1 of 12
2700+ ratings on Amazon
Wyze Cam Floodlight v2
Color
$128.99
Dominate the dark with 2800 Lumens LEDs, 2K video with Color Night Vision, and a 160° wide-angle view. Enjoy 24/7 local recording, Ambient Light Mode, two-way talk, and AI-Powered Light Control. All that, plus dusk-to-dawn automation, IP65 weather resistance, and seamless integrations with your favorite smart assistant means Wyze Cam Floodlight v2 is lighting the way to smarter home security.
Features
Dominate the dark - 2 super bright LED panels with 2800 Lumens
2K video - Crystal clear image quality so you can see every detail
Color Night Vision
24/7 local recording - Add a MicroSD card and capture days worth of footage
Specs
Wyze Cam Floodlight v2 Details
Color: White/Black
Finish: Matte
MountingWall/Ceiling
Materials & Components
Body: Polycarbonate
Lens: Glass + Plastic
Camera Dimensions: 9.5in x 7.7in x 7.0in (24.13cm x 19.56cm x 17.78cm)
Camera Weight: 2.76 lbs (1.25 kg)
Image Quality: 2K (2304 x 1296)
Night Vision
Color Night Vision
20 FPS daytime and 15 FPS nighttime
Field-of-view: 160° Diagonal
Light:2 dimmable LED light panels
2800 total lumens of brightness
5000K color temperature
Dimmable: Yes
Siren 105dB
Power Supply
Hardwired 110 - 120V AC
Additional Specifications
Audio: Built-in speaker and microphone; 2-way audio
Local Storage: Supports up to 256 GB microSD in ExFAT format
In the box
x1 - Wyze Cam Floodlight v2 (assembled)
x1 - Quick Start Guide
x1 - Mounting Accessory Kit
x2 - Bracket Screws
x1 - Ground Screw
x1 - Floodlight Screw
x1 - Rubber Stopper
x1 - Mounting Bracket
x2 - Wire Nuts
x1 - Hook
FAQ
What’s new with Wyze Cam Floodlight v2?
Wyze Cam Floodlight v2 is a 2K HD camera featuring a 160-degree super-wide angle view for extra coverage, upgraded floodlights with 2800 lumens of light, and Ambient Light Mode for additional exterior lighting. All that in a more rugged and robust build, with our new Access Point feature for ladder-free camera setup, and the Motion Warning feature that alerts intruders that they're being recorded.
Why do we love the 160° camera view?
The 160° wide-angle field of view eliminates nearly all blind spots, ensuring comprehensive surveillance for your peace of mind.
What is the Access Point feature used for?
Access Point setup lets you use a Wi-Fi hotspot to connect to your mobile device during setup. This saves you the hassle of climbing up a ladder to scan the QR code.
What is the Motion Detection range?
The floodlight can detect motion up to 30 feet away, with a customizable Detection Zone.
Can I store video recordings locally on a microSD card?
Yes, Wyze Cam Floodlight v2 has a microSD card slot in the camera that allows you to record 24/7 and store videos locally. The microSD card slot supports up to 265 GB (exFAT and FAT32 formats).
How does the motion-activated light work?
When motion is detected by the 270° PIR sensor, the floodlight turns on for a select period of time and then turns off. This feature is enabled by default but can be disabled in the floodlight's settings.
Does Wyze Cam Floodlight v2 have a battery?
No, Wyze Cam Floodlight v2 does not have a battery and must be hardwired.
Is Wyze Cam Floodlight v2 hardwired?
Yes, Wyze Cam Floodlight v2 needs to be hardwired either where another floodlight is installed or by using a junction box. Please ask a licensed electrician if you do not have a junction box set up yet.
Does Wyze Cam Floodlight v2 support 5 GHz Wi-Fi?
No, it only supports 2.4 GHz networks.
See more, worry less.
A 160° wide-angle view gives you double the visibility compared to the previous generation. Moms everywhere are wondering if this can be applied to genetics.
The dark doesn't stand a chance.
Turn night into day with two 2800 lumen, adjustable and motion-activated LED lights that illuminate your path and keep intruders at bay.
24/7 local recording with microSD card.
Don’t miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.
Caption
Two-way talk + loud siren.
Respond to visitors and familiars by tapping on the mic icon in the Wyze app. Still not getting the message? Sound the 105dB siren for extra deterrence.
Bye bye, blind spots!
Eliminate blind spots and trigger lights faster than ever with a 270° PIR motion detection area.
Dusk-to-dawn automation.
The floodlight knows when the sun goes down and when it comes back up. No need to turn it on and off manually.
IP65 weatherproof.
Rated to withstand any weather. Especially, the "it's raining packages which means my partner maxed out the AMEX again" type of weather. That's the worst weather.
It's time to shine!
