Wyze Solar Cam Pan 2K
Maintenance-free battery power with solar 360° protection.
Low stock
- Integrated High-Efficiency Solar Panel
- 360° Pan & 70° Tilt Coverage
- AI-Powered Person Tracking
- 2K HD Resolution with WDR
- Quick, Easy Mounting
- IP65 Weather Resistance
Features
Features
Specs
Specs
Specs
- Model: WYZESCPWH
- Materials: Body: Polycarbonate; Lens: Glass + Plastic
- Certifications: FCC/IC, IP65, RoHS, REACH, CA65
Audio
- Microphone: Built-in, digital
- Siren: 105dB
- 2-Way Audio
Storage & Alerts
- Alerts: Push notifications
- Cloud Storage: Stored in the AWS cloud* *Wyze Service subscription required
- Local Storage (microSD card required): Supports 8-32 GB microSD cards in FAT32 format; Supports up to 512 GB microSD cards in exFAT format
Weather & Temperature
- Weather Resistance: IP65
- Operating Temperature: -4°F - 122°F (-20°C - 50°C)
- Storage Temperature: -4°F - 140°F (-20°C - 60°C)
- Resolution: 2K (3MP)
- Digital Zoom: 8x
- Field of View: Diagonal: 130°; Horizontal: 108°; Vertical: 57°
- Frame Rate: Daytime: 20 FPS; Nighttime: 15 FPS
- Night Vision: Color Night Vision; IR LEDs: 2x 850nm
- Spotlight: 2x White LED (100 lm)
- Pan/Tilt Range: Horizontal: 360°; Vertical: 70°
Connectivity & Compatibility
- OS Requirements: Android 9.0+ or iOS 15.0+
- Wi-Fi: 802.11 b/g/n 2.4 GHz, Wi-Fi 4/5/6
- Bluetooth® Setup
Power
- Power Adapter: 5V/2A (not included)
- Input: 110-240V
- Cable: Type-C to USB-A (2 ft. / 0.6 m)
- Integrated Solar Panel (1.8W)
- Battery: 6400mAh, non-removable Lithium-ion battery
- Charging Time: 0-100% in 4-6 hours using the cable/adapter
- Battery Life: Up to 6 months (if not connected to power)
In the box
In the box
- Wyze Solar Cam Pan x 1
- Solar Panel x 1
- Camera Mounting Bracket x 1
- Solar Panel Mounting Bracket x 1
- Charging Cable (2ft) x 1
- Camera Mounting Kit x 1
- Solar Panel Mounting Kit x 1
- Camera Mounting Drilling Guide sticker x1
- Quick Start Guide x1
FAQ
FAQ
Q: What is Wyze Solar Cam Pan 2K?
A: Wyze Solar Cam Pan 2K is a revolutionary solar-powered, wire-free outdoor security camera with an integrated solar panel, offering 360° pan-and-tilt coverage, AI person tracking, 2K resolution, color night vision, and a motion-activated spotlight.
Q: Is Wyze Solar Cam Pan 2K part of the previous Wyze Solar Cam Pan recall?
A: No. Wyze Solar Cam Pan 2K is the updated version of Wyze Solar Cam Pan and is not part of the previously announced voluntary recall for certain earlier Wyze Solar Cam Pan units purchased on or before April 3, 2026. That recall applied to certain earlier units where the solar panel may have been attached to the top of the camera using the incorrect long flat-head wood screws.
Q: How is Wyze Solar Cam Pan 2K different from the earlier version?
A: Wyze Solar Cam Pan 2K keeps the same compact, clean, and user-friendly industrial design customers expect, while adding several updates to support a clearer and more error-proof installation experience. These updates include revised installation instructions, redesigned screw packaging, fail-safe screw types, and added warning labels on the camera body and brass inserts to help guide proper setup.
Q: Why does the packaging say “Wyze Solar Cam Pan 2K”?
A: The “2K” name and packaging update help clearly distinguish the updated version from earlier Wyze Solar Cam Pan units. If you purchase Wyze Solar Cam Pan 2K from Wyze after April 3, 2026, you are purchasing the updated version.
Q: Was the previous issue related to the camera itself or the installation process?
A: The previous recall was related to incorrect installation instructions for certain earlier Wyze Solar Cam Pan units. The issue could occur if the long flat-head wood screws were incorrectly used to attach the solar panel bracket to the top of the camera instead of the short pan-head machine screws. Wyze Solar Cam Pan 2K includes updated instructions, redesigned screw packaging, fail-safe screw types, and added warning labels to better support proper installation.
Q: Which screws should I use to attach the solar panel to the top of Wyze Solar Cam Pan 2K?
