900+ ratings on Amazon
Wyze Battery Cam Pro
Protect anywhere. See everything in 2.5K HDR.
Low stock
- 2.5K HDR Video Resolution
- Wire-Free, No Hub required
- Integrated Spotlight & Siren
- Radar + PIR Motion Detection
- Removable, Rechargeable Battery Packs**
- IP65 Weatherproof
Optional compatible accessories:
- Wyze Removable Battery Pack
- Wyze Solar Panel (when paired w/ a USB-C adapter)
- Wyze Charging Dock
Features
Features
Outdoor/Indoor
No Wires - 100% Wire-Free and Battery Powered
No Hub or Base Station Required
Place it anywhere with hassle-free setup
2.5K HDR Video with Color Night Vision Capture
Radar + PIR Motion Detection - Double the sensors for more accurate detections
Removable battery packs to avoid downtime
Specs
Specs
Color & Materials
Color: White or Black
Finish: Matte finish
Mechanical Structure: PC plastics
Camera Lens: Optical glass
Additional Details
Camera Weight (lbs): 0.94
Dimensions (Inches): 2.5 x 1.8 x 3.5
CPU Speed: 500 MHz
Memory: 128 MB RAM
Integrations: Alexa, Google Assistant, IFTTT
Mounting Methods: 1/4” - 20 standard
Wall mount: Included (short mount)
Wall Mount Dimensions: 2 in x 2 in x 2.2 in
Wall Mount Weight: 1.5 oz (44 g)
Drywall anchors
Wall anchors
Length: 28.7 mm
Width: 5.5 mm
Drill bit size: 7/32
Screw Assembly
Philips screws
Length: 29.5 +- 1 mm
Width: 2.9 mm
Drill bit size: 3/64
Certifications: FCC, IC
Power
Power Cable Length
USB-A to USB-C Cable, 0.5m
Power Adapter: 5V, 2A (NOT INCLUDED)
Battery Pack
Capacity: 6200mAh
Charging Time: Approximately 9 hours
Battery Life: Up to 6 Months
Technology: Li-Ion
Connector: USB-C
Image Sensor: CMOS-Starlight Sensor (2560 x 1440)
Lens: F1.6
Digital Zoom: 8x
Field-of-View: 134°(DFOV), 108°(HFOV), 56°(VFOV)
Night Vision: 2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)
Video Encoding: H.264
Video FPS
Daytime: 15 FPS
Nighttime: 15 FPS
Video Resolution: 2560 x 1440 (2.5K)
Connectivity & Compatibility
Bluetooth: BLE 5.1
Wi-Fi: 2.4 GHz and 5 GHz, 802.11a/n/g/b
Phone Compatibility: Android 7.0+, iOS 14.0+
Audio
Microphone: MEMS Digital Mic
Two-way Audio
Built-in speaker and microphone
Noise and echo cancellation
2-way Simultaneous
Siren, 100 dB SPL @ 0.1m
Weather & Temperature
Weather Resistance
Indoor and Outdoor (IP65)
Operating Temperature: -20°C to +50°C (-4°F to +122°F), Humidity < 90%
Storage Temperature: -40°C to +50°C (-40°F to +122°F), Humidity < 90%
Storage
Local Storage: Supports up to 256 GB microSD cards
Cloud Storage: Record to the cloud with Cam Plus
In the box
In the box
Wyze Battery Cam Pro x 1
Battery Pack x 1
USB-C Cable x 1
Wall Mount x 1
Screw Assembly x 3
Quick Start Guide x 1
Note: Power Adapter is not included
FAQ
FAQ
Q: Do you need a base station for it to work?
A: No, you can set up your camera directly on your 2.4 Ghz or 5 GHz home Wi-Fi network and start using your camera in minutes.
Q: Does it work with the Wyze Base Station?
A: No, it’s not compatible with Wyze Base Station.
Q: How long will the battery last?
