1 of 17
Secure Entry Advanced Bundle
The key is the palm of your hand.
What's in this bundle
Low stock
$225.98 $249.96
Wyze Palm Lock offers secure, contactless entry with advanced palm vein recognition technology for fast, key-free access. Easily manage entry through a numbered keypad with access codes, control your lock remotely via Wi-Fi, and enjoy up to 6 months of battery life. For added reliability, it also includes a manual key option and auto-lock functionality for total peace of mind.
Wyze Cam Pan v4 enhances your security coverage with a redesigned 360° pan and 180° tilt camera, providing a full view of any space. Built to withstand the elements, it’s IP65 weather-resistant and ideal for indoor or outdoor use, ensuring that every angle is protected—day or night.
Together, these devices deliver intelligent access and comprehensive monitoring for your home or business—all managed seamlessly from anywhere.
Features
Wyze Palm Lock
- Palmprint Unlock - Unlock your door in under a second—no touch, no hassle. Just wave your hand from 3-7 inches away and Wyze Palm Lock recognizes your unique palm veins instantly.
- Dual Battery System - Stay powered for up to 6-months using the main battery with a backup battery that lasts 1–2 weeks. While you charge the main, the backup keeps everything running—and you’ll get reminders if you forget to put the main battery back in.
- Auto-Lock - Never wonder if your door’s locked again. Wyze Palm Lock automatically locks once it detects the door is fully shut, thanks to smart gyroscope technology.
- Motion-Activated Wake-Up - Your lock is ready when you are. Wyze Palm Lock uses radar to detect motion and wake up, with customizable range to balance speed and battery life.
- Mechanical Key Backup - Prefer old-school backup? No problem. Wyze Palm Lock includes two mechanical keys and a damping cover so you’re always in control.
- Wi-Fi Control & Alerts - Control your lock from anywhere with the Wyze app and get real-time alerts. Switched routers? No reset needed—just update your Wi-Fi connection in the Wyze app using the new network update feature.
- Smart Keypad + Anti-Peep - Use up to 50 access codes for family, friends, or guests. Anti-peep protection lets you add random numbers before or after the real code for extra security.
- Emergency USB-C Charging - Low battery? Just plug in via USB-C to power up instantly and unlock—no need to worry about being stuck outside.
- Weatherproof Durability - Rain or shine, Wyze Palm Lock is built to last with IP53-rated weather resistance. Security that stands up to the elements.
- Tamper Alerts & Siren - After 5 failed unlock attempts, the lock disables for 5 minutes and triggers a siren. You’ll also get an instant alert if someone tries to force it open.
- Wyze Doorbell Integration - Pair with Wyze Video Doorbell Pro, Wyze Video Doorbell v2, or Wyze Duo Cam Doorbell to see who’s at the door and unlock it—all in one app.
- Works with Alexa & Google Home - Control your lock with your voice. Ask Alexa or Google Assistant to lock or check the status of your door anytime.
Wyze Cam Pan v4
- 4K Ultra HD Resolution with Color Night Vision
- 360° Pan and 180° Tilt Coverage
- AI-Powered Object Tracking
- Dual-Band Wi-Fi
- View from anywhere in the Wyze app
- Indoor/Outdoor IP65 Weather Rating
- Local MicroSD storage up to 512GB
Specs
Wyze Palm Lock Specs
Colors & Materials
- Model: WPLCK1
- Finish: Matte
- Color: Black
- Materials - Frame: Aluminum Alloy and Steel
- Materials - Panel: Tempered Glass
Dimensions
- External Assembly: 6.14 x 2.89 x 1.28 in (156 x 73.5 x 32.5 mm)
- Internal Assembly: 7.16in x 2.93in x 1.18in (182mm x 74.5mm x 30mm)
Weight
- 4 lbs (64 oz)
Wyze Cam Pan v4 Specs
- Color & Materials
- Color: White
- Finish: Textured Matte
- Materials: Body: Polycarbonate, Lens: Glass + plastic
Dimensions
- Dimensions (H,W,D): 4.91in x 2.48in x 2.17in (124.7mm x 63mm x 55mm)
- Weight: 274.8 g (0.61 lbs)
Video
- Resolution: 4K/8MP Resolution (3840 x 2160)
- Field of View: 105.4° (D), 88° (H), 46° (V)
- Pan Tilt Range: 360° (H) x 180° (V)
- Video FPS: Daytime - 20 fps, Nighttime - 15 fps
- Digital Zoom: 8x
Audio
- Built-in 100dB speaker & microphone
Power
- 6 ft (1.8 m) Flat Type-C to USB-A
- Power adapter: Input - 110-240V (AC), Output - 5V/2A
Addition Details
- Night Vision: 2 IR LEDs (850 nm) + White Spotlight LED (60 Lumen)
- Color Night Vision
Sensor
- Image sensor: 1/2.7' CMOS
Storage
