1 of 1
Wyze Accessory Bulb
Wyze Accessory Bulb
Porch bulbs, done brilliantly.
Quantity
Low stock
Got the Wyze Bulb Cam? Now get the light! Our Wyze Accessory Bulb is the trusty sidekick to the latest camera tech found in our Wyze Bulb Cam. No over-the-top features, just solid, reliable brightness that works like a charm, every time.
Features
- Simple & Bright:ย Delivers clear, dependable illumination at 800 lumens.
- Perfect Partner:ย Designed for Wyze Bulb Cam.
- Easy Peasy Install:ย Screws in like any standard E26 Bulb.
- Affordable Quality:ย Brighten your home without breaking the bank.
Specs
Materials & Colors
Model: WYZECBCAB
Body: Plastic
Bulb Base: Metal
Certifications: FCC, IC, UL, IP65
Power
120V AC Inputย Standard E26 Socket Only
8 watts
Lighting
Brightness: up to 800 lm
Color Temperature: 3000Kย
Controls: Manual, Ambient Light, Schedule, Wyze Automations, Motion-Activated Light (Requires Wyze Bulb Cam)
Connectivity and Compatibility
OS Requirements: Android 7.0+ or iOS 14.0+
Bluetoothยฎ: Bluetoothยฎ Low Energy (BLE), Bluetoothยฎย Linking: Up to 5 Wyze Accessory Bulbs per 1 Wyze Bulb Cam
In the box
1x Wyze Accessory Bulb
1x Quick Start Guide
FAQ
Q: Do I need Wyze Bulb Cam for the Wyze Accessory Bulbs to work?
A: While the Wyze Bulb Cam is not necessary, we highly recommend having at least one to enable in app functionality for Wyze Accessory Bulbs. Without the Bulb Cam, your Accessory Bulbs will only function like normal (not-smart) light bulbs. Without in app functionality, you can only turn them on and off with an external switch. If you want a smart bulb and not a cam, please checkout our Wyze Bulb White or Wyze Bulb Color.
Q: Can I change the brightness of the bulb?
A: Yes, Wyze Accessory Bulbs are dimmable via the Wyze app if you have a Wyze Bulb Cam setup. The brightness can be set up to 800 lumens, and has an Ambient Light mode which provides constant, low-level ambient lighting until motion is detected and automatically switches to increased brightness.
Q: Can I change the color temperature of the bulb?
A: No, Wyze Bulb Cam and Wyze Accessory Bulbโ€™s color temperature are fixed at 3000K and cannot be changed
Wide 160ยฐ View Sees More Space
Adjusts to Fit Most Light Fixtures
Manually extend, pan, and tilt the camera to find just the right angle.
Dimmable 800 Lumen LED Bulb
Traditional lightbulbs look boring. We built this bulb to look modern and classy (just like you). Customize the brightness on these long-lasting LED bulbs to achieve the perfect lighting.
Works with Wyze Accessory Bulb
Meet the sidekick that's full of bright ideas. It's 800 lumens, dimmable, and works exclusively with Wyze Bulb Cam.
Enhanced Group Light Control
Auto-connect up to 5 Accessory Bulbs for full coverage smart lighting.ย Customize brightness and set schedules. Motion-activated lights? Yeah, they can do that too!
24/7 Local Recording with MicroSD Card*
Donโ€™t miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.ย
  • Two-Way Audio
    Speak to people and pets from anywhere right from your smartphone.ย
  • Detection Features
    Get notified on your smartphone when motion is detected.ย
  • AI Notifications and Descriptive Alerts
    Customize your detections and notifications.ย Get a detailed alert of what's happening with Descriptive Alerts, available with Cam Unlimited Pro.ย Click to learn more.
  • Lighting Effects + Siren
    Flashing lights and a built-in siren will scare people away faster than a multi-level marketing invite.
Installation as easy as...
Brilliant setups
  • Accessory Bulb
    Auto-connect and synchronize the lighting of up to 5 Wyze Accessory Bulbs (sold separately) for full coverage smart lighting.
  • SD Card