A: Use only the screws specified in the included Quick Start Guide and Outdoor Installation Guide for attaching the solar panel bracket to the top of the camera. The long screws are intended for mounting the product to a wall or other surface and should not be used to attach the solar panel bracket to the top of the camera. Always follow the included installation instructions before setup.
Q: What should I do before installing Wyze Solar Cam Pan 2K?
A: Before installation, carefully review the included Quick Start Guide and Outdoor Installation Guide. Pay close attention to the screw packaging, warning labels, and instructions for attaching the solar panel.
Do not substitute screws or hardware. Only use the screws and hardware included in this package and specified in the installation instructions.
Q: I already own the earlier Wyze Solar Cam Pan. How do I know if mine is affected by the recall?
A: If you purchased Wyze Solar Cam Pan on or before April 3, 2026, please visit the Wyze recall page (https://www.wyze.com/pages/scprecall) to determine whether your camera is affected. The recall applies to certain earlier units where the solar panel was attached to the top of the camera using the incorrect long flat-head wood screws.
Q: If I am unsure which version I have, how can I tell?
A: You can identify Wyze Solar Cam Pan 2K by checking the packaging. The updated version includes “2K” after the “Wyze Solar Cam Pan” product title.
You can also check in the Wyze app if you are using app version v3.18 or newer. Go to Settings > Device Info > Model Version. Both versions share the same device model name, “Wyze Solar Cam Pan,” but the updated Wyze Solar Cam Pan 2K shows Model Version 1.1, while the original version shows Model Version 1.0.
If you purchased an earlier Wyze Solar Cam Pan and are unsure whether it is affected by the previous recall, please visit the Wyze recall page for the step-by-step guide.
A: If you purchased Wyze Solar Cam Pan on or before April 3, 2026, please visit the Wyze recall page to determine whether your camera is affected. The recall applies to certain earlier units where the solar panel was attached to the top of the camera using the incorrect long flat-head wood screws.
Q: How is Wyze Solar Cam Pan 2K different from other battery-powered Wyze outdoor cameras?
A: Unlike other battery-powered Wyze Cams, Wyze Solar Cam Pan 2K comes with an integrated solar panel and a built-in 6400 mAh rechargeable Li-ion battery for truly maintenance-free power. It is our only wireless camera with full 360º pan-and-tilt coverage, smart AI person tracking, and crystal-clear 2K resolution, all designed for outdoor security without the hassle of swapping and charging batteries.
Q: How much sunlight does Wyze Solar Cam Pan 2K need each day for continuous power?
A: Wyze Solar Cam Pan 2K's high-efficiency ETFE solar panel is designed for maintenance-free performance. With as little as 1 hour of direct sunlight per day, the solar panel can generate enough energy to keep the camera running continuously with normal use. Battery performance may vary due to mounting location, seasonal changes, and event activity levels.
Q: Is Wyze Solar Cam Pan 2K complicated to install?
A: Wyze Solar Cam Pan 2K is truly wire-free, and can be installed in a snap. You can mount it anywhere without worrying about power outlets, complicated mounting equipment, or running wires.
Q: Does AI Person Tracking require a subscription service?
A: No, Wyze Solar Cam Pan 2K comes with AI-powered person tracking without the need for a subscription. The camera follows and tracks the detected person when this feature is enabled in the Wyze app.
Q: What is the pan-and-tilt range?
A: Wyze Solar Cam Pan 2K provides 360° pan and 70° tilt coverage, ensuring no blind spots around your property.
Q: Does it include deterrent features?
A: Yes, Wyze Solar Cam Pan 2K comes with a motion-activated spotlight, Motion Warning, and a 105dB siren to help warn and deter unwanted visitors.
Q: Does Wyze Solar Cam Pan 2K use Bluetooth®?
A: Yes, Solar Cam Pan 2K supports Bluetooth® setup for fast and seamless pairing with the Wyze app.
Q: What is the Motion Detection range?
A: Wyze Solar Cam Pan 2K can detect motion up to 30 feet away when mounted 8 feet above the ground, and tilted 30º downward (as recommended).
Q: Do you need a base station for Wyze Solar Cam Pan 2K?
A: No, and it is not compatible with Wyze Base Station. Wyze Solar Cam Pan 2K is set up using Bluetooth and connects directly to your 2.4 GHz home Wi-Fi network.
Q: What are the mounting options for Wyze Solar Cam Pan 2K?
A: Camera: You can either mount Wyze Solar Cam Pan 2K camera on a vertical wall or under eaves using the included camera mounting bracket and mounting kits. Solar Panel: You can either mount the solar panel on top of the camera or mount the solar panel separately, leveraging the attached 10-ft cable on the solar panel.
