Wyze Cam Floodlight Plug-In Mount
Simple plug-n-play installation. No junction box needed.
Low stock
Say goodbye to the complexity and cost of installing a junction box. Go with an easy, plug-n-play floodlight solution instead.
Features
Features
Easy-to-install, plug-n-play floodlight solution
No junction boxes needed
Compatible with all Wyze floodlight camera models (v1, v2, and Pro)
20ft outdoor SJTW weather-resistant power cord Available in both black & white colorway
Streamlined & consistent design (looks clean and sleek)
Specs
Specs
Colors: White and Black
Outdoor safe: Yes
Operating Temperature: -22°F to 122°F
Input: 110 - 120V AC
Power Cord Rating: SJTW (Hard service, thermoplastic cable, S: service, J: junior, T: thermoplastic, W: weather-approved)
In the box
In the box
1x Wyze Cam Floodlight Plug-in Mount
1x Floodlight Pro mounting kit (silicone ring, long screw)
1x Mounting screw kit
1x Foam tape
1x Quick Start Guide
FAQ
FAQ
Q: What is a Wyze Floodlight Cam Plug-in Mount?
A: Wyze Floodlight Cam Plug-in Mount is an accessory that offers a simple installation solution for all Wyze floodlight models–no junction box required. Use it to install any Wyze Cam to an outdoor GFCI power outlet.
Q: What's unique about this plug-in mount?
A: Our Wyze Cam Floodlights require an outdoor junction box for installation. But many homes today lack multiple exterior junction boxes, and hiring a licensed electrician to install one can average ~$650.
With a Wyze Floodlight Cam Plug-In Mount, you don't need a junction box at all. You can install your Wyze Cam Floodlight near any outdoor-rated GFCI power outlet, simplifying installation and reducing the cost.
Q: Which Wyze floodlights are compatible with Wyze Floodlight Cam Plug-In Mount?
A: All Wyze Cam Floodlight models are compatible with this mount, including Wyze Cam Floodlight v1, v2, and Pro. The mount is not compatible with any non-Wyze floodlight camera.
Q: What colors are available for Wyze Floodlight Cam Plug-In Mount?
A: The mount is available in matte white and matte black to seamlessly match our existing Wyze Cam Floodlight devices.
Q: How long is the power cord for the plug-in mount?
The included outdoor power cord is 20 feet long.
Q: Is Wyze Floodlight Cam Plug-in Mount weather-resistant?
A: Yes, the plug-in mount and it's attached power cord are both outdoor-rated. It is suitable for outdoor environments when properly installed.
Is the 2-prong plug for the plug-in mount safe for outdoor use as well?
Yes, Wyze Floodlight Cam Plug-In Mount is safe for outdoor use as long as it is connected to a GFCI outdoor power outlet with a power output of 110-120V AC.
What are the power input requirements for the plug-in mount?
Wyze Floodlight Cam Plug-in Mount requires a power input of 110-120V AC. This is standard for most residential homes in the US.
Should I connect the plug-in mount to a power source before installing the floodlight camera?
No, DO NOT power the plug-in mount until the floodlight camera is completely wired and properly installed on the mount.
A flexible power solution for all Wyze Cam Floodlights.
Ditch the shock and zap (unless you're into that sort of thing). If you can plug in a cable, then you can enjoy the security of a Wyze Floodlight. No more scary junction boxes and expensive electricians.
Easy to install. No junction box needed.
Say goodbye to the complexity and cost of a junction box. No need to hire electricians and handy people, or cut giant holes into the exterior of your home.
Put it right where you need it.
Free thyself from the shackles of non-ideally-located junction boxes! The durable 20ft. cable reaches outdoor-rated outlets with ease. A velcro strap is included for clean cable management.
Seriously, watch how easy it is to install.
Compatible Wyze Cam Floodlights
Color: White
Camera resolution: 1080p
Lighting: 2 floodlight heads, 2600 lumens
AI Detection: People, Pets, Vehicle, and Package (with Cam Plus plan)
Wi-Fi: 2.4Ghz
Ambient light: No
Motion warning: No
Status: Retired (see the new v2)
Wyze Cam Floodlight v2 NEW
Shop nowColor: White/Black
Camera resolution: 2K
Lighting: 2 floodlight heads, 2800 lumens
Wi-Fi: 2.4Ghz
Ambient light: ✓
Motion warning: ✓ (with Cam Plus plan)
