2,100+ ratings on Amazon
Secure Entry Essentials Bundle
Access with your fingerprint.
- 1x Wyze Cam Pan v3
- 1x Wyze Lock Bolt
Low stock
Make losing your keys a thing of the past with the Secure Entry Essentials Bundle! Unlock your door instantly with Wyze Lock Bolt’s lightning-fast fingerprint reader and sleek backlit keypad—plus, it auto-locks if you forget. Keep an eye on things inside and out with the Wyze Cam Pan v3, a weather-resistant 360° pan and 180° tilt camera that captures every angle. Stay secure and in control with this playful, smart setup that makes home safety effortless and fun.
*For safe outdoor use, Pan v3 requires a Wyze Outdoor Power Adapter (sold separately).
Features
Features
Wyze Lock Bolt
- Bluetooth-Connected Smart Lock
- 0.5-second Fingerprint Unlock
- Anti-Peep Backlit Keypad
- Emergency USB-C Charging
- Pickproof and IPX5 Weatherproof
- View Lock/Unlock History in the Wyze App
- Auto-Lock Timer
- 20-Minute Installation
Wyze Cam Pan v3
- Indoor/Outdoor: Wyze Cam Pan v3 is a wired pan-and-tilt video camera with an IP65 rating, so you can confidently install it and track the action, whether outside in the rain or inside in the nursery.
- Pan, tilt, and zoom in full 1080p HD: Livestream from anywhere and control remotely using the Wyze app to check any part of the room, fast. Or monitor a room automatically, in a constant pattern, by setting 4 predefined waypoints. Panning has a 360° left/right rotation range and tilting has a full 180° vertical up/down range.
- Motion Tracking: Go beyond motion and sound alerts. Wyze Cam Pan doesn't just detect motion, it locks onto it - unfriendly, friendly, or furry - automatically following the action all around the room.
- Never miss a moment: Cam Plus records unlimited full motion whenever it's detected. Feel more secure knowing your Wyze Cam with 3 months Cam Plus will capture the full story.
- Smarter alerts: Wyze Cams come with motion detection alerts, but they can't detect people, packages, pets, or vehicles. Cam Plus gives you the option to only receive alerts of your interest, which can reduce notifications by up to 70%.
Specs
Specs
Wyze Lock Bolt Product Specs
- Color options: Matte Black and Satin Nickel
- Weight: 2.75 lbs
- Power Source: 4x AA Batteries (included)
- Battery Life: 10-12 months
- Communication: Bluetooth 5.0
- Range: 16 ft
Wyze Cam Pan v3 Specs
Color & Materials
- Color: White
- Finish: Matte
- Body: Polycarbonate
- Lens: Glass + plastic
- CPU: 1.5 GHz
- Image Sensor: 1/2.9'' CMOS
- LED indicator: Front. Red + Blue
- Night Vision: 4 IR LEDs (850 nm)
Dimensions & Weight
- 124mm (H) x 60mm (W) x 63mm (D)
- 11.29 oz (320 g)
Video
- Video Encoding: H.264
- Video FPS: Daytime - 20 fps; Nighttime - 15 fps
- Video Resolution: 1920 x 1080 (1080p)
View Range
- 360° horizontal, 180° vertical
Field-of-view
- 120° FOV
Door Compatibility
- Thru hole diameter on door: 2-1/8”
- Backset: 2-3/8” or 2-3/4”
- Door thickness: 1-3/8” or 1-3/4”
- Deadbolt diameter: 1”
- For more details check our Measuring Template
Wyze Cam Pan v3
Storage
- Supports up to 256 GB microSD in ExFAT format
Weather & Temperature
- Operating temp: -20°C - 50°C (-4°F - 122°F)
- IP65 Water Resistance
Certifications
- FCC, IC, UL, TSCA, IP65
Language
- English
Warranty
- 1-Year
Important note
- Wyze Cam Pan v3 comes with one of two versions of the Mounting Kit, as shown here. The Mounting Kit pictured on the product packaging is currently of the original design but the package could contain the new design. Both mounts allow you to install the Pan v3 upside down.
In the box
In the box
Wyze Lock Bolt
- Interior Lock Component
- Exterior Keypad Component
- Mounting Plate
- Mounting Parts
- AA Batteries
- Measuring Template
- Quick Start Guide
Wyze Cam Pan v3
- Wyze Cam Pan v3
- 6' micro USB Cable
- Power Adapter
- Mounting Kit (Please note: There has a been change in our mounting bracket's design. Customers may get either design regardless of the design on the packaging. However, this shouldn't affect functionality. Learn more here.)
- Quick Start Guide
FAQ
FAQ
Keyless entry. A fingerprint away.
Gone are the days of fumbling for keys. Enter your home quickly and securely with just a tap on the ultra-fast fingerprint sensor.
Fingerprint Recognition in 0.5s
Unlocks in Under a Second
Stores Up to 50 Fingerprints Locally
Luxurious backlit keypad.
Wyze Lock Bolt's exterior is crafted from solid metal for maximum security. Each button on the keypad is backlit for easy viewing at night.
Designed to blend in, beautifully.
Crafted to compliment your interior design.
Luxurious metal design to match any exterior.
Fully pick-proof and weatherproof.
Wyze Lock Bolt is completely pick-proof by removing the need for keys. It’s also built tough enough to withstand the elements with IPX5 weatherproofing.
Up to 12 months of battery life.
Wyze Lock Bolt's 4 AA batteries last up to a year and are easily replaceable. If the battery life is low, the indicator will flash red reminding you to replace them.
If the batteries die, the USB-C port allows for a brief charge for you to enter your access code.
Incredible smart features in the Wyze app
View the lock/unlock history.
See who stopped by in the Wyze app. You can even view how it was unlocked, the exact time, and if there were any failed passcode attempts.
Create access schedules.
Worried about giving out access codes to your home? Use auto-expiring codes so you never have to worry about temporary guests entering without permission. Set the day/time the code expires and never think about it again.
Take Wyze Cam Pan v3 outside.
Not just an indoor cat anymore. With IP65 water resistance* you can automatically patrol your property in any weather.
Automatic motion-tracking.
Those cans never knew what hit them, but Pan v3 did. That's because it detects motion, follows, and records it automatically. Its upgraded tracking motor is quieter than a gossiping church mouse, so it won't wake napping babies or startle pets.
Privacy Mode.
You just sat down to binge watch that show. You also decided that pants were optional today.
Two-Way Audio.
Watched a black and white movie recently? We haven't either, because every detail matters. That's why we've made Color Night Vision standard across all of our security cameras with Starlight Sensor.
$150 Competitor Cam
Wyze Cam Pan v3
