Wyze Cam v3 Garage Door Controller
View and control your garage door remotely.
Features
Features
Remotely control your garage door
See what's going on in 1080p HD video
Get notified when the garage is left open
Schedule your garage door to close
Uses your existing garage door equipment
Easy, step-by-step, in-app installation
Specs
Specs
Indoor/Outdoor Usage: Indoor
Brand: WYZE
Connectivity Technology: Wired
Recommended Uses For Product: Indoor
Room Type: Garage
Power Input: 5V DC, 2A
Wi-Fi: 802.11/b/g/n, 2.4GHz
In the box
In the box
Wyze Garage Door Controller x1
Wyze Cam v3 x1
QR Code Sticker x1
Micro USB Cable Splitter x1
Warning Placard x1
5V 2A Power Adapter x1
5V 2A Power Cord x1
Wyze Cam v3 Parts x1
Adhesive Mounting Sticker x1
Cable Clips x3
Quick Start Guide x1
Garage Door Controller Replacement Part Kit
QR Code Sticker x1
Warning Placard x1
5V 2A Power Cord x1
Cable Clips x3
FAQ
FAQ
*In order to comply with UL325 labeling requirements, this controller-only pack is intended to be used as a replacement part with the Wyze Cam v3 you previously received when you purchased the Wyze Cam v3 + Garage Door Controller Bundle. While any Wyze Cam v3 will technically work with the Garage Door Controller Unit, a Wyze Cam v3 purchased separately does not include the required garage door warning labels. **We do not recommend using this product as the sole method for accessing your home.
Get notified when your garage door is left open.
Forgot to shut the garage door?
We'll notify you if your garage door was left open or if someone is opening or closing it.
Know when your garage door was opened or closed.
Easily find the exact time of day your garage was opened, left opened, or closed.
View. Record. Repeat.
Stream 1080p HD video in full color, even at night, with the included, award-winning, Wyze Cam v3.
Get notified when motion is detected, record 24/7 with local microSD storage, even set off a mini-siren to scare off intruders.
Scheduling and automation.
Schedule your garage door to close automatically if you accidentally left it open and create automations that make life easier.
We did our homework...
Here's everything critics disliked about other brands of smart garage door controllers.
Competitor Who Shall Not Be Named #1
❌ Extra $120 for camera
❌ Requires bolting a bracket onto your ceiling
❌ Not compatible with Amazon Alexa
❌ Battery sensor required
Competitor Who Shall Not Be Named #2
❌ Unintuitive installation
❌ No camera option
❌ Extensive wiring required
❌ 2-part door sensor
Competitor Who Shall Not Be Named #3
❌ Expensive
❌ No camera option
❌ Frustrating setup
❌ Pairing issues with door sensors
❌ Parts in the box don't match
and we listened.
✅ Award-winning Wyze Cam v3 included
✅ No complicated wiring
✅ No battery powered sensors
✅ No bolting brackets or screws required
✅ Alexa and Google Assistant compatible
