1 of 10
Bulb Cam + Free 32GB microSD
2K Camera Built into a Smart Bulb
What's in this bundle
$72.98 $79.97
Protect your home day and night with Wyze Bulb Cam, the 2-in-1 outdoor security camera and smart LED light bulb. Unlock continuous, local recording and time lapses for your Bulb Cam with the included 32GB MicroSD card — never miss a moment, whether it’s big or small!
Features
• Video Surveillance. Smart Lighting. Combined. - A powerful security camera combined with a smart light bulb to make it an all-in-one outdoor security solution that's conveniently powered by a light fixture.
• Wide 160° View Sees More Space - Protect more space with a wide field of view.
• Clear 2K HD Resolution with WDR and Color Night Vision - See all details in full color, day or night. WDR (Wide Dynamic Range) balances dark and light spots in the same scene for a more even picture.
• Adjusts to Fit Most Light Fixtures - Manually extend, pan, and tilt the camera to find just the right angle you need.
• Dimmable 800 Lumen LED Bulb - No need to install a dimmer switch. Use the Wyze app to adjust the brightness with just a tap.
• Group Light Control with Wyze Accessory Bulbs - Auto-connect and synchronize the lighting of up to 5 Wyze Accessory Bulbs (sold separately) for full coverage smart lighting.
• Lighting Effects - Coming soon. Set the vibe with Firefly mode. Ward off intruders with flashing lights. Activate Music Mode and boogie till the sun comes up.
• 24/7 Local Recording with MicroSD Card* - Don't miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.
• Two-Way Audio - Speak to people and pets from anywhere right from your smartphone.
• Free Detection Feature - Get notified on your smartphone when motion is detected.
• AI Notifications and Descriptive Alerts - Customize your notifications and only get notified when People, Pets, Packages, and Vehicles are detected. Get a detailed alert of what's happening with Descriptive Alerts, available with Cam Unlimited Pro.
• Bluetooth® Setup - No need to scan QR codes. Enjoy hassle-free setup with Bluetooth®.
• Alexa, Google Assistant, and IFTTT Support - Convenience and customization at your fingertips with integrations like Amazon Alexa, Google Assistant, IFTTT, and Wyze Automations.
• Maximizes Wyze Cam, Wyze Cam Outdoor and Wyze Cam Pan functionality with continuous recording and time-lapse video.
• With microSD card installed, video continues to record even if WiFi connection is interrupted.
• 32GB microSD card will hold approximately 2 days of HD video and 7 days of SD video.
• These recording times are rough approximations. Each situation is different and recording file sizes may take up more storage space based on factors such as lighting, scene movement, and the device itself. Also works with non-Wyze devices for local storage.
• Note on in-app settings:
- When live streaming in 360p, local footage will be available in SD or HD, whichever resolution you used most recently.
- When live streaming in SD, local footage will be available in SD.
- When live streaming in HD, local footage will be available in HD.
Specs
Wyze Bulb Cam Tech Specs
Materials & Colors
Model: WYZECBC
Body: Plastic
Lens: Glass and Plastic
Bulb Base: Metal
Certifications: FCC, IC, UL, IP65
Telescoping Length: 1.18 in (3 cm)
Power
120V AC Input
Standard E26 Socket Only
15 watts
Video
Resolution: 2K (2304 x 1296)
Field of View: 160° : 166° diagonal, 144° horizontal, 82.5° vertical
Frame Rate: Daytime: 20 FPS, Nighttime: 15 FPS
Functionality: Color Night Vision / IR Night Vision, Digital Zoom
Audio
Microphone: Built-in, digital
Siren: 95 dB at 4 in
2-Way Audio
Lighting
Brightness: up to 800 lm
Color Temperature: 3000K
Controls: Manual, Motion-Activated Light, Ambient Light, Schedule, Wyze Automations
IR Lights: 4x 850nm
Storage and Alerts
Alerts: Push notifications, Motion Warning
Cloud Storage: stored in the AWS cloud (Wyze Service subscription required)
Local Storage:
Supports 8 GB, 16 GB, and 32 GB microSD cards in FAT32 format
Supports up to 256 GB microSD cards in exFAT format
Connectivity and Compatibility
OS Requirements: Android 7.0+ or iOS 14.0+
Wi-Fi: IEEE 802.11 b/g/n 2.4 GHz, Wi-Fi 6
Bluetooth®: Bluetooth® Low Energy (BLE), Bluetooth® 4.2
Linking: Up to 5 Wyze Accessory Bulbs
Weather and Temperature
Weather Resistance:
Camera portion: IP65
Bulb portion: UL Damp
Operating Temperature: -4°F - 122°F (-20°C - 50°C)
Storage Temperature: -40°F - 176°F (-40°C - 80°C)
Warranty
1-year product warranty
Wyze MicroSD Card
Learn more about the MicroSD card in this bundle.
In the box
Bulb Cam
1x Wyze Bulb Cam
1x “Do Not Turn OFF” Sticker
1x Quick Start Guide
Wyze 32gb MicroSD Card32GB
1x MicroSDHC Memory Card x1 - for Wyze 32GB microSDHC Memory Card
FAQ
Manually extend, pan, and tilt the camera to find just the right angle.
Traditional lightbulbs look boring. We built this bulb to look modern and classy (just like you). Customize the brightness on these long-lasting LED bulbs to achieve the perfect lighting.
Works with Wyze Accessory Bulb
Meet the sidekick that's full of bright ideas. It's 800 lumens, dimmable, and works exclusively with Wyze Bulb Cam.
Enhanced Group Light Control
Auto-connect up to 5 Accessory Bulbs for full coverage smart lighting. Customize brightness and set schedules. Motion-activated lights? Yeah, they can do that too!
Don’t miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.
  • Two-Way Audio
  • Detection Features
  • Lighting Effects + Siren
    Flashing lights and a built-in siren will scare people away faster than a multi-level marketing invite.
Installation as easy as...
Brilliant setups
  • Accessory Bulb
  • SD Card
