1 of 5
Wyze Battery Charging Dock
Low stock
$26.99
Double the fun! Charge two batteries simultaneously with the Dual Battery Charging Dock.
⚠️ Compatible with Wyze Removable Battery Pack. Battery packs not included with charging dock.
Features
· Charge two batteries simultaneously
· Extended reach and unrestricted placement with a 6ft charging cable
· Compact and convenient
Specs
Model Number: WYZEDBCD
Weight: 2.75 oz (78 g)
Dimensions: Charging Dock: 2.6 in x 2 in x 1 in (58 mm x 52 mm x 26 mm); Power Adapter: 42 mm x 40 mm x 23 mm
Color: White
Operating Temperature: +50℉ to +104℉ (+10°C to +40°C); Humidity < 90%
Power Adapter Input: AC100-240V, 50/60Hz
Power Adapter Output: DC5V, 2A
USB Cable: USB-A to USB-C
Power Cable Length: 6 ft (1.8 m)
Fully Charging Time: Approximately 8.5h at 25°C/77℉
In the box
· Wyze Battery Charging Dock x1
· Adapter Cable x1
· Power Adapter x1
Note: Battery pack not included
FAQ
Q: How do I know when the batteries are fully charged using the charging dock?
A: The two charging indicator lights on the battery will both turn on once it is fully charged.
Q: Can the charging dock charge both batteries simultaneously?
A: Yes, it can.
Q: How long does it take to fully charge a single battery using the charging dock?
A: It takes approximately 8 hours and 30 minutes to fully charge a single battery pack.
