1 of 5
Floodlight + OG Security Kit
Style
Low stock
With this much lumen power, you'll dominate the dark, and spot the bad guys, with ease.
Features
Specs
Wyze Cam Floodlight v2
Color: White or Black
Finish: Matte
Mount: Wall/Ceiling
Body: Polycarbonate
Lens: Glass + Plastic
2 dimmable LED light panels
2800 total lumens of brightness 5000K color temperature
Dimmable: Yes
2K (2304 x 1296)
Night Vision
Color Night Vision
Hardwired 110 - 120V AC-4°F - 140°F (-20°C - 60°C)
IP65 Water Resistance
Safe for outdoor use
Wyze Cam OG
Power Adapter: Input - 110-240V (AC/DC) Output - 5V/1A
Video FPS: Daytime - 20 FPS Nighttime - 15 FPS
Video Encoding: H.264Video Resolution: 1920 x 1080 (1080p)
2 spotlight (5000K, 40 lumens)
802.11 b/g/n, 2.4 GHz Wi-Fi
Phone Compatibility: Android 9.0+, iOS 15.0+
Integrations: Alexa, Google Assistant, IFTTT
Weather Resistance: Indoor and Outdoor (IP65)
Operating: -4°F - 131°F (-20°C - 55°C)
Storage: -40°F - 158°F (-40°C - 70°C)
Power Cable Length: 6 ft (1.8 m)Ports: 1 micro USB
Night Vision: 4 IR LEDs (850nm)
Digital Zoom: 8x
Field-of-View-OG: 121.4°(DFOV), 102.3°(HFOV), 54.1°(VFOV)
Audio: Built-in Speaker & Microphone; Noise & Echo Cancellation
Local Storage: Supports up to 256 GB microSD in exFAT format
Connectivity & Compatibility
IEEE802.11 b/g/n. Wi-Fi 2.4G b/g/n
Warranty
1 Year
In the box
Wyze Cam Floodlight v2:
x1 - Wyze Cam Floodlight v2
x1 - Quick Start Guide
x1 - Mounting Accessory Kit
x2 -Bracket Screws (#6, #8, and #10)
x1 - Ground Screw
x1 - Floodlight Screw
x1 - Rubber Stopper
x1 - Mounting Bracket
x2 - Wire Nuts
x1 - Hook x
Wyze Cam OG (Standard):
x1 - Camerax1 - Indoor Power Adapter
x1 - USB Cablex1 - Wall Anchors
x1 - Wall Platex1 - Mounting Screws (M4)
FAQ
Wyze Floodlight v2
The dark doesn't stand a chance.
Delivering 2K HD video and vibrant color night vision, this outdoor security camera ensures your home always under watch.
The expansive 160° wide-angle view and advanced motion detection eliminate blind spots.
Enjoy a well-lit exterior with powerful 2800-Lumen LEDs, and let the 105dB siren add an extra layer of security.
Buy the v2 and get this free...
WYZE CAM OG
Packed with power and features.
We’ve upgraded everything that matters most to make this a powerful and affordable plug-in cam.
  • Load live HD video faster
  • See in full color with 1080p Color Night Vision
  • Speak and hear with clarity through your cam
  • Set this up inside or outside
  • Pro Tip: Mount a second Wyze Cam OG on top (with a stack kit) to get views from multiple angles.
One powerful Wyze app to control it all.
Control both smart floodlight cameras from the palm of your hand and get total peace of mind.
  • 24/7 Live Streaming
  • Access local recordings*
  • Setup detection zones
  • Available for Android & iOS
*Local recording requires the addition of MicroSD card
Add a Wyze Security Plan
Get better AI detections with Cam Plus
Instead of vague motion detections, you can now get phone alerts for Person and Package Detection with Cam Plus. Also enjoy unlimited 14-day cloud video storage and additional functionality.
