2,500+ ratings on Amazon
Wyze Cam v4
Wyze Cam v4
The clearest Wyze Cam ever made.
Get unmatched security with Wyze Cam v4. Crystal-clear 2.5K QHD resolution, Enhanced Color Night Vision, and motion-activated spotlight keep your home safe day or night. Plus, 24/7 local recording, Wi-Fi 6 support, and compatibility with Alexa and Google Assistant for ultimate convenience.Â
Features
Features
Crisp 2.5K QHD Resolution with Wide Dynamic Range
Color Night Vision
IP65-rated for Indoor and Outdoor Use
Versatile Mounting
Improved Two-Way Talk
Integrated LED Spotlight
Louder Mini Siren
Specs
Specs
Wyze Cam v4 Device Details
Colors & Materials
Color options: White and Grey
Body: Polycarbonate
Lens: Glass + Plastic
Lens FOV: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Sensor: CMOS Starlight Sensor
LED Indicator: Front. Red + Blue.
Camera Dimensions & Weight
2 in x 2 in x 2 3/8 in
Weight: 0.49 lb (222 g)
Power
Power Adapter: Input 110-240 V (AC/DC), Output Indoor 5V/1AOutdoor Power Adapter (sold separately)
Cable: 6-Foot Flat micro USB to USB-A cable
Connectivity
2.4 GHz Wi-Fi, Wi-Fi 6
Video
Resolution: 2.5K QHD (2560x1440)
Digital Zoom: 8x
Wide Dynamic Range (WDR): Yes
IR Lights: 4x850 nm
Day/Night Vision: Yes
Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
Color Night Vision: Yes
Video Encoding: H.264
Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Audio
Speaker: 99dB, waterproof
Simultaneous 2-way Talk: Yes
Built-in Siren: Yes
Noise & Echo Cancellation: Yes
Phone Compatibility
Android 7.0+, iOS 14.0+
In the box
In the box
Included in a 1 pack:
· Wyze Cam v4 x1
· Quick Start Guide x1
· Wall Mount Plate x1
· Wall Mount Plate Tape x1
· Screw Kit x1
· Indoor USB Power Adapter x1
· 6-Foot Flat micro USB to USB-A cable x1
Note: The camera and USB cable will be either white or grey, depending on the colorway chosen.
FAQ
FAQ
Q: What's new with Wyze Cam v4?
A: Wyze Cam v4 is our best camera yet, with super-clear, 2.5K QHD resolution and enhanced Color Night Vision. Our new audio technology now removes harsh and static sounds better than ever before. You can use Wyze Cam v4 indoors and outdoors, and use its built-in spotlight and Motion Warning feature to deter intruders. With Wi-Fi 6 capabilities, you can get better connectivity, and with Smart Focus on the Live stream, you can catch important details in motion while still viewing the bigger picture.
Q: Is Wyze Cam v4 wireless or battery-powered?
A: Wyze Cam v4 is wired only. It is not wireless or battery powered. It is powered via the included 6 ft USB cable.
Q: Can I use Wyze Cam v4 outdoors?
A: Yes, Wyze Cam v4 is IP65-rated and can be used both indoors and outdoors.
Q: What is the resolution of Wyze Cam v4?
A: 2.5K QHD (2560x1440).
Q: Does Wyze Cam v4 support 5 GHz Wi-Fi?
A: No, Wyze Cam v4 only supports 2.4 GHz networks.
Q: What is Color Night Vision?
A: Wyze Cam v4 is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night.
Q: Is Wyze Cam v4 compatible with Wyze Web View?
A: Yes, Wyze Cam v4 is compatible with Wyze Web View.
Q: What's so great about Wi-Fi 6?
A: Wi-Fi 6 offers better range, handling of congestion, and higher connection speed. For example, the max capacity of Wi-Fi 5 is ~80 feet vs WiFi 6 at ~150 ft, and the number of streams for Wi-Fi 5 is 8 streams vs Wi-Fi 6 at 12 streams. If you are interested in a Wi-Fi 6 router, check out our Wyze Mesh Router and Wyze Mesh Router Pro.
Q: Wi-Fi 6 work with my Wi-Fi 4 router?
A: Yes, Wi-Fi 6 is backwards compatible.
Q: Does Wyze Cam v4 have a battery?
A: No, Wyze Cam v4 is powered via a USB cable.
Q: What is the frame rate of the v4?
A: Day: 20 frames per second (fps)
Night: 15 fps
A: Is Wyze Cam v4 weather resistant?
A: Yes. While it's not waterproof, it is weather resistant and safe to use outside. Indoor and Outdoor IP65 rated.
Q: Which accessories work with Wyze Cam v4?
A: Wyze Cam v4 works with the following accessories: Wyze Lamp Socket, Wyze Cam Window Mount, Wyze Cam Outdoor Adapter v1 and v2, and microSD cards up to 512 GB.
Q: What is Smart Focus?
A: Smart Focus is a new feature that adds a smaller view of the Live stream, while the camera focuses on what matters - motion. When motion is detected, you will have two views of the Live stream at the same time.
Q: Is Wyze Cam v4 compatible with Wyze Home Monitoring?
A: No. Wyze Cam v4 is not compatible with our home monitoring service, but it's on the wish list!
The best just got
Capture images and video in greater detail with Quad High Definition clarity.
More security with Color Night Vision.
Enhanced hardware pierces through darkness, unveiling stunning details in low-light conditions that even the human eye can't catch. It's like giving your camera superhero vision!
Traditional Night Vision
Color Night Vision ✨
ip65 weather resistance
Place it anywhere.
Enhanced two-way talk
Clearer conversation.
Talk to anyone easily with a more powerful amplifier and an updated mic for clearer camera audio.
Integrated Spotlight + Siren
More safety at night.
Record every second
Don’t miss a thing with continuous local recording to a microSD card up to 512 GB. No subscription required.
Wyze microSD Card
Add a Wyze MircoSD Card to capture days worth of local recordings
Connect with bluetooth®
Easy to set up.
Screw-free magnetic mount
Easy to mount.
Works with smart assistants
AUTO-ZOOM WITH AI
Track with Smart Focus.
Even more features to love.
Wi-Fi 6 Connection Support
Motion and Sound Detection
Motion Detection Zones
Smoke & CO Alerts
Receive an alert the moment Wyze Cam hears a Smoke or CO alarm go off. Wyze Cam records a video during this time.
Pick the Best Plug-In Camera for You
Wyze Cam v4 NEW
Ready to buy?Colors: White or Grey
Finish: Textured Matte
Resolution: 2.5K QHD w/ our best color range (WDR)
Field of view: 115.9° (D) x 98.5° (H) x 53.1°(V)
Night vision: B&W + Enhanced Color Night Vision
Sound: Enhanced Two-Way Talk
Siren: 99 dB
Spotlight: ✓
Notification speed: Advanced
MicroSD card support: Up to 512GB
Released: 2024
Wyze Cam v3 Pro
Learn moreColors: White
Finish: Matte
Resolution: 2.5K
Night vision: B&W + Color Night Vision
Sound: Two-Way Talk
Siren: 89 dB
Spotlight: ✓
MicroSD card support: Up to 256GB
Released: 2022
Wyze Cam v3
Learn moreColors: White, Black, or Limited Edition Blue
Finish: Matte
Resolution: 1080p
Field of view: 121° (D) x 102° (H) x 54°(V)
Sound: Two-Way Talk
Siren: 80 dB
Spotlight: No (spotlight kit sold separately)
Notification speed: Standard
Released: 2020
