Bird Feeder Cam v4 Bundle
Birdwatching on easy mode. Comes with everything you need to start.
Low stock
Bundle comes with Wyze Bird Feeder, Wyze Cam v4, and Wyze Outdoor Power Adapter. It's birdwatching on easy mode. View and record live video of every feathered visitor with Wyze Bird Feeder. The feeder's vibrant blue body and orange top is designed to attract a variety of birds. Use your favorite top-selling Wyze Camera to explore the world around you like never before. A must-have for the birder in all of us!
Features
Features
Easy Installation with 5 Mounting Options—Mount it on a wall, tree, pole, mounting cord, or suction cup - Wyze Bird Feeder adapts effortlessly to any outdoor or balcony space. The all-in-one kit is designed to meet your specific needs.
Compatible with Wyze Cams for Remote Birdwatching—Wyze Bird Feeder supports 6 different Wyze cameras, including Wyze Cam v3/v3 Pro/v4, Wyze Cam Outdoor v1/v2, and Wyze Battery Cam Pro.There's also a designated cover for an optional Wyze Solar Panel to minimize recharging.
Colorful, Weather-Resistant Design—This innovative design brings the vibrant world of wild birds right to your home with unmatched clarity and convenience. Whether it's rainy or sunny, Wyze BirdFeeder offers wild birds a cozy, temporary shelter to relax and have a snack.
Comes with a Universal Wyze Cam Lens Bracket—The included universal magnifying lens gives you high-definition, close-up views of visiting birds, enhancing your birdwatching experience with vivid and detailed images.
Works with the Wyze App for Live Streaming and Notifications—Tailored to bird enthusiasts, the Wyze app provides an immersive nature experience. Enjoy high-quality video and live streaming, easily shareable with friends and on social media.
Specs
Specs
Wyze Bird Feeder
Color: Blue and Orange
Material: Polycarbonate
Dimensions: 7.48 in x 10.12 in x 8.58 in (190mm*257mm*218mm)
Net Weight: 2.5 lb (1.13 kg)
Gross Weight: 3.42 lb (1.55 kg)
Bird Seed Capacity: 1 Liter
Weather Resistance: IP65 Weatherproof
Operating Temperature: -4°F to 122°F (-20°C to 50°C), Humidity < 90%
Warranty: 1 year
Wyze Cam v4
Colors: White and Grey
Body: Polycarbonate
Lens: Glass + Plastic
Lens FOV: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Sensor: CMOS Starlight Sensor
LED Indicator: Front. Red + Blue.
Dimensions: 2in x 2in x 2 3/8in
Weight: 0.49 lb (222 g)
Mounting: Stand, wall mount, ceiling mount, or magnetic wall mount (adhesive)
Power Adapter: Input 110-240 V (AC/DC), Output Indoor 5V/1A
Cable: 6-Foot Flat micro USB to USB-A
Resolution: 2.5K QHD (2560x1440)
Digital Zoom: 8x
Wide Dynamic Range (WDR): Yes
IR Lights: 4x850 nm
Day/Night Vision/Color Night Vision: Yes
Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
Video Encoding: H.264
Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Color: White
Dimensions: 78.7 mm x 62.5 mm x 29.4 mm
Weight: 235 g
Total cable length: 12.5 ft (3.8 m)
AC cable length: 3.9 ft (1.2 m)
DC cable length 8.5 ft (2.6 m)
Weather Resistance: IP67 Certification: FCC, UL
Warranty: 1-Year
In the box
In the box
Wyze Bird Feeder
Wyze Bird Feeder x 1
Food Tray x 1
Food Tray Stand x 1
Solar Panel Cover x 1
Camera Bracket x 1
Lens Bracket x 1
L-Shaped Bracket x 1
Suction Cup Bracket x 1
Pillar Connecting Piece x 1
Cable Tie x 1
Suction Cup x 2
Safety Cord x 1
Mounting Cord x 1
Screw Accessory Pack x 1
Screwdriver x 1
Quick Start Guide x 1
Wyze Cam v4
FAQ
FAQ
Q: Which Cams are compatible with Wyze Bird Feeder?
