Wyze Duo Cam Doorbell
Two cameras. Two views. Double the porch protection.
Wyze Duo Cam Doorbell is our most advanced battery-powered video doorbell yet. Dual camera views for people and packages, 2K video and local storage, two-way audio, real-time AI detections and alerts, and motion-activated voice deterrence. Includes Wyze Wi-Fi Chime and Wyze Removable Battery Pack. You can enable 24/7 local recording when you add a MicroSD card (sold separately) and set up the doorbell with hardwired power.
Features
Features
Two Cameras. Two Views. Double the Porch Protection - One camera sees people, and another focuses on the doorstep for clearer package detection and alerts. The result? Double the porch protection with zero distortion.
2K Video Resolution with Color Night Vision - Capture all porch arrivals and departures in greater detail. Our award-winning starlight sensor amplifies low light for vivid color images even at night.
24/7 Local Recording with MicroSD Card - See what happened start to finish with continuous local recording. MicroSD card sold separately.Wi-Fi Chime Included - Receive notifications anywhere in your home. Compatible with all Wyze Cams and doorbells.
Removable Battery Pack - Eliminate downtime with a removeable and rechargeable battery that lasts up to 6 months on just one charge.Easy 1-Minute Installation - Mount without wires or screws with the adhesive plate quickly and easily.Two-Way Audio - Respond to visitors by simply pressing the "talk" button in the Wyze app.Free 12-Second Video Recordings - Get up to 14 days of cloud storage for clips captured on every doorbell press.
Motion-Activated Voice Deterrence - When enabled, a voice prompt plays to alert visitors that they are being recorded.
IP65 Weatherproof - Rated to withstand any weather.
Motion & Sound Notifications - Get instant notifications sent to your phone for any visitor or package delivery.
Dual-Band Wi-Fi Connectivity - Connects to 2.4 GHz or 5 GHz Wi-Fi networks.Alexa, Google Assistant, IFTTT Support - Convenience and customization at your fingertips with integrations like Amazon Alexa, Google Assistant, IFTTT, and Wyze Automations.
Specs
Specs
Wyze Duo Cam Doorbell Specs
Color & Materials
- Colors: Black/Silver
- Materials: Plastic body, resin lens
Dimensions
- 5.90in x 1.88in x 1.18in (150mm x 48mm x 30mm)
Weight
- 0.92 lbs (416 g)
Video
Video Resolution
- Front: 2K (2048 x 1536)Bottom: 1920 x 1080
- Frame Rate: Daytime: 20 FPS / Nighttime: 15 FPS
- Digital Zoom: 8x
- Camera FOV
- Front camera - Horizontal: 132°, Vertical:100°
- Bottom camera - Horizontal: 121°, Vertical: 60°
Audio
- Siren: 90 dB
- Audio: Two-Way Talk, simultaneous
- Mic Sensitivity: -42 ± 3 dB
- Motion Warning: “Hi, you’re currently being recorded.”
Additional Specs
Lighting
- IR light: 6x 850 nm
- PowerPort: Micro USB
- Power: Battery or AC (10-24V AC, 60 HZ)
Storage
- Local Storage: Supports up to 256 GB microSD in exFAT format
- Cloud Storage: Stored in the AWS Cloud
- Battery Capacity: 22.94 Wh, 6200 mAh
- Battery Type: Lithium-ion
- Output Voltage: 3.6 V
- Input Voltage: 5 V DC
- Charging Port: USB-C
- Compatibility: Wyze Battery Cam Pro, Wyze Battery Charging Dock, Wyze Duo Cam Doorbell
Connectivity & Compatibility
- Wi-Fi: IEEE 802.11 a/b/g/n 2.4 GHz & 5 GHz Wi-Fi
- Bluetooth® 5.0
- Phone Compatibility: Android 9.0+, iOS 15.0+
- Integrations: Alexa, Google Assistant, IFTTT
- Weather & Temperature Operating Temperature: -4°F-122°F (-20°C-50°C)
- Storage Temperature: -40°F-158°F (-40°C-70°C)
- Weather Resistance: Indoor and Outdoor (IP65)
Certifications
- FCC, IC, UL, IP65
Warranty
- 1 year
In the box
In the box
1x Wyze Duo Cam Doorbell
1x Wyze Wi-Fi Chime
1x Back Plate
1x Corner Kit
1x USB-C Charging Cable
3x Wire Nuts
1x Jump Wire
2x Extension Wires
3x Long Screws
3x Short Screws
3x Expansion Tubes
1x Adhesive Tape
1x Doorbell Detaching Pin
1x Removable Battery Pack
1x Quick Start Guide
FAQ
FAQ
Q: How long does it take to install Wyze Duo Cam Doorbell?
A: It takes ~30 seconds to use the included 3M adhesive to mount the doorbell. Using the included screws to mount it on a door frame takes <1 minute.
Q: Do I need a technician for installation?
