1 of 7
Wyze Scale X Butterfly
Bluetooth Smart Scale with Extended Battery
Color
$54.99
Wyze Scale X measure 13 body composition metrics and share the scale with up to 8 users. Use baby, pet, luggage, and pregnancy mode to go beyond yourself. Wyze Scale X has a premium design with full-surface glass sensors and up to 22 months of battery life. Oh, and it syncs with popular fitness apps so you can keep all your metrics where YOU want them.
Features
- Measures 13 Body Composition Metrics
- Baby, Pet, Luggage, Pregnancy Modes
- Full-Glass ITO Sensors
- 22-Month Battery Life
- Share with up to 8 People
- Syncs with Popular Health Apps
- Heart Rate Measurement in Wyze App
Specs
Color & Materials
- Color: Black or White
- Weight sensors: 4 independent leg sensors
- Surface: ITO coated glass
Weight
- 3.96 lbs (1.80 kg)
Dimensions
- 11.8 in x 11.8 in x 1.18 in
Power
- Battery-Powered: 4 x 1.5V AAA Batteries (included)
Measurement
- Display Units: lb/kg
- Weight Measurement Range: 11-400 lbs / 5-180 kg
Available Measurements
- On Scale: Weight, Body Fat Percentage
- In-App: Weight, Body Fat Percentage, Heart Rate, Lean Body Mass, BMI, Muscle Mass, Muscle Mass %, Visceral Fat, Basal Metabolic Rate, Bone Mass, Metabolic Age, Protein, Body Water Percentage.
Weather & Temperature
- Operating Temperature: 41°F-104°F (5°C-40°C)
- RH Storage Temperature: -4°F-131°F (-20°C-55°C)
- Storage Humidity: 90% RH
- Waterproof Rating: IPX3
Connectivity & Compatibility
- OS Compatibility: Android 7.0+ and iOS 12.0+
- Bluetooth Version: BLE 5.0
- Supported Fitness Apps: Apple Health and Google Fit
Warranty
- 1-year
In the box
1x Wyze Scale X
4x 1.5V AAA Batteries
1x Quick Start Guide
FAQ
Q: What is the age range?
A: 10-100 years old. Anyone can use Wyze Scale X to take their weight measurement, no matter their age. Body composition (Body Fat %, Water %, etc.) is only available for people between the ages of 10 and 100 years old. Children under 10 and seniors over 100 will not be able to access body composition features.
Q: What is the weight range?
A: Wyze Scale X has a weight range of 11-400 lbs (5-180 kg).
Q: Why is it not showing my body composition (Body Fat %, Water %, etc.)?
A: Make sure your personal information (ex. Body Type, Athlete Mode, etc.) settings are correct. To do this, open the Wyze app and tap on your scale then Settings > Users > (your Nickname).
Q: Can I use Wyze Scale X with my shoes on?
A: Yes, but if you step on the scale with socks and/or shoes on, Wyze Scale X will only be able to measure your weight. To take your other body composition measurements (ex. Body Fat %, Water %) you will need to step on the scale with both feet while barefoot.
Q: Can I use Wyze Scale X with wet feet?
A: Not wet, but damp is fine. Wet feet may affect accuracy and make the scale slippery and not safe to use. If wet, wipe down the scale and your feet before stepping on.
Q: Can Body Impedance Analysis (BIA) affect my pacemaker?
A: Yes, BIA may affect your pacemaker. The smart body analyzer in Wyze Scale X circulates a small electric current through your body to calculate your body composition measurements, like Body Fat %. Though the current is weak, it can affect your pacemaker. However, your Wyze Scale X can be used even if you wear a pacemaker or are pregnant. If you turn on the Only Measure Weight setting, the current will be disabled and the scale will not affect your pacemaker. Set the scale to only measure your weight. Unlike other smart scales, Wyze Scale X has a unique feature that lets you disable the BIA measurement entirely to only measure weight. With this option turned on, the scale will not affect your pacemaker. To enable the Pregnancy/Weight-Only Mode: Open the Wyze app and tap Wyze Scale X. Tap on the gear to open Scale Settings. Tap Users, then select your email address to open the Account Info screen. Tap the slider next to Pregnancy/Weight-Only Mode, then Yes to confirm.
Q: How many scales can I add to my Wyze account?
A: As many as you want! There is no limit to how many Wyze scales you can add to one Wyze account. Put a Wyze Scale X in every bathroom, and in your home gym, too.
Q: Why is my body composition data different from what I see at the gym, doctor, etc.?
