1 of 8
Wyze Lamp Socket v2
Wyze Lamp Socket v2
Make your exterior lighting smart.
Regular price $25.98 CAD
Regular price Sale price $25.98 CAD
Sale Sold out
Style
874 in stock
Make your exterior lighting even smarter. With our latest lamp socket, you can now power Wyze Cam v3/v3 Pro/v4, Cam OG, Pan v3, Pan v4 and Duo Cam Pan without the need for a power outlet.
Check out what's new:
  • Same Dusk-to-Dawn technology
  • Motion Activated lighting + AI Activated lighting for security plan subscribers
  • Now you can link unlimited Lamp Socket v2's ✓
  • Now compatible with Cam OG and Pan v3 ✓
Features
Turn Your Dumb Light Into a Smart Light
Easy Installation
Links Well With Others' Lamp Sockets
Motion-Triggered LightsSchedules and Rules
Powers Wyze Cam v3/v3 Pro/v4/OG/Pan v3/Duo Cam Pan via USB
Indoor and Outdoor Use
Easy and Versatile Mounting
Specs
Color: White
Materials: Polycarbonate, Plastic
Dimensions: 56.5mm x 56.5mm x 65mm
Weight: 80 g
Socket Connector Type: E26
Power
Lamp Socket Input/Output 120V~, 60Hz
Max Lamp Power 20W
Compatibility
Phone: Android 7.0+, iOS 12.0+
Camera: Wyze Cam v3/v4, OG, Pan v3
Connectivity
802.11 b/g/n, 2.4GHz, Bluetooth
Operating temperature
-4°F ~ 120°F (-20°C, ~ 50°C)
Weather Resistance
Not weatherproof or waterproof. Suitable for damp locations.
Certifications: FCC, IC UL496, CA65, TSCA, RoHS
Warranty: 1-Year
Note: Due to thermal limitations, incandescent bulbs cannot by used with this lamp socket. We recommend using a CFL or LED bulb under 20W, like Wyze Bulb White.
In the box
1x Wyze Lamp Socket v2
1x Sticker
1x Quick Start Guide
FAQ
Q: What is the difference between this and other USB lamp sockets?
A: Users can leave the power switch on all the time, but the light doesn’t need to stay on all the time, to save power. The light will be turned on when a motion or person is detected.
Q: What kind of bulbs are compatible with Wyze Lamp Socket v2?
A: Due to thermal limitations, incandescent bulbs cannot by used with this lamp socket. We recommend using a CFL or LED bulb under 20W, like Wyze Bulb White.
Q: How do I link multiple lamp sockets together?
A: Turn them all on (up to 5) within 30 seconds and they will find themselves, link, and form a group. Once they form a group, you can control each lamp socket in the group at the same time.
Q: How many Wyze Cams can be connected?
A: Only 1 (one) Wyze Cam v3 or Cam v4 per lamp socket.
Q: Does it support multiple outdoor fixture lights?
A: Yes absolutely. All sockets are connected wirelessly and can be turned on/off simultaneously. We currently support up to 5 lamp sockets linked in one group.
Q: Do I need extra cables to connect it to a Wyze Cam?
A: No, each Wyze Lamp Socket comes with a dedicated cable to connect to a v3/v4. Do not use any other Wyze Cam v3/v4 cable.
Q: Does it work with other Wyze cameras?
A: No, it does not support Wyze Cam v1/v2 or Wyze Cam Pan v1/v2 because they cannot communicate with the lamp socket. Wyze Cam Outdoor is also not supported because the USB cable is not designed to support this camera, and would compromise the camera’s built-in waterproofing.
Q: Can I use it without a Wyze Cam?
A: No, you must have at least one Wyze Cam v3 or v4 connected to the lamp socket.
Q: Is it compatible with my light fixture?
A: We currently support E26 sockets. (Link to E26 vs E12)
Q: How far can my light fixtures be apart?
A: Up to 82 feet (25 meters) apart.
Q: Do I always need to keep the power to the lamp socket on?
A: Yes, you must keep the switch that powers the lamp socket on at all times. You can use the Wyze app to turn the light on/off, set a schedule for it to turn on/off automatically, or have the light triggered by motion.
Q: Is Wyze Lamp Socket weatherproof?
A: No, it is not weatherproof or IP-rated. It is UL rated for Damp Locations, and must be protected from direct rain and water.
Q: Does it come with a lamp or light fixture?
A: No, neither the lamp socket or bundle includes a lamp.
Q: Can I schedule my lights to turn on/off?
A: Yes, you can schedule the light to turn on/off in the Wyze app.
Q: How does the motion-trigger feature work?
A: We use the advanced motion detection from Wyze Cam v3 or v4 to detect motion and turn on your light.
Flexible power for your Wyze Cams, now including Pan v3.
Skip the wiring and electrocution (unless you're into that sort of thing). Harness the electricity from your outdoor light fixture to continuously power your Wyze Cam v3/v3 Pro/v4, Wyze Cam OG, and Wyze Cam Pan v3. No long, ugly wires. No hassle.
Upgrade to smart lighting in seconds.
Wyze Lamp Socket v2 and compatible Wyze Cams work together to make your existing outdoor lighting smart. The socket gives the camera power and the camera gives the socket brains! Control your lights from anywhere in the Wyze app.
Illuminate your way to motion activated lights.
Set your newly smartened lights to illuminate whenever your compatible Wyze Cam senses motion. Now your old light fixture is a cutting-edge model of sleek security sophistication!
Easily link multiple sockets for greater coverage and control.
Assign unlimited lamp sockets to your Wyze Cam automated, group-controlled lighting. Then schedule and control your smart setup from anywhere using the Wyze app.
Dusk to Dawn automation.
As easy as screwing in a lightbulb.
Some installations are as easy as screwing in a lightbulb. Other installations are literally the exact same as screwing in a lightbulb. Wyze Lamp Socket v2 falls in the latter category.
This video is for our Lamp Socket v1, but the installation process is still just as easy.
