Wyze Scale BodyScan
Wyze Scale BodyScan
Our Most Affordable 8-Electrode BIA Scale
Low stock
Meet your body's most affordable accountant. Wyze Scale BodyScan delivers professional-grade, dual-frequency 8-electrode BIA with segmental muscle and fat analysis across your arms, legs, and torso. 17 body composition metrics, 7 on the 4.7-inch LED display the second you step on, no app required. Syncs to Apple Health, Health Connect, and Fitbit. Recognizes up to 8 users automatically. 9-month battery life. No subscription. No excuses.
Features
Features
Specs
Specs
Wyze Scale BodyScan Specs
Color: Black or White
Materials: Plastic, Silicone, ITO Coated Glass
Weight: 4.18 lbs / 1.90 kg
Dimensions: 11.81 in x 13 in x 1.49 in / 300 mm × 330.2 mm × 37.8 mm
Power: Battery-Powered: 4 x 1.5V AAA Batteries (Included)
Display Units: lb/kg
Weight Range: 11 - 400 lbs / 5 - 180 kg
Available Measurements
Displayed On Scale: Weight, Body Fat Percentage, BMI, Muscle Mass Percentage, Bone Mass, Protein, Body Water Percentage
Displayed In-App: Weight, Body Mass Index, Body Fat Percent, Muscle Mass, Muscle Rate, Body Water, Physical Age, Protein, Lean Weight, Bone Mass, Visceral Fat, Basal Metabolism, Subcutaneous Fat, Fat Mass, Skeletal Muscle Mass, Segmented Muscle Mass & Body Fat
Weather
Operating Temperature: 41°F-104°F (5°C-40°C)
Operating Humidity: 20 - 85% RH
Storage Temperature: -4°F-131°F (-20°C-55°C)
Storage Humidity: 90% RH
Connectivity & Compatibility
Connectivity: Bluetooth 5.0®Phone Compatibility: Android 10.0+, iOS 16.0+
Supported Fitness Apps: Apple Health, Health Connect, Fitbit
Warranty: 1 year warranty
In the box
In the box
Wyze Scale BodyScan x 1
1.5V AAA Batteries x 4
Quick Start Guide x 1
FAQ
FAQ
Q: What is the difference between Wyze Scale BodyScan and Wyze Scale Ultra BodyScan?
A: Both scales use the same dual-frequency eight-electrode body impedance analysis (BIA) with a handle for segmental body composition analysis, and both measure the same 17 body composition metrics, so you're getting the same professional-level measurement accuracy with either scale. Wyze Scale BodyScan shows 7 key metrics on its LED display and delivers your full segmental breakdown, detailed reports, and trend tracking through the Wyze app. Wyze Scale Ultra BodyScan adds a customizable TFT screen for viewing more metrics and segmental data directly on the scale, plus Wi-Fi connectivity for automatic syncing. If you want the same accuracy at an unbeatable price, BodyScan delivers it for less.
Q: What is the difference between Wyze Scale BodyScan and Wyze Scale X?
A: Both scales connect via Bluetooth and track body composition metrics through the Wyze app. Wyze Scale BodyScan steps it up with dual-frequency eight-electrode BIA and a handle that measures body impedance in your arms, legs, and torso individually, delivering results that are more accurate and personalized than the 4-electrode foot-only measurement used by Wyze Scale X. BodyScan also features a large 4.7-inch LED display showing 7 key metrics on-screen and includes 17 body composition metrics with segmental muscle mass data. If you're serious about understanding your body composition beyond just weight, BodyScan is well worth the upgrade.
Q: How many scales can I add to my Wyze account?
A: As many as you want! There is no limit to how many Wyze scales you can add to one Wyze account. Put a Wyze Scale BodyScan in every bathroom, and in your home gym, too.
Q: What is the age range?
A: Anyone can use Wyze Scale BodyScan to take their weight measurement, no matter their age. Body composition (Body Fat %, Water %, etc.) is only available for people between the ages of 10 and 100 years old. Children under 10 and seniors over 100 will not be able to access body composition features. For users between 10-17, body composition data is only for reference.
Q: What is the weight range?
A: Wyze Scale BodyScan has a weight range of 11-400 lbs (5-180 kg).
Q: Can I use Wyze Scale BodyScan with my shoes on?
A: Yes, but it will only measure your weight. To take your full body composition measurements (ex. Body Fat %, Water %, Lean Body Mass) you must hold the handle and step on the scale with both feet while barefoot.
