Get a FREE Wyze Video Doorbell + Chime this Wyze Week only.
Meet the ultimate smart home front porch security bundle. With Wyze Video Doorbell and Chime, view your front porch in 1080p HD and say hello with two-way audio. With Wyze Lock, unlock and lock the door remotely and view your lock history in the Wyze app.
Features
Features
View your porch in 1080p HD
Lock/unlock the front door remotely
View motion events and lock history
Works with Alexa and Google Assistant
Specs
Specs
Wyze Video Doorbell
Power: 16V-24V AC, ≥10VA (May use existing doorbell-chime circuit, or standalone transformer and wires.)
Weight: 1.7oz / 49gSize: 1.5'' x 3.25'' x 0.625''
Image Sensor: 2K (2048 x 1536)
Camera: F2.0 aperture, 2.7mm focal length, 1/2.8" CMOS
Image Quality: 1080p and 480p w/ 8x Digital Zoom
Frames per Second: 20 Daytime, 15 Nighttime
Audio: Built in Speaker & Microphone (with 2-way Audio & Noise/Echo Cancellation)
White LED (Fill Light): 6 x 5000K (daylight color temperature)
IR Night Light: 4 x 940nm Infrared LED
Connectivity: Direct to WiFi 802.11 b/g/n, 2.4GHz (5GHz WiFi not supported)
Sub1G: 906.8MHz, used for local connection between doorbell and chime.
IP65 Weather-resistant
Storage Temperature: -40 to 176°F (-40 to 80°C)
Operating Temperature: -4 to 122°F (-20 to 50°C)
Field of View: 120° Vertical x 88° Horizontal
Operating Systems: iOS 9.0 and Android 5.0 or later
Data Security: End-to-end encryption, HTTPS secure transfer protocol, AES 128-bit encryption
Wyze Chime
Chime Power: Standard US Power Outlet: 100V-240V, 0.1A, 50/60Hz
Weight: 2.0 oz / 56g
Size: 2'' x 2'' x 1.4''
Chimes: 5 modern, 4 classic doorbell, 3 animal sounds, 6 automation sounds, 1 intruder alarm
Lock
Color
Silver
Dimensions
4.9" Length x 2.5" Width x 1.3" Depth (2" including knob)
Weight
0.67 lb
Power Source
4x AA Batteries (included)
Battery Life
5-6 months (depending on usage)
Communication Method
Bluetooth, Zigbee
Range
To Keypad: 9', To Gateway: 50', BLE to phone: 16'
Compatibility
Android 5.0+, iOS 9.0+
Weather Resistance
Indoor use only
14°F - 131°F / -10°C - 55°C
Storage Temperature
-22°F - 158°F / -30°C - 70°C
Keypad (sold separately)
Color
Silver
Dimensions
3.7" Length x 1.3" Width x 1.0" Depth
Weight
0.1 lb
Power Source
2x AA Batteries (included)
Battery Life
4-6 months (depending on temperature)
Bluetooth
Range
To Lock: 9'
Compatibility
Weather Resistance
IPX5
-4°F - 140°F / -20°C - 60°C
Storage Temperature
Gateway
Color
White
Dimensions
2.1" Length x 2.1" Width x 1.2" Depth (1.9" including pins)
Weight
0.12 lb
Power Source
110-240V, ~60Hz
Battery Life
NA
Bluetooth, Zigbee, Wifi
Range
To Lock: 50', To Router: 50
Compatibility
Weather Resistance
Indoor use only
Storage Temperature
In the box
In the box
Wyze Lock x1
Wyze Lock Gateway x1
AA Batteries x4
Adhesive Strip x1
Mounting Plate x1
Adapter x3
Quick Start Guide x1
Wyze Video Doorbell x1
Wyze Chime x1
Wall Plate x1
Wedge (Horizontal, 30°) x1
Wire Caps x4
Bracket Screws x2
Screws & Expansion Tubes x2
Extension Wires x2
Fuse x1
FAQ
FAQ
