Wyze Removable Battery Pack
Low stock
Pack a punch with a replacement 6200mAh rechargeable battery designed for the Battery Cam Pro and Duo Cam Doorbell.
Features
Features
· Up to 6 months on a single charge
· Built-in USB-C charge port
· Built-in indicator lights (One Solid Green Light: The battery is charging; Two Solid Green Lights: The battery is fully charged)
· Compact and easy to store
Specs
Specs
Model Number: WBAT2
Weight: 3.9 oz (110g)
Dimensions: 2.9 in x 1.6 in x 0.9 in (75 mm x 40mm x 22 mm)
Color: White
Battery Capacity: 6200 mhA
Output Voltage: 3.6 V
Input Voltage: 5V DC
Charging Current: 800 mA
Battery Type: Lithium Ion
Operating Temperature: -4℉ to 122℉ (-20°C to 50°C); Humidity < 90%
Charging Temperature: 32℉ to 122℉ (0°C to 50°C); Humidity < 90%
Connector: USB-C
Fully Charging Time: Approximately 9h at 25°C/77℉
In the box
In the box
· Wyze 6200 mhA Battery Pack x1
Note: Charging cable not included
FAQ
FAQ
Q: How long does it take to charge the camera battery from 0% to 100%?
A: It takes approximately 9 hours to fully charge the battery.
Q: Does this battery pack work with a charging dock?
A: Yes, you can use it with the Wyze Charging Dock.
Q: How long does it take to charge the camera battery from 0% to 100% using the Wyze Charging Dock?
A: It takes approximately 8 hours and 30 minutes to fully charge the battery.
Q: Can I charge the battery with a PD charger?
A: Yes, you can use a PD charger to charge the battery pack. However, please note that it will not charge faster due to the battery charging IC design.
Q: Are Wyze Battery Pack and Wyze Battery Charging Dock compatible with any devices other than Wyze Battery Cam Pro and Wyze Duo Cam Doorbell?
A: No. They are only compatible with the Battery Cam Pro and Wyze Duo Cam Doorbell.
