1 of 15
Wyze Battery Video Doorbell
Effortless. Battery powered. Porch protection.
Style
Low stock
  • Head-to-Toe Viewing
  • 1536 x 1536 HD+ Resolution
  • Wire-Free or Wired
  • Up to 6-Month Battery Life
  • AI-Powered Person & Package Detection
  • Easy Install in Minutes
Features
- Head-to-Toe Viewing
- 1536 x 1536 HD+ Resolution
- Wire-Free or Wired
- Up to 6-Month Battery Life
- AI-Powered Person & Package Detection
- Easy Install in Minutes
Specs
- Colour: Black
- Field of View: 150° x 150°
- Video Resolution: 1536 x 1536
- IR Lights: 850nm
- Siren: 90dB
- Weather Resistance: IP65
- Wi-Fi: 2.4 GHz, Wi-Fi 4/5/6
- Bluetooth®: BLE 5.0
- Charging Port: USB-C
- Battery Capacity: 6400 mAH
- Power Supply: Battery or 5V/2A DC/12-24V, 50/60HZ AC Wired
- Dimensions: 5.71 in x 1.85 in x 1.14 in / 145 mm x 47 mm x 29 mm
- Weight: 7.58 oz (215 g)
- Local Storage: Up to 256 GB MicroSD Card
- Operating Temperature: -4°F - 122°F (-20°C - 50°C)
- Storage Temperature: -4°F - 140°F (-20°C - 60°C)
- Certifications: FCC, IC, UL, DOE, CEC, NRcan, CA65, TSCA
- Warranty: 1 Year
In the box
- Wyze Battery Video Doorbell x 1
- USB-C Charging Cable x 1
- Corner Mounting Plate x 1
- Flat Mounting Plate x 1
- Extension Wires x 2
- Wire Nuts x 3
- Expansion Tubes x 3
- Jumper Wire x 1
- Long Screws x 3
- Doorbell Detaching Pin x 1
- Quick Start Guide x 1
FAQ
Q: How long does it take to install Wyze Battery Video Doorbell?
A: Mounting the doorbell on a wooden door frame with the included mounting kit should take under 1 minute.
Q: Do I need a technician for installation?
A: No technician is required for installation, even if you choose the hardwired option to use your existing doorbell wiring.
Q: Where can I install the doorbell?
A: Anywhere near your front door is a great choice since no wires are needed when you go fully wire-free. We recommend mounting your doorbell 4 feet up from the ground for the best motion detection and usability.
Q: Does the doorbell use batteries? How long is the battery life?
A: Yes, our wire-free doorbell is powered by a built-in battery pack. The battery life is 3-6 months with normal use.
Q: Is motion detection available on Wyze Battery Video Doorbell?
A: Yes, and you can receive notifications whenever motion is detected (using the body heat infrared sensor and edge algorithm.). With a subscription to Cam Plus, you’ll be able to configure alerts to detect people, pets, packages, and more.
Q: Is Cam Plus available on Wyze Battery Video Doorbell?
A: Yes, and you’ll receive a up to 30-day free trial of Cam Plus after activating your doorbell. With an annual or monthly subscription to Cam Plus, Wyze Battery Video Doorbell will have the latest AI features, including Person Detection, Package Detection, Vehicle Detection and Pet Detection. Also, Cam Plus enables the doorbell to record full-length event videos.
Q: Can I use my existing doorbell wiring to power Wyze Battery Video Doorbell?
A: Yes, compatible wiring will allow the doorbell to charge while it’s mounted. Having constant external power will allow your doorbell to record an additional 3-6 seconds of pre-roll video before an event, allowing you to get more context for a video clip.
Q: Is Wyze Battery Video Doorbell compatible with a chime?
A: Yes, the doorbell is compatible with Wyze Wi-Fi Chime (not included). Or you can use the Wyze chime controller(not included) to hard wire with your house mechanical chime.
Q: Is Wyze Battery Video Doorbell weather resistant?
A: Yes, Wyze Battery Video Doorbell is IP65-rated as weather resistant for outdoor installation. This means that it is "dust-tight" and protected against water sprays from any angle.
Q: Can I control the volume of my Wyze Wi-Fi Chime?
A: Yes, you can adjust the volume or change ringtone in the Wyze app, in your Chime settings.
  • Head-To-Toe View Angle
    Wide 150° x 150° view angle sees visitors and packages tucked right against your door.
  • 1536 x 1536 HD+ Video Resolution
    Records and streams crystal clear video with a 1:1 aspect ratio.
  • 6-Month Battery Life
    Get up to 6 months of battery life, or hardwire for continuous power.​
    Place it anywhere (mounting hardware included). A corner plate is also included for optimal viewing angles.
1 of 4
A battery-powered doorbell built to see the full picture.
Experience effortless front porch protection, no matter where you live. Easily install it wired or wire-free and view it all from anywhere in crystal-clear HD+ resolution.
Wide head-to-toe view angle.
See more of what matters. With a 150° horizontal and 150° vertical field of view, Wyze Doorbell captures everything from a visitor’s smile to a package tucked against your door.
Keep an eye on kids coming home from school, delivery drop-offs, or unexpected guests, all without blind spots. Even if someone stands close to the camera, you’ll still see the full picture — from head to toe, porch to street.
Wire-free or wired.
Go up to 6 months on a single charge, or hook it up to your existing doorbell wiring for nonstop power. Recharging is easy, just plug into the USB-C port on the back.
Flexible chime options.
Never miss a ring. Connect to your home’s existing chime, or pair with a Wyze Universal Wi-Fi Chime (sold separately) to hear alerts anywhere in your home, even through your Wyze Cams.
Pick from 20 chime sounds and 8 volume levels to match your style (or have a little fun and set it to a dog bark to surprise uninvited guests).
Easy to install for homes and apartments.
Mount anywhere with the included hardware and corner plate for the perfect view. Ideal for renters or homeowners who want simple, secure installation without hassle.
When motion is detected, Wyze Battery Video Doorbell can automatically play a “You are currently being recorded” message, letting visitors know they’re on camera.
That simple phrase can make a big difference. Studies have shown that visible or audible signs of surveillance reduce break-ins by up to 60%, and most burglars admit they’ll avoid homes with cameras or alarms altogether.
With two-way audio, you can greet guests, give delivery instructions, or let friends know you’ll be right there, all through the Wyze app.
In a rush? Use Quick Responses to instantly play preset messages like “Please leave the package at the door” or “Be there shortly.” Perfect for when your hands are full, your baby’s napping, or you just don’t feel like yelling through the door.
IP65 weather resistance.
No need to worry about water damage, foggy lenses, or failed recordings of those cheaper doorbells. Get reliable protection and peace of mind, no matter what the forecast says.
Unlock from anywhere.
Pair with Wyze locks.
See who’s at the door and let them in, all from the same screen. When paired with Wyze Palm Lock, you can unlock your door remotely right from the Wyze app or your doorbell’s live view.
Shop Now
  • Review Video Events in the Wyze App
  • Motion Detection Zones
1 of 2
Local Recording with MicroSD Card
Don’t miss a thing with local recording (continuous wired power required) with a microSD card up to 256GB (sold separately).
Alexa, Google Assistant, IFTTT Support
Watch and learn. Customize your doorbell.
Watch our unboxing below. Learn how to pair your doorbell, customize notifications, add a Chime, and more.