A: With normal use, the Battery Cam Pro’s battery should last up to 6 months before recharging. Alternatively, you can purchase additional batteries to swap them out as needed.
Q: What are the mounting options?
A: You can use the provided standard 1/4”-20 metal wall mount or purchase our longer universal metal mount accessory for ceiling mounting. It's not compatible with the Wyze Cam Outdoor magnetic base mount.
Q: Will I be able to continuously record to a micro SD card like with Wyze Cam v3?
A: No, it doesn't support continuous recording to micro SD cards.
Q: How long does it take to charge the camera battery from 0% to 100%?
A: It takes approximately 9 hours to fully charge the battery.
Q: How long does it take to charge the camera battery from 0% to 100% using the Wyze Charging Dock?
A: It takes approximately 8 hours and 30 minutes to fully charge the battery.
Q: Can I use the camera while it’s charging?
A: Yes, you can use the camera normally while it's charging.
Q: Will there be a solar panel option?
A: Yes, you can purchase the Wyze Solar Panel with an included USB-C adapter cable. Alternatively, you can purchase a USB-C cable if you bought the original solar panel.
Q: What if someone steals my camera?
A: You will not lose all of your recorded videos if someone steals your camera. You can use the footage as evidence when filing a police report.
Q: Is Wyze Battery Cam Pro compatible with Wyze Web View?
A: Yes it is.
Q: Is Wyze Removable Battery Pack accessory the same as the battery pack included in the box for Wyze Battery Cam Pro? If so, is the battery capacity specification for this 6200 mhA?
A: Yes, it is the same battery pack with 6200mhA capacity.
Q: Can I use a microSD card with Wyze Battery Cam Pro?
A: While continuous or motion-only local recording won’t be available on Wyze Battery Cam Pro at launch, those features are coming soon. Wyze Battery Cam Pro is compatible with microSD cards in the following sizes and formats: 8 GB, 16 GB, and 32 GB microSD cards in FAT32 format; Up to 256 GB microSD cards in exFAT format
Q: Is Wyze Battery Cam Pro waterproof?
A: Wyze Battery Cam Pro is not completely waterproof - it won’t work underwater! But it is IP65 weather resistant. This means that it’ll keep doing its job in sunshine, snow, or a summer storm.
Q: What is the range of motion detection?
A: Wyze Battery Cam Pro can detect motion up to 30 feet away. Refine the range further with a customized detection zone or adjust the detection sensitivity.
Q: Can I use this camera indoors?
A: Yes, you can use this camera both outdoors and indoors.
Feature release: Local recording (with a MicroSD card) is now available for Battery Cam Pro
Radar + PIR = A motion detection superstar.
Double the motion sensors means double the "Gotcha!" Radar and PIR combine for earlier and more precise detections. Set custom detection zones in the Wyze app for location specific notifications.
Get even smarter detections with Cam Plus.
Integrated light. Intruder flight.
Light up potential intruders with 150 lumens of LED, motion-activated light. You can also manually control the spotlight in the Wyze app for extra security while you’re walking the dog at night.
More Pro features you'll love.
IP65 Weather Resistance
Drip. Splash. Plop. No matter the weather, this camera cannot be stopped.
Dual-band Wi-Fi
Enhanced Two-Way Audio
Talk (or yell) to anyone easily with a built-in microphone and speaker.
The power to protect.
Wyze Battery Cam Pro has flexible power & mounting options.
Removable battery packs.
Taking down your camera to charge it is as tedious and wearisome as cleaning an airport urinal. Easily hot-swap battery packs and eliminate security downtime.
Ready power with Wyze Battery Charging Dock.
Charge up to two battery packs at once with Wyze Battery Charging Dock. Sold separately.
It's here! Battery Cam Pro can locally record to a microSD card.
Never miss a moment and record motion events locally to a microSD card, no subscription required. Enabling this feature impacts battery life.
Wyze microSD Card
Record 24/7 continuous footage.
