your favorite screen, frame your headboard, or illuminate dark corners. Just peel, stick, and plug in Wyze Light Strip anywhere for perfect accent lighting.
Sun Match
Automatically sync the color temperature of your LED light strips to the natural light-cycle of the day, so you can wake, work, or wind down the way nature intended
Trimmable Design
Designated cut areas allow precise customization to fit your space.
Music Mode makes a rave in every room
Sync your lights to the beat of your favorite tracks with Music Mode using Wyze Light Strips’s built-in microphone. Your dance videos (and dance parties) just got a serious glow-up.
More bright ideas
Voice Control
Vacation Mode
Make it look like someone's home whenever you are away. Just enable "Vacation Mode" in the Wyze app and our light strip does the rest.
Sleep Routines
Timers & Automations
Start a timer to have your strip turn on or off or create powerful automations in the Wyze app.
                  Wyze Light Strip (Current Page)
- One color per strip
- Basic lighting effects
- No epoxy coating -
- Up to 16 colors per strip
- Advanced lighting effects
- Protective epoxy coating
- Plus all great features of Wyze Light Strip!
Shop now