A: No technician is required for installation, even if you choose to use the included hard-wired option for your existing doorbell wiring.
Q: Where can I install the doorbell?
A: Anywhere near your front door is a great choice since no wires are needed when you go fully wire-free. Make sure the height you choose is comfortable for visitors to press the button on your new doorbell.
Q: Does the doorbell use batteries? How long is the battery life?
A: Yes, Wyze Duo Cam Doorbell is powered by a removable battery pack. The battery life is 3-6 months with normal use.
Q: Is Cam Plus available on Wyze Duo Cam Doorbell?
A: Yes, the Wyze Duo Cam Doorbell can be used with Cam Plus or Cam Unlimited subscriptions. For more information about what these subscriptions unlock, please check out our Security Plans.
Q: Can I use my existing doorbell wiring to power Wyze Duo Cam Doorbell?
A: Yes, compatible wiring will allow the doorbell to charge while it’s mounted. Having constant external power will also allow your doorbell to record an additional 3-6 seconds of pre-roll video before an event, allowing you to get the whole picture.
Q: Does Wyze Duo Cam Doorbell include a chime?
A: Yes, one Wyze Wi-Fi Chime is included.
Q: Is Wyze Duo Cam Doorbell weather resistant?
A: Yes, Wyze Duo Cam Doorbell is is IP65-rated for outdoor installation. This means that it is "dust-tight" and protected against water sprays from any angle.
Q: Can I control the volume of my Wyze Wi-Fi Chime?
A: You can adjust the chime sound or volume in the Wyze app.
Q: Can I use 24/7 continuous recording with Wyze Duo Cam Doorbell?
A: You can enable 24/7 local recording on your Wyze Duo Cam Doorbell as long as you have a microSD card installed, and your doorbell is hardwired. No subscription required!
Two Cameras. Two Views. Double the Porch Protection.
Some is good. More is better. And Wyze Duo Cam Doorbell with TWO cameras and full porch coverage is the punch that'll send porch pirates packing all the way to Puerto Penasco!
Ding dong from anywhere. Hear alerts exactly where you want in your home. Built-in Wi-Fi enables you to trigger audio alerts with all Wyze Cams and Doorbells.
Take your doorbell to the next level with Cam Unlimited.
A Doorbell Camera Built for AI ✨
Person Detection + Facial Recognition 🧑
One camera sees people to clearly capture every visitor. Get next-level notifications with Facial Recognition so you know when it's your best friend or if it's mom.
Package Detection 📦
Another camera looks directly down at your doorstep. And we will tell you the moment your latest package of [REDACTED] arrives, but we can't remove the shame of your subscription.
Pet Detection 🐶
Unless your pet is a llama, you know they won’t always show up on your doorbell cam. Now you can spot the furball when they make their way to your front porch. See everything from your door to doormat to doggo.
Vehicle Detection 🚗
Utilize the top cam to record each vehicle that stops at your residence. You can monitor a delivery driver from the moment they park in front of your house to when they drop off the package.
Mount it in two shakes of a dog's tail with the included adhesive strips. No wires or screws. I'm paw-sitively certain you'll have it up in no time. You can also wire it if you really want to.
Two-Way Audio
Act like a celestial messenger who knows neither time nor space and answer your door from anywhere. Somehow "Please leave my curly fries right there" feels more dignified when replying via the Wyze app.
IP65 Weather Resistant
It's rated to withstand all the elements. Even the element of surprise. In fact, it's basically impossible to sneak up on this thing. Did we mention it has TWO cameras?
Local Recording with microSD
See what happened start to finish with local recording. MicroSD card sold separately.
⚠️ To enable 24/7 local recording you must add a microSD card and hardwire the doorbell cam.
Plus, get all the core features you love.
Dual-Band Wi-Fi
30° Corner Kit Included
An angled mounting wedge is included with every doorbell to help you achieve the perfect view.
Works with your favorite smart assistant. Use Wyze Automations for more control.
Pick the best video doorbell for you.
Duo Cam Doorbell NEW
FOV: Top: 132 x 100° / Bottom: 121 x 60°
Resolution: Top: 2K / Bottom: 1080p
Compatible Chime: Wyze Wi-Fi Chime
Installation: 3M adhesive or screw mounting
Local Storage: Supports up to 256 GB, 24/7 continuous recording is available when hardwired
Mounting Location: Anywhere
Power: Wyze Removable Battery Pack or Wired (AC 16-24 V)
Video Doorbell Pro
FOV: 150 x 150°
Resolution: 1440p+
Compatible Chime: Wyze Chime Pro
Local Storage: N/A
Power: Rechargeable Built-In Battery or Wired (AC 16-24 V)
Video Doorbell v2
FOV: 135 x 103°
Resolution: 2K
Compatible Chime: Existing mechnical chime
Installation: Screw mounting
Mounting Location: Requires existing wiring
Power: Wired (AC 16-24 V) only
