Wyze Outdoor Power Adapter
Ready for rain, snow, or shine.
Ready for rain, snow, or shine. IP67 weather-resistant, so you can safely use your Wyze Camera outdoors.
Universal Outdoor Adapter (Latest Model): Works with Cam v3/v3 Pro/v4, OG series, Pan v3/v4, and Duo Cam Pan.
Outdoor Adapter + L-shaped Adapter + USB-C Adapter: Works with Cam v3/v3 Pro/v4, OG series, Pan v3, and Battery Cam Pro.
Adapters will NOT work with OG Stack Kit.
Features
Features
- Easy installation, as simple as plugging it in
- Wyze Outdoor Adapter works with Wyze Cam v3/v4 and Cam OG series
- IP67 Weather Resistant
Specs
Specs
Color: White
Dimensions: 78.7 mm x 62.5 mm x 29.4 mm
Weight: 235 g
Outdoor Power Adapter Cable Length:
Total cable length: 12.5 ft (3.8 m)
AC cable length: 3.9 ft (1.2 m)
DC cable length 8.5 ft (2.6 m)
L-shaped Adapter: a 4.5 in. female-to-male weatherproof dongle with a 90 degree angled micro USB on the male end
Universal Outdoor Adapter Cable Length:
Total cable length: 19.68 ft (6m)
AC cable length: 13.1 ft (3.4m)
DC cable length 8.5 ft (2.6m)
Outdoor Power Adapter + L-shaped + USB-C Compatibility:
Outdoor Power Adapter works with Wyze Cam v3/Cam v4 and Cam OG series. Outdoor Power Adapter + L-shaped Adapter works with Wyze Cam Pan v3/Cam v3 Pro.
Outdoor Power Adapter + L-shaped USB-C Adapter works with Wyze Battery Cam Pro.
Universal Outdoor Adapter Compatibility: Works with Cam v3/v3 Pro/v4, OG series, Pan v3/v4, and Duo Cam Pan.
Powering Methods:
Input power: 100v-240v
Output power: 5v2A
Connector to camera: Micro USB
Connector to wall plug: 2 pin flat, US
Operating Temperature: -22℉ - 122℉ (-30°C - 50°C)
Weather Resistance: IP67 Weather Resistant
Certification: FCC, UL
Warranty: 1-Year
In the box
In the box
1x Wyze Cam Universal Outdoor Power Adapter
1x L-Shape Micro USB Connector Cable (Type C Female to L-Shape Micro USB Male)
1x Micro USB Connector Cable (Type C Female to Micro USB Male)
12x Wire Clips
12x Screws
12x Screw Anchors
1x Wyze Outdoor Power Adapter
8x Wire Clip
6x Screw
2x Attached Cable Wrap (White)
6x Screw Anchor
L-shaped Adapter
1x Weatherproof L-shaped Micro-USB Adapter
FAQ
FAQ
How long is the cable?
The total length of the cable is 12.5 ft (3.8 m), with the AC cord and DC cables together for the Original Wyze Outdoor Adapter. For our new Universal Adapter, the total length of the cable is now approximately 19.5 ft.
What accessories are included in the box?
Wyze Outdoor Adapter includes wire clips, screws, screw anchors, and a cable wrap. These accessories are designed to hold the adapter and cable to the wall.
Is a Wyze Cam included?
No, Wyze Outdoor Power Adapter does not come with a camera included.
What color options do you have?
Currently, the power adapter only comes in white.
Can I use this adapter to power any other product?
This product is compatible with other Wyze products that require 5V1A or 5V2A input. We cannot guarantee product performance if you are trying to use it for any other non-Wyze product.
