Wyze Lamp Socket
Wyze Lamp Socket
Power Wyze Cam v3 or v4 and upgrade to automated lighting.
Powers Wyze Cam v3/v4 by using exterior light fixture for continuous power. Converts standard bulbs into motion-activated security lights with easy installation. Dusk to Dawn scheduling automatically turns your lights on at sunset and off at sunrise.
Features
Features
- Turn Your Dumb Light Into a Smart Light
- Easy Installation
- Links Well With Others
- Motion-Triggered Lights
- Schedules and Rules
- Powers Wyze Cam v3 or v4 via USB
Specs
Specs
Wyze Lamp Socket Device Details
Color
White
Materials
Polycarbonate, Plastic
Product Dimensions
56.5mm x 56.5mm x 65mm
Weight
80 g
Socket Connector Type
E26
Power
Lamp Socket Input/Output
120V, 60Hz
Max Lamp Power
30W
USB Cable
75 cm / 30 inches
USB Ports
1 Type-A
USB Output
5W/ 5V1A, USB 1.1
Compatibility
Phone Compatibility
Android 7.0+ and iOS 12.0+
Camera Compatibility
Wyze Cam v3 or Cam v4
Connectivity
802.11 b/g/n, 2.4GHz, Bluetooth
Operating temperature
-4°F ~ 120°F (-20°C, ~ 50°C)
Weather Resistance
Not weatherproof or waterproof. Suitable for damp locations.
Certifications
ETL, CETL, UL
Wyze Cam v3 Device Details
Color
White, with black accents
Materials
Body: Polycarbonate
Lens: Glass + Plastic
Camera Dimensions
52 mm (L) x 51 mm (W) x 58.5 mm (D)
Camera Weight
98.8g
Phone Compatibility
Display
Resolution: FHD 1920x1080p
Viewing angle: 130º diagonal
Night Vision:
IR Lights
4x940 nm, 4x850 nm
Day/Night Vision
Audio
Mic
ECM
Speaker
80 db, waterproof
Simultaneous 2-way Talk
Siren
Powering methods
Power Adapter
Indoor 5v/1A
Wyze Lamp Socket (sold separately)
Outdoor Power Adapter (sold separately)
Cable
6 Feet Flat USB Cable
Sensor
CMOS Starlight Sensor
LED Indicator
Front. Red + Blue.
Connectivity
2.4GHz WiFi
Storage
Local Storage (microSD card required)
Cloud
Operating Temperature
-5°F - 113°F (-20°C - 45°C)
Weather Resistance
IP65 Weather resistant
Indoor/Outdoor
Certifications
FCC, IC, UL and IP65 Certified
Languages
English
Warranty
1-Year
In the box
In the box
Lamp Socket (only)
Wyze Lamp Socket x1
USB Cable x1
USB Cable Clips x6
Wall Anchors x6
Screws x6
Quick Start Guide x1
Lamp Socket + Wyze Cam v3 Bundle
Wyze Lamp Socket x1
Wyze Cam v3 x1
USB Cable x1
USB Cable Clips x6
Cable Clips x6
Wall Anchors x6
Camera Screws x2
Camera Wall Anchors x2
Camera Wall Plate x1
Camera Mounting Tape x1
FAQ
FAQ
What is the difference between this and other USB lamp sockets?
Users can leave the power switch on all the time, but the light doesn’t need to stay on all the time, to save power. The light will be turned on when a motion or person is detected.
How do I link multiple lamp sockets together?
Turn them all on (up to 5) within 30 seconds and they will find themselves, link, and form a group. Once they form a group, you can control each lamp socket in the group at the same time.
How many Wyze Cams can be connected?
Only 1 (one) Wyze Cam v3 or Cam v4 per lamp socket.
Does it support multiple outdoor fixture lights?
Yes absolutely. All sockets are connected wirelessly and can be turned on/off simultaneously. We currently support up to 5 lamp sockets linked in one group.
Do I need extra cables to connect it to a Wyze Cam?
No, each Wyze Lamp Socket comes with a dedicated cable to connect to a v3/v4. Do not use any other Wyze Cam v3/v4 cable.
Does it work with other Wyze cameras?
No, it does not support Wyze Cam v1/v2 or Wyze Cam Pan v1/v2 because they cannot communicate with the lamp socket. Wyze Cam Outdoor is also not supported because the USB cable is not designed to support this camera, and would compromise the camera’s built-in waterproofing.
Can I use it without a Wyze Cam?
No, you must have at least one Wyze Cam v3 or v4 connected to the lamp socket.
Is it compatible with my light fixture?
We currently support E26 sockets. (Link to E26 vs E12)
How far can my light fixtures be apart?
Up to 82 feet (25 meters) apart.
Do I always need to keep the power to the lamp socket on?
Yes, you must keep the switch that powers the lamp socket on at all times. You can use the Wyze app to turn the light on/off, set a schedule for it to turn on/off automatically, or have the light triggered by motion.
Is Wyze Lamp Socket weatherproof?
No, it is not weatherproof or IP-rated. It is UL rated for Damp Locations, and must be protected from direct rain and water.
Does it come with a lamp or light fixture?
No, neither the lamp socket or bundle includes a lamp.
Can I schedule my lights to turn on/off?
Yes, you can schedule the light to turn on/off in the Wyze app.
How does the motion-trigger feature work?
We use the advanced motion detection from Wyze Cam v3 or v4 to detect motion and turn on your light.
Flexible power for your Wyze Cam v3/v4
Skip the wiring. Harness the electricity from your outdoor light fixture to continuously power your Wyze Cam v3 or Cam v4. No more creative cord compositions. No long, ugly wires. No hassle.
Upgrade to smart lighting in seconds.
Wyze Lamp Socket and Wyze Cam v3/v4 work together to make your existing outdoor lighting smart. The socket gives the camera power and the camera gives the socket brains!
Dusk to Dawn Automation.
Illuminate your way to motion activated lights.
Set your newly smartened lights to illuminate whenever Wyze Cam v3/v4 senses motion or sound. Now your old light fixture is a cutting-edge model of sleek security sophistication!
Easily link multiple sockets for greater coverage and control.
Auto-connect up to 5 lamp sockets for Olympics-worthy synchronization of your outdoor lighting. Then schedule and control your newly smart setup from anywhere using the Wyze app.
Grab a Bundle with Wyze Cam v4
Indoor/Outdoor 2.5K Home Security Cam.
IP65 weather & dust resistance lets you see everything around your home, inside and out. See around the clock with Colour Night Vision. Add a MicroSD card to your camera to unlock local recording.
Add a Wyze Service Plan to enable cloud recording.