A: Wyze Bird Feeder is compatible with Wyze Battery Cam Pro (this is the camera included in this bundle), Wyze Cam Outdoor v1/v2, and Wyze Cam v3/v3 Pro/v4. If using a Wyze Cam that is not battery-powered, you'll need a Wyze Outdoor Power Adapter to plug it into power.
Q: Is Wyze Bird Feeder compatible with other non-Wyze Cams?
A: Wyze Bird Feeder was designed specifically for select Wyze Cams - from the housing to the lens bracket.
Q: Does Wyze Bird Feeder work with Wyze Solar Panel?
A: Yes, it works with Wyze Solar Panel, but our solar panel will only work with Wyze Battery Cam Pro. Truly hassle-free. The best part? There's a wireless Bird Feeder Bundle with both the solar panel and Wyze Battery Cam Pro.
Q: Can I control Wyze Bird Feeder from the Wyze app?
While you can view and manage the camera installed in the bird feeder from the Wyze app, Wyze Bird Feeder itself is not a connected or an IoT device. We say it's the smartest way to bird watch.
Q: How does it prevent squirrel invasions?
After much research and consultation, we’ve concluded that any attempt to prevent squirrels from visiting would be futile. Instead, we focused on making sure that the materials used will be able to withstand significant damage, which should prevent the squirrels from destroying the feeder itself. Right now, our priorities lie in making sure that no harm could come to our feathered friends.
Q: How does Wyze Bird Feeder dispense bird food?
It has a sloped food tray that slowly dispenses the bird feed. Yay gravity!
Wyze Bird Feeder
Birding on easy mode.
Weather-resistant for all seasons.
Birds of every feather will flock your way, no matter the weather. Come rain or shine, the durable polycarbonate design of Wyze Bird Feeder serves as a safe haven for wild birds to hang out and grab a bite.
Easy install with many mounting options.
Choose between 5 easy installation options—wall, tree, pole, cord, and suction cup. Place it anywhere you (or they) need it.
Compatible with Wyze Cams for remote birdwatching.
Wyze Bird Feeder supports various Wyze cameras, including Battery Cam Pro, Cam v3/v4, and Cam Outdoor v1/v2.
Macro Lens Adapter included.
It's like a monocle, but for your Wyze Cam. This special lens slips over compatible cameras correcting the focus to ensure you get clear up-close views of bird friends.
Compatible with Wyze Solar Panel (for battery cam setups).
There’s a designated space for a Wyze Solar Panel to minimize recharging for battery powered cameras.
Live stream video and get notifications with the Wyze app.
View, record, and get notified about every visitor with the Wyze app.
You're not just getting a bird feeder with this plug-in Cam v4 bundle.
Get the Wyze Bird Feeder, Wyze Cam v4, and Wyze Outdoor Power Adapter.
You'll get our latest flagship plug-in cam.
Get unmatched security with Wyze Cam v4; the clearest Wyze Cam ever made.
- Crystal-clear 2.5K QHD
- Color Night Vision
- Motion-activated spotlight
- 24/7 local recording
- Wi-Fi 6 support
- Works w/Alexa & Google
A safe way to keep your Wyze Cam up and running from an outdoor plug.
Ready for rain, snow, or shine. Wyze Outdoor Power Adapter is IP67 weather resistant so you can safely use your Wyze Camera outdoors.
- Long 12.5ft cable
- IP67 weather resistant
- Easy cable management
Share proof you DO have friends who like to visit!
Send videos and images of bird friends to wow@wyze.com! We'd love to share them.
⚠️ WARNING: THE ELUSIVE "FUR BIRD" ⚠️
Disclaimer: While our bird feeder is top-notch, it unfortunately doesn’t include a squirrel defense system. These tiny furry ninjas who’ve mastered the art of stealth and parkour will likely visit. So, sit back, relax, and enjoy the inevitable squirrel circus. You’ve been warned, friend.