Q: Can I record continuously to a microSD card?
A: Yes, you can record continuously to a microSD card as long as the camera is connected to 5V/2A AC power.
Q: Is Wyze Solar Cam Pan 2K weatherproof?
A: Just be sure to properly secure the Micro SD card slot cover to avoid water damage. If using the continuous plug-in power option, a Wyze Cam Universal Outdoor Power Adapter (latest version) is required for outdoor use.
Q: Will Wyze Solar Cam Pan 2K work even when it's cloudy or overcast?
A: Yes, Solar Cam Pan 2K is equipped with a 6400 mAh lithium battery, allowing the camera to operate through cloudy or rainy conditions without solar charging, and last 2-6 months under normal usage. Please note that solar charging will automatically pause to protect the battery when the outside temperature drops below 32°F (0°C).
Q: Does cold weather affect Solar Cam Pan 2K's battery?
A: Yes, in two ways. Battery power drains faster in cold weather than in mild conditions. And when the outdoor temperature drops below 32°F (0°C), solar charging automatically pauses to protect the battery, even if the panel is generating power. The camera keeps recording throughout, it simply isn't taking on new charge, and charging resumes automatically once temperatures rise. Solar Cam Pan 2K is rated to operate from -4°F to 122°F (-20°C to 50°C).
Q: How do I get the best battery life during the winter months?
A: Short, dark days mean less charging time, so give the solar panel the best position you can. Keep it clean, out of the shade, and with the cable fully inserted, angled for at least 1 hour of direct sunlight per day. In the Northern Hemisphere, face the panel south and tilt it 30°. Then reduce what drains the battery: mount the camera 7-10 ft high and tilt it 25-30° downward so it isn't triggered by busy roads or moving trees, enable Power Saving Mode under Settings > Power Manager, and avoid prolonged live streaming.
Q: What should I do if my camera runs low on battery in the winter?
A: Bring the camera inside and charge it fully by plugging it into 5V/2A power with the included Type-C cable. Once it is charged and back outside, solar charging resumes on its own when the temperature rises above 32°F (0°C).
Maintenance-Free Solar Power
An integrated solar panel delivers continuous power to the battery with just one hour of sunlight per day.
360° Pan/Tilt Coverage + 2K HD
See every detail with no blind spots. Secure an entire space with pan and tilt coverage.
AI-Powered Object Tracking
Detects and locks on to people, following them wherever they go.
Quick, Easy Mounting + Setup
Mount anywhere and snap into place in minutes. Enjoy hassle-free setup with Bluetooth®.
No battery swaps. No wires. No worries.
Let the sun do the work. ☀️ An integrated high-efficiency ETFE solar panel delivers continuous power to the battery with one hour of sunlight per day.
360° pan/tilt coverage with AI-powered person tracking.
Edge AI detects and locks on to people, following them wherever they go. Secure an entire space with pan and tilt coverage. Control remotely via the Wyze app to see exactly what you want.
Flexible solar panel mounting.
Connect the solar panel on top of the camera for a tidy install. Or place it separately where the sunlight’s strongest for maximum charging power. The choice is yours.
Cloudy days? No sweat.
Does the sun like to hideout for a while where you live? No worries. The built-in 6400mAh lithium-ion battery provides up to 6-months of standalone power.
Crystal-clear video recording with a wide field-of-view captures every detail, day or night. Wide Dynamic Range (WDR) evens out the brightest highlights and the darkest shadows so nothing gets lost.
Motion-activated spotlight & siren.
Deter intruders or light your way home with a motion-activated spotlight. Activate the loud 105dB siren for extra security.
IP65 weather resistance.
Drip. Splash. Plop. No matter the weather, this camera cannot be stopped. Built tough to handle the elements outdoors. Designed with style to blend into your home indoors.
Two-Way Audio
Hear sound and speak through the camera from anywhere with the Wyze app.
Detection Features
AI Notifications and Descriptive Alerts
Customize your detections and notifications. Get a detailed alert of what's happening with Descriptive Alerts, available with Cam Unlimited Pro. Click to learn more.
Wi-Fi 6 Support
Maintain a strong and reliable connection with Wi-Fi 6 support (Wi-Fi 6 router required), resulting in smoother livestreaming.
24/7 Recording with microSD
Don’t miss a thing with 24/7 local recording (continuous plug-in power required) with a microSD card up to 256GB (sold separately).
Alexa, Google Assistant, IFTTT support
Wyze microSD Card
Add a Wyze MircoSD Card to capture days worth of local recordings.
Review Video Events in the Wyze App
Motion Detection Zones
