1 of 6
Wyze Cam Floodlight v2 + FREE Color Filters
Wyze Cam Floodlight v2 (Color)
Transform your space with 6 pairs of color filters for every mood and occasion.
Features
- 6 Vibrant Color Options: Choose your colors to set the scene.
- Transform Your Floodlight: Your light, your vibe. Tone it down or jazz it up.
- Compatible with Floodlight v1 & v2: Use your existing Wyze Cam Floodlight v2/v1 (not compatible with Pro).
Specs
Wyze Cam Floodlight v2 Color Filter
- Color: 3500K Warm White, Red, Blue, Green, Cyan, Purple
- Material: High-transmittance plastic + adhesives
- Dimensions: 2.76 in x 0.79 in x 3.15 in / 7cm x 2cm x 8cm
- Weight: 0.16 lbs / 0.073kg
- Compatible with: Wyze Cam Floodlight v1/v2
Color & Materials
- Color: White or Black
- Finish: Matte
- Mount: Wall/Ceiling
- Body: Polycarbonate
- Lens: Glass + Plastic
Lighting
- 2 dimmable LED light panels
- 2800 total lumens of brightness
- 5000K color temperature
- Dimmable: Yes
Image Quality
- 2K (2304 x 1296)
- Night Vision
- Color Night Vision
Power Supply
- Hardwired 110 - 120V AC
Weather and Temperature
- -4°F - 140°F (-20°C - 60°C)
- IP65 Water Resistance
- Safe for outdoor use
Connectivity & Compatibility
- IEEE802.11 b/g/n. Wi-Fi 2.4 GHz b/g/n
- Phone Compatibility: Android 9.0+, iOS 15.0+
- Integrations: Alexa, Google Assistant, IFTTT
Warranty
- Floodlight v2: 18 months
- Floodlight Color Filters: 12 months
In the box
1 x Wyze Cam Floodlight v2 (assembled)
1 x Quick Start Guide
1 x Mounting Accessory Kit
2 x Bracket Screws (#6, #8, and #10)
1 x Ground Screw
1 x Floodlight Screw
1 x Rubber Stopper
1 x Mounting Bracket
2 x Wire Nuts
1 x Hook
12 x Color Filters (6 pairs total, 2 of each color)
- 3500K Warm White
- Red
- Blue
- Green
- Cyan
- Purple
2 x Cleaning Wipe Packets
- Each packet includes 1 wet wipe + 1 dry wipe
(Camera not included)
FAQ
Q: Can I repeatedly install or swap colors?
A: Yes, you can gently peel off the current filter using the small tab on the bottom of the filter, then clean the LED lamp’s surface and apply a new color. Just keep in mind that repeated removal and reapplication will reduce the adhesive strength over time.
Q: Can I mix different colors on each of the lamp heads?
A: Absolutely! Each pack includes 6 colors (2 filters in each color) so you can mix and max – use one color on each lamp head to create your own custom combo.
Q: Will the filters reduce the brightness of my floodlight?
A: Wyze Cam Floodlight v2 Color Filters are designed with high transmittance to help maintain light output. Some brightness reduction may occur, especially with colored filters, but they’re designed to provide warm or colorful lighting without significantly compromising your floodlight experience.
Q: Can I use the color filters on Wyze Cam Floodlight Pro?
A: No, the filters are only compatible with Wyze Cam Floodlight v1/v2. They are not compatible with Wyze Cam Floodlight Pro.
Q: How long will the filters last?
A: They are built with durable material and adhesive designed to withstand outdoor conditions alongside your IP65-rated Wyze Cam Floodlight v2. Under regular use, the filters will last multiple seasons.
Q: Will the color filters affect my camera resolution?
A: No, the color filters are applied to the LED lamp heads only and do not cover the camera lens. Your camera’s resolution and night vision should remain unaffected.
Q: Are the color filters weatherproof?
A: The filters are built with durable, weather-resistant material. Just be sure to clean and fully dry the LED light surface before applying the filters for the best adhesive bond.
Q: What are the color codes for the filters’ colors?
A:We are unable to provide the color codes as the color may appear slightly different based on environmental factors and the floodlight’s brightness.
Q: How do I store used filters if I want to reuse them?
A: Store filters in a cool, dry place while ensuring the adhesive side isn’t exposed to dust.
Q: What should I use to clean the lamp head?
A: Two small cleaning wipes are included in the package, but you can also use similar electronics cleansing wipes or a soft microfiber towel. No need for soapy water! Do not use abrasive materials, sharp objects, harsh chemicals, or rough cloths, as these may damage the lamp head surface.
Q: Can I clean the adhesive part of the color filter?
A: No, the adhesive cannot be cleaned. Please ensure minimal to no dust is on them when applying to the lamp head.
Q: How many times can I re-use the color filters?
A: While they can be reused multiple times if stored and cared for properly, we generally consider them one-time use, similar to phone screen protectors.
Q: Can I layer multiple color filters on top of each other?
A: We do not recommend stacking or layering the filters.
1 of 3
Use the perfect color for your home
Choose from 6 color options to add a fun, welcoming glow to holidays, celebrations, and everyday moments.
Quick and easy installation.
Just peel the protective film from the plastic filter, stick it to the floodlight, and you’re good!
Softer warm white lighting.
Transform your floodlight with a softer warm glow.
Compatible with Floodlight v1 & v2.
Elevate your lighting experience even if you have our older Floodlight v1.
Weather resistant.
It can handle anything Mother Nature can throw at it.
