Wyze Universal Wi-Fi Chime
No complicated wiring needed, just plug-in and know.
Easily set up your home's doorbell with the Wyze Universal Wi-Fi Chime. No complicated wiring required—just plug it in and stay informed. Know exactly when someone rings your doorbell (or tries to ditch).
With smart Automations, you can even have it chime when your camera detects a person on your kitchen's cookie cam. Never miss a ding-dong again with this convenient, fuss-free chime.
Features
Features
Specs
Specs
Color: Black
Materials: Plastic
Dimensions: 81 x 53 x 38 mm
Speaker: φ40mm
Wi-Fi: IEEE802.11 b/g/n 2.4 GHz
Power Input: 10-24V AC, 10VA 60HZ
Operating Temperature: -4°F ~ 122°F (-20°C ~ 50°C)
Note: Indoor use only
Bluetooth BLE 5.0
Works with IFTTT, Hey Google, and Alexa
Certifications: FCC, IC, UL, CP65
In the box
In the box
1x Wyze Wi-Fi Chime1x Quick Start Guide
FAQ
FAQ
Q: How many tones does the Wi-Fi Chime have?
A: You have 17 different tones.
Q: Can I use more than one chime in the same household?
A: YES! Put one on different floors or sides of the house so you never miss an alert.
Works with all Wyze Cams
Compatible with all Wyze Cams and doorbells.
17 different tones
Choose one tone or switch it up depending on the situation.
Easy installation
Compatible with your everyday wall socket. No need to stress about batteries or electrical wiring.
Connect multiple devices
Why settle for one chime when you can have a bunch! Pair up those chimes with cams for full coverage.
Ding dong from anywhere. Hear alerts exactly where you want in your home. Built-in Wi-Fi enables you to trigger audio alerts with all Wyze Cams and Doorbells.
Get chime alerts when a person is detected, even if they don't ring.
We all expect our chimes to ring when our doorbell cameras are pressed. But you can do so much more! Setup an Automation inside the Wyze app that chimes you when your camera detects a person.
Works with all Wyze cameras... especially with these amazing Video Doorbell Cams.
Duo Cam Doorbell NEW
FOV: Top: 132 x 100° / Bottom: 121 x 60°
Resolution: Top: 2K / Bottom: 1080p
Compatible Chime: Wyze Wi-Fi Chime
Installation: 3M adhesive or screw mounting
Local Storage: Supports up to 256 GB
Mounting Location: Anywhere
Power: Wyze Removable Battery Pack or Wired (AC 16-24 V)
Video Doorbell Pro
FOV: 150 x 150°
Resolution: 1440p+
Compatible Chime: Wyze Chime Pro
Local Storage: N/A
Power: Rechargeable Built-In Battery or Wired (AC 16-24 V)
Video Doorbell v2
FOV: 135 x 103°
Resolution: 2K
Compatible Chime: Existing mechnical chime
Installation: Screw mounting
Mounting Location: Requires existing wiring
Power: Wired (AC 16-24 V) only
