Wyze Window Mount
Wyze Window Mount
Upgrade your exterior security by attaching a Wyze Cam v3/Cam v3 Pro/Cam v4, Wyze Cam OG, or Wyze Cam OG Telephoto to your window. Mount your cam on a glass surface with this accessory and enjoy a clear view free of glare or reflection.
Features
Features
Functionality
- View through a window without glare or reflection
- Turn Wyze Cam v3 into a window-mounted security camera
- Monitor outside without needing to run wiring outdoors
- Take advantage of Color Night Vision even through glass
User Cases
- Watch for package deliveries with a Wyze Cam v3 mounted on a nearby window
- Monitor important areas around your home with a - Wyze Cam v3 mounted on a nearby window
Specs
Specs
Dimensions
90 mm x 63.8 mm x 11.45 mm
Weight
1 ounce
Warranty
1 year
In the box
In the box
- Wyze Cam v3 Window Mount
*** Wyze Cam v3 SOLD SEPARATELY
FAQ
FAQ
Does the Window Mount work with other Wyze cameras?
No. The Windows Mount for Wyze Cam v3 is specifically designed for the v3 camera.
Does the Wyze Cam v3 Window Mount for Wyze Cam v3 come with a Wyze v3 Camera?
No. This is an add-on accessory for the Wyze Cam v3 which is sold separately.
