The perfect angle for every porch layout.
The only acceptable wedge that should come between you and Doorbell v2! Perfect for angled door frames and porches with stairs, this accessory allows you to easily adjust the viewing angle for maximum coverage. Goodbye to blind spots, hello to a superior home security experience.
Features
Features
Specs
Specs
Color: Black
Material: Plastic
Compatible with: Doorbell v2 only
Product warranty: 1 year
In the box
In the box
7.5° Vertical Bracket ×2
Horizontal 15° Bracket ×1
Short Screws x6
Quick Start Guide ×1
FAQ
FAQ
Q: Will this work with Duo Cam Doorbell, Video Doorbell Pro, or the original Doorbell v1?
A: No. This wedge kit is designed to fit the Doorbell v2 and the wedge that comes with the camera.
Q: Do I have to use all the pieces in this wedge kit?
A: Nope. You only need to use what's needed to angle the Doorbell v2 to get the best view.
Compatible with Doorbell v2
This wedge kit is only compatible with Doorbell v2.
Stackable, so it's flexible
Use one wedge piece or use them all. Get the perfect angle for your porch.
Weather resistant, heavy duty plastic
We designed this to last outside just like your Doorbell v2.
Quick installation
The hardest part will be figuring out angle that makes you happy.
Wedges for the perfect angle
Not all porches are made the same. Some have steps, while others have slanted sidings. Wedge Kit was designed to give every Doorbell v2 owner the perfect view so they don't miss a thing.
Thick heavy duty plastic
We don't cut corners on our cameras, and the same is true of our accessories. We used thick, weather-resistant plastic on this kit, so you can have it last for years.
Designed to work with Wyze Doorbell v2
Crystal-clear video, color night vision, and two-way audio, plus an extra layer of security with voice deterrents.
Wyze Video Doorbell v2
2K porch protection with local microSD storage.
Answer your door from anywhere with our clearest and most capable wired video doorbell yet. Wyze Video Doorbell v2 gives you 2K video and local microSD storage, so you can capture every moment in more detail than ever. Plus, get video doorbell essentials like two-way audio, real-time alerts, and motion-activated voice deterrence.
