Wyze Chime Controller
Works only with Wyze Video Doorbell v2 and Duo Cam Doorbell.
Standalone chime controller unit. Only compatible with Wyze Video Doorbell v2 and Duo Cam Doorbell.
Features
Features
Easy to install
Works with most mechanical chimes
Specs
Specs
Dimension: 47mm x 32mm x 15mm (controller unit body)
Wire: 13cm wire
Power: AC16V/AC24V, ≥10VA
Compatible Products: Wyze Video Doorbell V2, Wyze Duo Cam Doorbell
Work Temp-20ºC - 50ºC
Storage Temp-40ºC - 80ºC
In the box
In the box
1x Chime controller unit
FAQ
FAQ
Q: What cameras are compatible?
A: Wyze Chime Controller is a wired unit that works directly with your existing mechanical chime and is compatible with Wyze Doorbell v2 and Duo Cam Doorbell.
Q: Is this a chime?
A: No. This is not a chime device and does not have the ability to audibly notify you when someone pressed the doorbell button. You will need an existing mechanical chime for this controller to work.
Q: What mechanical chime is compatible?
A: Wyze Chime Controller is compatible with nearly every mechanical chime out there, even broken one. Double-check if your existing chime is compatible, here: https://support.wyze.com/hc/en-us/articles/19832958217115-Wyze-Video-Doorbell-v2-Chime-Compatibility-Check.
Compatible with Doorbell v2 and Duo Cam Doorbell
We all expect our chimes to ring when our doorbell cameras are pressed. With our chime controller unit, you can make new video doorbell technology work with your existing mechanical chime setup.
Works with your mechanical chime
Ding dong. Hear alerts exactly where you want in your home with your Wyze cams.
Doorbell cams that work for your setup
Check compatibility
Learn about compatibilityWhile made to work with most mechanical chimes, here's how to check compatibility.
Installation
Learn about installationWe lay it all out for you. But checkout the steps prior to buying.
Alternative wiring setup
Learn the alternativeMost home setups, while similar, are not the same. See if this works better for you.
Need help?
Let's troubleshootAfter all is said and done, sometimes we need a little extra help to make it work.
Make sure you have a compatible video doorbell cam.
✅ Compatible WOOHOO!
Product: Wyze Doorbell v2
FOV: 135 x 103°
Resolution: 2K
Chime: Wyze Chime Controller (for existing mechnical chimes)
Installation: Screw mounting
Local Storage: Supports up to 256 GB
Mounting Location: Requires existing wiring
Power: Wired (AC 16-24 V) only
Product: Duo Cam Doorbell NEW
FOV: Top: 132x100°/Bottom: 121x60°
Resolution: Top: 2K/Bottom: 1080p
Chime: Wyze Wi-Fi Chime and Wyze Chime Controller
Installation: 3M adhesive or screw mounting
Mounting Location: Anywhere
Power: Wyze Removable Battery Pack or Wired (AC 16-24 V)
❌ Not compatible
Product: Wyze Video Doorbell Pro
Works with original Wyze Chime.
❌ Not compatible
Product: Wyze Doorbell (v1)
