1 of 11
Wyze Duo Cam Pan
Wyze Duo Cam Pan
Two cams. Two views. Zero blind spots.
Pack
Wyze Duo Cam Pan delivers two 2K cameras in one device for complete coverage. One stays fixed on your priority view while the other pans and tilts to track motion, with color night vision, spotlights, siren, and indoor/outdoor versatility. Outdoor use requires Wyze Cam Universal Outdoor Power Adapter, available Sept. 2025.
Features
Dual-lens, dual-view, work at the same time
One fixed cam, one pan and tilt cam, 360° no blind spots
Dual 2k HD quality with WDR
Color Night Vision, built-in IR LEDs
Motion & sound detection (free)
Specs
Wyze Duo Cam Pan Tech Spec
Colors: White
Finish: Textured Matte
Body: Polycarbonate
Lens: Glass + Plastic
Lens FOV:
DFOV 127.5°, HFOV 106°, VFOV 56.5° (Fixed)
DFOV 127.5°, HFOV 106°, VFOV 56.5° (PT)
Image Sensor: 1/2.8'' CMOS (Fixed), 1/2.8'' CMOS (PT)
LED Indicator: Front. Red + Blue.
Dimensions: 2.36in x 2.16in x 5.26in (64mm x 54.9mm x 133.5mm).
Weight: 0.66lb (300g).
Mounting: Stand, wall mount, ceiling mount.
View Range: 360° horizontal, 180° vertical.
Power Adapter: Input 110-240 V (AC/DC), Output 5V/1.5A
Compatible Outdoor Power Adapter (sold separately and coming soon)
Cable: 6-Foot Flat Type-C to USB-A
Video Resolution: 2K (2304*1296)+ 2K (2304*1296)
Wide Dynamic Range (WDR): Yes
IR Lights: 4x850 nm
Day/Night Vision: Yes
Night Vision: 4 IR LEDs (850 nm) + 4 white spotlight LEDs ( 80 lumens)Color Night Vision: Yes
Video Encoding: H.264Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Audio Speaker: 100dB, waterproof
Simultaneous 2-way Talk: Yes
Built-in Siren: Yes
Noise & Echo Cancellation: Yes
Connectivity & Compatibility
Bluetooth® 5.0
Wi-Fi: 2.4 GHz Wi-Fi, Wi-Fi 6
Phone Compatibility: Android 10+ and iOS 16+
Integrations: Alexa, Google Assistant, IFTTT
Local storage: Yes (microSD card required, sold separately)
MicroSD card up to 512 GB
Cloud storage: Yes (with subscription plan)
IP65 weather-resistant
Operating temp: -4ºF - 113ºF (-20ºC - 45ºC)
Storage temp: -22°F - 158°F (-30°C - 70°C)
Language: English
Warranty: 1-Year
In the box
Wyze Duo Cam Pan x1
Quick Start Guide x1
Mounting Kit x1
Wall Plate x1
USB-C to USB-A Cable (6-foot, flat) x1
Indoor Power Adapter (5V, 1.5A. x1
FAQ
Q: Will this work with Lamp Socket v2?
A: Yes! It's compatible.
Q: What's new with Wyze Duo Cam Pan?
A: Two cameras combined as one camera. One of the cameras is stationary. The other camera is a pan and tilt camera.
Q: Is Wyze Duo Cam Pan wireless?
A: No, Wyze Duo Cam Pan is powered via a 1.8 m USB cable.
Q: Can I use Wyze Duo Cam Pan outdoors?
A: Yes, Wyze Duo Cam Pan is IP65-rated and can be used both indoors and outdoors. Just be sure to cover the SD card slot to avoid water damage. Wyze Universal Outdoor Power Adapter is required for outdoor use.
Please note that Wyze Universal Outdoor Power Adapter is coming soon.
Q: Does Wyze Duo Cam Pan support local storage?
A: Yes! Wyze Duo Cam Pan has a microSD card slot for local storage, and you can record 24/7 and store videos locally.
Q: Do I need a Wi-Fi 6 router for Wyze Duo Cam Pan?
No, Wyze Duo Cam Pan is compatible with Wi-Fi 6, but it is not required.
Q: Does Wyze Duo Cam Pan support 5 GHz?
A: No, Wyze Duo Cam Pan only supports 2.4 GHz networks.
Q: Is Wyze Duo Cam Pan compatible with Wyze Web View?
A: Yes, Wyze Duo Cam Pan supports Wyze Web View (Requires an active security plan.)
Q: Does Wyze Duo Cam Pan have Privacy Mode?
No, Privacy Mode is not a feature on Wyze Duo Cam Pan. Because the camera has two lenses and one is stationary, a truly physical Privacy Mode is not an option.
Q: What is the difference between the two cameras?
A: The top and bottom cameras are nearly identical, sharing most of the same features, like field-of-view and a spotlight. However, the bottom camera is fixed and has a speaker and mic, while the top camera moves and has the status light. Can I use Wyze Duo Cam Pan outdoors? Yes, Wyze Duo Cam Pan is IP65-rated and can be used both indoors and outdoors. Just be sure to cover the SD card slot to avoid water damage.
  • Two Cameras. Two Views.
    One fixed + one pan and tilt cam eliminate blind spots.
  • 2K HD Resolution + Color Night Vision
    See every detail clearly in vibrant color, day or night.
  • Indoor/Outdoor Security
    Place it anywhere with IP65 weather resistance.
  • Two Motion-Activated Spotlights
    Automatically trigger the LED light and voice prompt for extra security.
1 of 4
Two cameras. Two views.
One stays steady while the other one moves. Cover two areas with a single device for maximum coverage.
Take in the entire scene with seamless
Now you'll never miss the action with automatic way points and auto tracking. Capture it all with incredible 2K clarity for every detail.
  • Traditional Night Vision
  • Color Night Vision
Integrated Spotlights + Siren
More safety at night.
ip65 weather resistance
Place it anywhere.
Wyze Duo Cam Pan is IP65 weather-resistant, so it can operate in any weather.
Note: Outdoor use requires Wyze Cam Universal Outdoor Power Adapter, available September 2025.
Enhanced two-way talk
Clearer conversation.
Forget the days of sounding like you’re talking through tin cans. Advanced Audio Coding (AAC) and a revamped mic give our best audio experience yet.
Record every second
24/7 Recording with MicroSD Card.
Don’t miss a thing with continuous local recording to a microSD card up to 512 GB. No subscription required.
See it in Action.
And check out the unboxing video to see more magic.
Full coverage
Double the coverage. No blind spots.
It's especially effective when placed near a corner. Keep a fixed watch on the driveway, and at the same time follow the action if it moves to the backyard.
Connect with bluetooth®
Easy to set up.
No need to scan QR codes. Enjoy hassle-free setup with Bluetooth®. We'll get you up and running within minutes.
Plug it in and go
Versatile mounting.
Four unique mounting options gives you the flexibility to secure your space exactly how you need to.
Works with smart assistants
Convenience and customization at your fingertips with integrations like Amazon Alexa, Google Assistant, IFTTT, and Wyze Automation.
Patrol your room with Pan Scan
Set the camera’s patrol route with up to 4 custom waypoints.
Even more features to love.
Wi-Fi 6 Connection Support
Motion and Sound Detection
Look & listen for motion & sound. Wyze Duo Cam Pan sends your phone an alert and begins recording when either is detected.
Detection Zones
Smoke & CO Alerts
Receive an alert the moment Wyze Duo Cam Pan hears a Smoke or CO alarm go off. Wyze Cam records a video during this time.
