1 of 6
Wyze Cam Close-up Lens
Get closer to the action. Capture close-ups of wildlife & small pets.
$14.99
Bring the smallest moments into sharp focus. Our close-up (macro) lens accessory lets you capture wildlife and pets in breathtaking clarity.
Features
Specs
Color: White
Material: Plastic
Intended for use with: Compatible with Wyze Battery Cam Pro, Wyze Cam v3/v3 Pro/v4, Wyze Cam Outdoor v1/v2.
Warning
Do not attempt to remove or adjust the lens while the camera is powered on to avoid potential damage.
Handle the lens carefully to avoid scratching or smudging the surface.
Keep the lens out of reach of small children to prevent choking hazards.
Note: This magnifying lens is designed exclusively for select Wyze Cam devices. It is not compatible with other camera models.
In the box
1x Lens adapter
1x Quick start guide
FAQ
Q: Macro lens, close-up lens, are they the same?
A: Yes, they mean the same thing in this case. The Wyze Close-up Lens does what it says in the name. Instead of opening the camera to DIY a change to the focal length, this exterior lens is placed over the camera's lens so you can get a clear view of small pets that get up close to your camera.
Easy install, works with multiple Wyze cams
One lens to rule them all. Our lens bracket, while not universal to every cam, was designed to fit: Wyze Battery Cam Pro, Cam v3/v3 Pro/v4, and Cam Outdoor v1/v2.
  • It's a macro lens!
    Think monocle, but for your Wyze Cam. 🧐 This special lens slips over compatible Wyze cameras to adjust the focus for close-up shots. See every little critter that sneaks up on your cam!
  • How close exactly?
    We know it will work when paired with our Bird Feeder, but this will also work for small pets in cages. Who wouldn't want to watch a backyard friends or smol dwarf hamsters taking a drink break. 🥺
1 of 2
See the lens in action with our Bird Feeder
1 of 2
Send videos and images of bird friends to wow@wyze.com! We'd love to share them.