- Supports up to 512GB local storage (microSD card required - sold separately)
- Cloud (AWS) with Wyze Security Plan
Temperature
- Storage Temperature: -4°F-122°F (-20°C-50°C)Operating Temperature: -40°F-158°F(-40°C-70°C)
Weather Resistance
- IP65 Weather Resistant
- Indoor/Outdoor* compatible
Note: *Requires Wyze Cam Universal Outdoor Power Adapter (sold separately, coming soon)
Connectivity & Compatibility
- Wi-Fi: 802.11a/b/g/n/ac/ax, 2.4/5 GHz, Wi-Fi 4/5/6
- Phone app support: Android 10.0+, iOS 16.0+
- Integrations: Alexa, Google Assistant, IFTTT
Languages: English
- Warranty: 1-Year
In the box
Wyze Palm Lock
- 1x Wyze Palm Lock
- 1 x Exterior Assembly
- 1 x Interior Assembly
- 1x Mounting Plate
- 1x Deadbolt
- 1x Strike Plate
- 1x Dust Box
- 1x Main Battery
- 1x Backup Battery
- 1x Silicone Plug
- 1x Drilling Template
- 1x Quick Start Guide
- 2x Mechanical Keys
- 4x Wood Screws
- 3x Interior Panel Screws
- 4x Mounting Screws
Wyze Cam Pan v4
- Wyze Cam Pan v4 x1
- 6' USB Type-C to Type A Cable x1
- Power Adapter x1
- Mounting Bracket & Kit x1
- Quick Start Guide x1
FAQ
  • Touchless Palm Scan Unlock
  • 6 Entry Methods + Wi-Fi Control
  • No Down Time with Dual Battery System
  • Replaces Existing Deadbolt
1 of 4
Highly secure, contactless biometric tech identifies you based on the unique pattern of veins beneath the surface of your palm. Just hover your palm near the reader, and voilà, the door unlocks. It’s like a secret handshake with your front door.
Access for all types of hands.
Palm vein recognition is more accurate than fingerprints and is reliable despite different hand conditions.
  • Palm Scan
  • Access Codes
  • App Control
  • Manual Key
  • Voice Control
  • Manual Latch
1 of 6
Numbered keypad with access codes.
A bright, numbered keypad illuminates with a simple tap. Set and store up to 50 unique access codes, or create one-time guest passcodes that expire on a schedule.
Dual Battery System
The main is a removable lithium-ion battery that provides up to 6 months of battery life. A secondary backup battery keeps things running for up to two weeks while you charge the main.
Peace of mind with auto lock.
A built-in gyroscope detects the angle and movement of the door in real time. Once it senses the door has closed then it automatically locks, preventing false or jammed locks.
Featuring anti-peep technology.
With anti-peep technology, you don't have to worry if someone watches you enter your code.
Simply add extra digits before or after your code and Wyze Palm Lock will still unlock.
Discreet manual lock and key option.
Still yearning for the comfort of a traditional key? We got you covered. Simply slide down the damping cover and manually unlock the old-fashioned way (set of keys included).
Hey Luke, who's your deadbolt daddy?
OK, maybe don't ask him that. Instead, see what this modern day Skywalker had to say when we asked him about Wyze Palm Lock.
IP53 weather-resistant & BHMA certified.
Backed by the Builders Hardware Manufacturers Association, this lock has been tested, slammed, twisted, and splashed thousands of times to make sure it can handle real life. It meets rigorous standards for security, durability, and performance. It’s not just smart, it’s strong.
BHMA Logo
Backed by industry-best security features.
  • Palm Vein Recognition
    Unlike fingerprints, palm vein pattern is an internal characteristic of the human body and cannot be copied or forged.
  • Hardware Encryption
    Your palms and passcodes are encrypted and stored locally on the lock so no one can access your data.
  • Security Siren & Alerts
    An alarm sounds from excessive incorrect unlock attempts, and if you leave the door open (customizable in the Wyze app).
1 of 3
Watch and learn. It's super easy to install.
Wyze Palm Lock is compatible with almost all exterior doors and replaces your existing deadbolt lock in about 20 minutes. Watch our unboxing and install demo below.
Take Wyze Cam Pan v3 outside.
Not just an indoor cat anymore. With IP65 water resistance* you can automatically patrol your property in any weather.
Automatic motion-tracking.
Those cans never knew what hit them, but Pan v3 did. That's because it detects motion, follows, and records it automatically. Its upgraded tracking motor is quieter than a gossiping church mouse, so it won't wake napping babies or startle pets.
Privacy Mode.
You just sat down to binge watch that show. You also decided that pants were optional today.
Two-Way Audio.