A: Home-use smart scales are designed for reference. Wyze Scale X uses bioelectric impedance analysis (BIA) to estimate body composition, particularly body fat. BIA is a popular method to estimate body fat percentage, but there are many other methods available. While a good estimate, the data calculated by your Wyze Scale X may vary from those given by professional-grade medical instruments or methods.
Q: How do I factory reset my Wyze Scale X?
A: On the back of your scale, find the UNIT button under the battery cover. Press and hold this button for 3s until the LED display shows "Clr".
Q: Can I use Wyze Scale X on carpet?
A: No, only use the scale on a hard, flat surface like tile or hardwood flooring before use. Carpets and rugs can affect the calibration of your scale, giving you inaccurate measurements.
Q: Should I use Wyze Scale X if I'm pregnant?
A: Consult your physician first. By default, Wyze Scale X sends a weak (and safe) electric current through the body for Bioelectrical Impedance Analysis (BIA). There are no known risks with using BIA while pregnant, but body composition results may not be accurate. Set the scale to Pregnancy/Weight-Only Mode to only measure your weight, and disable the BIA measurement entirely.
Q: What is the Bluetooth® connection range?
A: Based on our testing, Wyze Scale X has a Bluetooth® range up to 32 feet (10 meters) when clear of physical obstacles or the other wireless devices.
Q: Do I have to do anything after replacing the batteries?
A: Yes, open the Wyze app and connect to your scale. When you replace the batteries, the time on the scale resets. Connecting to it in the app will sync up the time.
Q: Can two people own two separate scales and share data?
A: No, as each user can only access their measurements within their own Wyze account. However, while you are not able to share your data within the Wyze app, we do support exporting your data via email. This will allow you to export your data into a spreadsheet to share with your healthcare professional, fitness coach, etc.
Q: I don’t want to share my data. Can the scale recognize me and only send my data to me?
A: Yes, even if you have other family members on your Wyze account, your scale measurements will only be sent to your user profile in the app. Wyze Scale X is able to differentiate up to 8 user’s measurements as long as their weight difference is greater than 13.2 lb with the app closed, or greater than 6.6 lb with the app open.
Q: Does the Wyze app have to be open while using the scale?
A: No, the app does not have to be open. Step on the scale with the app closed, and the scale will store your data until you connect to it with your phone. Once connected via Bluetooth®, the scale will sync and upload your measurements to the app.
Q: Will the scale still send my data to my phone if someone else connects to it first?
A: Yes, if you’ve taken your measurements with the Wyze app closed, the scale will store your data until you connect to it with your phone. Even if someone else steps on it and connects to it first, your measurements will not be shared and will only go to your user profile.
  • 13 Body Composition Measurements
  • Baby, Pet, Luggage, Pregnancy Modes
  • Up to 22 Months of Battery Life
  • Syncs with Popular Health Apps
1 of 4
Two Patterns. Same Accuracy.
Goal-oriented home screen.
Immediately see your goal and trend line when you open the Wyze Scale X app.
View your monthly trends, heart-rate, body fat, and muscle mass without tapping any further.
Helpful insights into each measurement.
Wyze Scale X gives detailed explanations about each measurement so you can understand more about your health and make informed decisions.
Full-glass surface electrodes.
An ITO coating of the tempered glass used on Wyze Scale X gives highly accurate body composition measurements.
Designed for every space.
Wyze Scale X comes in two neutral color options to compliment the design of wherever you decide to place it.
1 of 2
Baby, Pet, Luggage, and Pregnancy Modes.
Step on the scale with your 4-legged friend, 4-wheeler travel bag, or all 4 kids and let Wyze Scale X do the math for you. Pregnancy Mode turns off all electrical currents used to measure body composition as an added safety measure.
Motivation with the brands you love.
Wyze Scale X syncs with popular health apps so you can track everything in one place and take full control over your health journey.
  • Apple Health
  • Fitbit
  • Health Connect
1 of 3
Share with family and friends.
Share access to Wyze Scale X with up to 8 family members and friends. For privacy, each user sees only their own personal insights and measurements.
Syncs automatically.
Don't have your phone on you? No problem.
Wyze Scale X keeps track of all your measurements locally and then automatically syncs with Bluetooth whenever you open the Wyze app.
Thin and light for easy storing.
Scale X is built from premium materials making it both thin and light so you can effortlessly store it away when you're not using it.
Measure heart rate in the Wyze app.
The Wyze app provides a quick and convenient way to measure your heart rate from anywhere. Simply follow the steps and get your heart rate anywhere in under 10 seconds.
Instant step to wake.
No more annoying “tap and wait” before stepping on. Wyze Scale X immediately starts measuring as soon as you step on. See your weight and body fat percentage on the bright LED display.
