Low stock
Features
Features
Easy-to-install, plug-n-play floodlight solution
No junction boxes needed
Compatible with all Wyze floodlight camera models (v1, v2, and Pro)
20ft outdoor SJTW weather-resistant power cord Available in both black & white colorway
Streamlined & consistent design (looks clean and sleek)
Specs
Specs
Wyze Cam Floodlight Plug-in Mount
Colors: White and Black
Outdoor safe: Yes
Operating Temperature: -22°F to 122°F
Input: 110 - 120V AC
Power Cord Rating: SJTW (Hard service, thermoplastic cable, S: service, J: junior, T: thermoplastic, W: weather-approved)
Cable Wire: 18 AWG
Power Cord Length: 20 feet (6m)
Package Dimension: 153mm x 155mm x 79mm
Package Weight: 1.39 lbs
Wyze Cam Floodlight v2
Color: White or Black
Finish: Matte
Mount: Wall/Ceiling
Body: Polycarbonate
Lens: Glass + Plastic
2 dimmable LED light panels
2800 total lumens of brightness 5000K color temp
Dimmable: Yes
2K (2304 x 1296)
Night Vision & Color Night Vision
Hardwired 110 - 120V AC-4°F - 140°F (-20°C - 60°C)
IP65 Water Resistance
Safe for outdoor use
Connectivity & Compatibility
IEEE802.11 b/g/n. Wi-Fi 2.4G b/g/n
Phone Compatibility: Android 9.0+, iOS 15.0+
Integrations: Alexa, Google Assistant, IFTTT
Warranty: 1 Year
In the box
In the box
1x Wyze Cam Floodlight Plug-in Mount
1x Floodlight Pro mounting kit (silicone ring, long screw)
1x Mounting screw kit
1x Foam tape
1x Quick Start Guide
1x Wyze Cam Floodlight v2
1x Mounting Accessory Kit
2x Bracket Screws (#6, #8, and #10)
1x Ground Screw
1x Floodlight Screw
1x Rubber Stopper
1x Mounting Bracket
2x Wire Nuts
1x Hook
2.5K QHD & Color Night Vision
Capture more details day and night with 160° Wide Field of View.
Plug-in mount with 20ft Power Cord
Reach a outdoor-rated outlet with ease. Velcro cable strap included.
Easy to Install
It's fast and easy. Just plug it in, and mount your floodlight.
No Junction Box Required
Skip the electrician and the construction. Plug-n-play in minutes.
What's in this bundle?
Buy this combo now-
The dark doesn't stand a chance.
Delivering 2K HD video and vibrant color night vision, this outdoor security camera ensures your home always under watch. The expansive 160° wide-angle view and advanced motion detection eliminates blind spots.
Enjoy a well-lit exterior with powerful 2800-Lumen LEDs, and let the 105dB siren add an extra layer of security. -
Wyze Plug-in Mount
Easy to install. No junction box needed.
Say goodbye to the complexity and cost of a junction box. No need to hire electricians and handy people, or cut giant holes into the exterior of your home.Works with Wyze Floodlight v1/v2 and Pro.
A flexible power solution for all Wyze Cam Floodlights.
Ditch the shock and zap (unless you're into that sort of thing). If you can plug in a cable, then you can enjoy the security of a Wyze Floodlight. No more scary junction boxes and expensive electricians.
Put it right where you need it.
Free thyself from the shackles of non-ideally-located junction boxes! The durable 20ft. cable reaches outdoor-rated outlets with ease. A velcro strap is included for clean cable management.
Seriously, watch how easy it is to install.
Compatible Wyze Cam Floodlights
Wyze Cam Floodlight v1
Color: White
Camera resolution: 1080p
Lighting: 2 floodlight heads, 2600 lumens
AI Detection: People, Pets, Vehicle, and Package (with Cam Plus plan)
Wi-Fi: 2.4Ghz
Ambient light: No
Motion warning: No
Status: Retired
Wyze Cam Floodlight v2 NEW
Color: White/Black
Camera resolution: 2K
Lighting: 2 floodlight heads, 2800 lumens
Wi-Fi: 2.4Ghz
Ambient light: ✓
Motion warning: ✓ (with Cam Plus plan)
Release date: 2024
