Front Porch Security Bundle
Capture all of the action happening in your yard.
Keep an eye on who's coming and going without breaking the bank. Get the new Wyze Video Doorbell v2 and a Wyze Cam OG to see everything on your front porch.
Features
Features
Specs
Specs
Video Resolution: 2K (2048 x 1536)
Video Format: H.264
Sensor Size: 1/2.8"
Aperture: F2.0
Focal Length: 2.1mm
Frame Rate: Day: 20FPS, Night: 15FPS
Field-of-View: Horizontal: 135°, Vertical: 103°,Diagonal: 166.8°
Power: 16V-24V AC,≥10VA
Microphone: ECM (Electric Condenser)
Zoom: Digital Zoom
MicroSD card: Up to 256G in FAT32 format
Cloud: When paired with a Wyze Security Plan
IP65 weather resistant
Operating temp: -4°F - 122°F (-20°C - 50°C)
Storage temp: -40°F - 176°F (-40°C - 80°C)
Wyze Cam OG
Power Adapter: Input - 110-240V (AC/DC) Output - 5V/1A
Video FPS: Daytime - 20 FPS Nighttime - 15 FPS
Video Encoding: H.264
Video Resolution: 1920 x 1080 (1080p)
2 spotlight (5000K, 40 lumens)
Weather Resistance: Indoor and Outdoor (IP65)
Operating: -4°F - 131°F (-20°C - 55°C)
Storage: -40°F - 158°F (-40°C - 70°C)
Power Cable Length: 6 ft (1.8 m)
Ports: 1 micro USB
Night Vision: 4 IR LEDs (850nm)
Digital Zoom: 8x
Field-of-View-OG: 121.4°(DFOV), 102.3°(HFOV), 54.1°(VFOV)
Audio: Built-in Speaker & Microphone; Noise & Echo Cancellation
Local Storage: Supports up to 256 GB microSD in exFAT format
Connectivity & Compatibility
IEEE802.11 b/g/n. Wi-Fi 2.4G b/g/n
Phone Compatibility: Android 9.0+, iOS 15.0+Integrations: Alexa, Google Assistant, IFTTT
Warranty
1 Year
In the box
In the box
Wyze Video Doorbell v2:
1x Video Doorbell Camera
1x Wyze Doorbell Chime Controller
1x Wall Plate1x Wedge (30°)
1x Installation Kit3x Wire Caps
2x Extension Wires1x Screw Kit
2x Long Screws
2x Short Screws
2x Wall Anchors
1x Quick Start Guide
Wyze Cam OG:
1x Plug-in Camera
1x Indoor Power Adapter
1x USB Cable
1x Wall Anchors
1x Wall Plate
1x Mounting Screw Kit (M4)
FAQ
FAQ
Around the clock front door monitoring.
2K Video Resolution with Head-To-Toe Viewing—Capture all porch arrivals and departures in greater detail.
- Local recording with MicroSD card (sold separately)
- Works with existing Doorbell Chime
- Two-way audio
- 3-6 seconds of pre-roll recording for motion events
- Motion-Activated Voice Deterrence alerts visitors that they are being recorded
Wyze Cam OG
Packed with power and features.
We’ve upgraded everything that matters most to make this a powerful and affordable plug-in cam.
- Load live HD video faster
- See in full color with 1080p Color Night Vision
- Speak and hear with clarity through your cam
- Set this up inside or outside
- Pro Tip: Mount a second Wyze Cam OG on top of one another to get a wider field of view
Night as clear as day.