Q: Can I use Wyze Scale BodyScan on carpet?
A: No, only use the scale on a hard, flat surface. Carpets and rugs can affect the calibration of your scale, giving you inaccurate measurements.
Q: Can I use Wyze Scale BodyScan with wet feet?
A: Only step on Wyze Scale BodyScan with dry or slightly damp feet, and only when the surface of the glass is not wet. If wet, wipe down the scale and your feet before stepping on.
Q: Can Wyze Scale BodyScan measure my heart rate?
A: Yes, the Wyze app provides a quick and convenient way to measure your heart rate from anywhere in under 10 seconds.
Q: Should I use Wyze Scale BodyScan if I'm pregnant?
A: Consult your physician first. By default, Wyze Scale BodyScan sends a weak (and safe) electric current through the body for Bioelectrical Impedance Analysis (BIA). There are no known risks with using BIA while pregnant, but body composition results may not be accurate. Set the scale to Pregnancy / Weight-Only Mode to only measure your weight.
Q: Why is my body composition data different from what I see at the gym, doctor, etc.?
A: Home-use smart scales are designed for reference. Wyze Scale BodyScan uses bioelectric impedance analysis (BIA) to estimate body composition, particularly body fat. BIA is a popular method to estimate body fat percentage, but there are many other methods available.
While a good estimate, the data calculated by your Wyze Scale BodyScan may vary from those given by professional-grade medical instruments or methods.
Q: How do I factory reset my Wyze Scale BodyScan?
A: Open the battery compartment, then set the scale down. Tap to activate the scale, then press and hold the UNIT button above the batteries. The TFT display will show “Clear” when the scale is reset.
Q: How do I open the battery compartment?
A: On the back of Wyze Scale BodyScan, locate the arrow over the battery compartment. With two thumbs, press downward on the center of the compartment cover, away from the UNIT/RESET button.
Professional-Grade Precision at Home
Built-in handle and electrodes to measure your arms, legs, and torso individually.
Large Information Display
Cutting-edge screen displays your health data right at your toes, no app needed.
17 Essential Body Composition Metrics
Measure your weight, body fat percentage, heart rate, BMI, and so much more.
Detailed Advanced Reports
Get a detailed breakdown of your body composition, and track progress trends over time.
BodyScan precision. Somehow even more affordable.
A deeper scan from head to toe.
8 smart electrodes across your hands and feet to measure your arms, legs, and torso individually, delivering gym-grade body composition insights without the gym membership.
Ultra-detailed data reports. No subscriptions.
Get segmental data for your arms, legs, and torso without paying an arm and a leg.
4.7 inches of phone-free data without the scrolling.
View 7 key metrics instantly on the massive 4.7-inch LED display. The app's there when you want to go deeper, but you don't need it to know where you stand.
Track 17 Essential Health Metrics
Keep track of important health metrics like weight, body fat, muscle mass and more. We haven't figured out how to measure the joy you'll feel when you achieve your dream bod, but we're working on it.
Track Body Metric Data Trends
View insightful body metric trends instantlyon the scale every time you step on it.
Baby, Pet & Luggage Mode
We get it. Math is hard. Weigh your baby, pet, luggage, or your kid’s absurdly heavy backpack with smart baby/pet mode and let us do the calculations for you.
Unlimited Sharing & Smart User Recognition
Share it with the whole family. Wyze Scale BodyScan automatically recognizes and syncs data for up to 8 unique users. Take one-off measurements for an unlimited number of guests. Stay motivated by sharing data and trends with an unlimited number of people.
Reliable Bluetooth® Connection
Quickly sync your health data to the Wyze app and track your metric history.
Two Colorways to Fit Any Room
Wyze Scale BodyScan comes in two color options to match whatever vibe you've got going on in your porcelain palace.
Works with the brands you love.
No need to ditch your existing fitness tracker. Wyze Scale BodyScan connects seamlessly to your health apps for smooth syncing and complete control over your wellness journey.
Apple Health
Fitbit
Health Connect
Anti-Slip Floor Contacts
Sturdy construction and grippy silicone floor contacts enable safe and accurate measurements, every time.
ITO Coated Glass
Step anywhere on the scale. An ITO conductive glass gives highly accurate body composition measurements.
Long-Lasting Battery Life
They say nothing lasts forever. Except maybe the embarrassment you feel when the server tells you to have a nice meal, and you say, "You too!" Like, why would you say that? Anyways, enjoy up to 9 months of battery life with this scale.
