1 of 14
Pan v4 Outdoor Bundle
The clearest Wyze cam yet.
What's in this bundle
$96.98 $106.97
The #1 best-selling 360° pan & 180° tilt Wyze camera is now back with 4K Ultra HD Quality. Paired with our Wyze Universal Outdoor Adapter which is IP67 weather-resistant, so you can safely use your Wyze Pan v4 camera without worrying about the weather.
Features
Wyze Cam Pan v4
- 4K Ultra HD Resolution with Color Night Vision
- 360° Pan and 180° Tilt Coverage
- AI-Powered Object Tracking
- Dual-Band Wi-Fi
- View from anywhere in the Wyze app
- Indoor/Outdoor IP65 Weather Rating
- Local MicroSD storage up to 512GB
Wyze Outdoor Power Adapter
- Easy installation - just plug it in!
- IP67 Weather Resistant
Specs
Wyze Cam Pan v4 Tech Specs
Color & Materials
- Color: White
- Finish: Textured Matte
- Materials: Body: Polycarbonate, Lens: Glass + plastic
Dimensions
- Dimensions (H,W,D): 4.91in x 2.48in x 2.17in (124.7mm x 63mm x 55mm)
- Weight: 274.8 g (0.61 lbs)
Video
- Resolution: 4K/8MP Resolution (3840 x 2160)
- Field of View: 105.4° (D), 88° (H), 46° (V)
- Pan Tilt Range: 360° (H) x 180° (V)
- Video FPS: Daytime - 20 fps, Nighttime - 15 fps
- Digital Zoom: 8x
- Color: White
- Dimensions: 78.7 mm x 62.5 mm x 29.4 mm
- Weight: 235 g
Universal Outdoor Adapter Cable Length:
- Total cable length: 19.68 ft (6m)
- AC cable length: 13.1 ft (3.4m)
- DC cable length 8.52(2.6m)
Universal Outdoor Adapter Compatibility: Works with Cam v3/v3 Pro/v4, OG series, Pan v3/v4, and Duo Cam Pan.
Audio
- Built-in 100dB speaker & microphone
Power
- 6 ft (1.8 m) Flat Type-C to USB-A
- Power adapter: Input - 110-240V (AC), Output - 5V/2A
Addition Details
- Night Vision: 2 IR LEDs (850 nm) + White Spotlight LED (60 Lumen)
- Color Night Vision
Sensor
- Image sensor: 1/2.7' CMOS
Storage
- Supports up to 512GB local storage (microSD card required - sold separately)
- Cloud (AWS) with Wyze Security Plan
Temperature
- Storage Temperature: -4°F-122°F (-20°C-50°C)
- Operating Temperature: -40°F-158°F(-40°C-70°C)
Weather Resistance
- IP65 Weather Resistant
- Indoor/Outdoor compatible
Connectivity & Compatibility
- Wi-Fi: 802.11a/b/g/n/ac/ax, 2.4/5 GHz, Wi-Fi 4/5/6
- Phone app support: Android 10.0+, iOS 16.0+
- Integrations: Alexa, Google Assistant, IFTTT
Languages
- English
Warranty
- 1-Year
In the box
Wyze Cam Pan v4
- Wyze Cam Pan v4 x1
- 6' microUSB Cable x1
- Power Adapter x1
- Mounting Kit x1
- Quick Start Guide x1
1x Wyze Cam Universal Outdoor Power Adapter
1x L-Shape Micro USB Connector Cable (Type C Female to L-Shape Micro USB Male)
1x Micro USB Connector Cable (Type C Female to Micro USB Male)
12x Wire Clips
12x Screws
12x Screw Anchors
FAQ
  • 4K Ultra HD Video Resolution
    Capture every detail with crystal-clear recording.
  • 360° Pan and 180° Tilt Coverage
    Control remotely via the Wyze app for full-room coverage.
  • AI-Powered Object Tracking
    Person, pet, and vehicle tracking with customizable priority.
  • Dual-Band Wi-Fi
    Maintain a strong connection on both 2.4 and 5 GHz networks.
1 of 4
Capture life in stunning 4K Ultra HD Resolution.
Crystal-clear video recording with a wide field-of-view captures every detail, day or night.
1080p resolution
Pan v4 (4k Ultra HD)
Follow only what matters with AI-Powered Object Tracking.
Person, pet, and vehicle tracking with customizable priority means Pan v4 follows the motion that’s important to you (and ignores the rest).
Dual-Band Wi-Fi
Faster, stronger connections.
ip65 weather resistance
Place it anywhere.
Wyze Cam Pan v4 is IP65 weather-resistant*, so it can operate in any weather.
*Note: Outdoor use requires Wyze Cam Universal Outdoor Power Adapter (sold separately, coming soon).
Integrated spotlight + Siren
More safety at night.
Want to see a robber wet their pants in 4K? Enable the motion-activated spotlight and motion warning. Or activate the 100dB siren.
Record every second
24/7 recording with a MicroSD Card.
Don’t miss a thing with continuous local recording to a microSD card up to 512 GB. No subscription required.
*Note: MicroSD cards sold separately.
LEVEL YOUR CAM UP ✨
Get total peace of mind by saving event videos to a secure cloud.
With a Cam Unlimited Pro subscription, you get up to 60-day cloud video backups, AI Video Search, Descriptive Alerts, and more.
Note: Wyze Cam Pan v4 works with Cam Plus, Cam Unlimited, and Cam Unlimited Pro.
Learn more about compatible plans
  • Traditional Night Vision
  • Color Night Vision ✨
Privacy Mode
Physical Privacy Mode.
Enable Privacy Mode in the Wyze app, and the camera lens points straight down to eliminate its field of view and turns off.
Connect with bluetooth®
Easy to set up.
No need to scan QR codes. Enjoy hassle-free setup with Bluetooth®. Your cam will be up and running within minutes.
Plug it in and go
Versatile mounting.
Four unique mounting options gives you the flexibility to secure your space exactly how you need to.
Works with smart assistants
Patrol your room with Pan Scan.
Set the camera’s patrol route with up to 4 custom waypoints.
You gotta see it to believe it.
Your life in 4K. Check out the unboxing video if you're curious about what's in the box or if you miss Kyle.
Your Wyze Cam Pan v4 comes bundled with our Wyze Universal Outdoor adapter. With IP67 weather-resistance you can keep your home safe without having to worry about the weather...or changing a battery! Win/Win!
