 88,000+ ratings on Amazon
Wyze Cam v3 Security System Bundle
Bundle & Save on Our #1 Best-Selling Home Security Camera
Build a DIY security system with Wyze Cam v3.
                        Features
                        Features
                        Specs
                        Specs
                    Wyze Cam v3 Device Details
Color -White, with black accents
Materials
Body: Polycarbonate
Lens: Glass + Plastic
Camera Dimensions - 52 mm (L) x 51 mm (W) x 58.5 mm (D)
Camera Weight - <98.8g
Phone Compatibility
Android 7.0+
iOS 12.0+
Night Vision
IR Lights: 4x940 nm, 4x850 nm
Day/Night Vision
Audio
Mic: ECM
Speaker: 80db, waterproof
Simultaneous 2-way Talk
Siren
Powering methods
Power Adapter: Indoor 5v/1A
Outdoor Power Adapter (sold separately)
Cable: 6 ft Flat USB Cable
Sensor - CMOS Starlight Sensor
LED Indicator - Front. Red + Blue
Connectivity - 2.4GHz WiFi
Storage - Local Storage (microSD card required), Cloud
Operating Temperature -5°F - 113°F (-20°C - 45°C)
Weather Resistance
IP65 Weather resistant
Indoor/Outdoor
Certifications - FCC, IC, UL and IP65 Certified
Languages - English
Warranty - 1-Year
                        In the box
                        In the box
                    Wyze Cam v3 - 4-pack
- Wyze Cam v3 x4
- Quick Start Guide x1
- Wall Mount Plate x4
- Wall Mount Plate Tape x4
- Screw Kit x4
- Indoor USB Power Adapter x4
- 6 Feet Outdoor Rated USB Cable x4
                        FAQ
                        FAQ
                        Support
                Support
Look on the bright side.
Pierce through darkness with the Starlight Sensor. This low-light amplifier shows dark areas in vivid, spectacular detail unseen even to the human eye.
            Starlight SensorThe Starlight CMOS sensor sees in environments up to 25x darker.
            Æ’/1.6 apertureReveals greater detail at night by capturing 2x more light.
            Starlight ISPReduces noise from low light & sharpens the image for astonishing clarity.
              "I’m having a really hard time thinking of a reason to even consider other cameras"
Now available in black
Sometimes subtle is better. In places where you want a less prominent security cam, we've got your back.
Indoor/Outdoor Home Security.
IP65 weather & dust resistance lets you see everything around your home, inside and out.
1080p HD Color Night Vision
Full control in the Wyze app
View live streams and motion-activated events at any time in the Wyze app. Get smart notifications with Cam Plus when a person, vehicle, pet, or package is detected.
Packed with Amazing Features
              Store Footage Locally on a MicroSD CardInsert up to a 128GB MicroSD card to store motion events or record 24/7 footage. We even built a custom Wyze app calendar so you can scroll through months of stored footage quickly.
              Works with Alexa and Google AssistantPull up live streams on Amazon Echo Show devices and Google Assistant devices. With Cam Plus, your Alexa devices will even tell you if a person is detected on your Wyze Cam.
              Smoke and Carbon Monoxide Alerts + Built-In SirenIf a Smoke/CO alarm goes off in your home, Wyze Cam v3's intelligent sound recognition AI will send a notification right to your phone, alerting you even if you are away from home.
Shop Wyze Cam v3 Accessories
Wyze microSD CardRegular price From $14.99 CADRegular priceUnit price / per-
Wyze Window MountRegular price From $17.99 CADRegular priceUnit price / per$17.99 CADSale price From $17.99 CAD
 Sale SaleWyze Lamp SocketRegular price From $23.98 CADRegular priceUnit price / per$29.98 CADSale price From $23.98 CADSale
Wyze Outdoor Power AdapterRegular price From $29.99 CADRegular priceUnit price / per
