Wyze Bulb White
Wyze Bulb White
A smart, tunable LED bulb with 90+ CRI.
Low stock
Features
Features
Sun Match
Bring the outdoors in by having your lights automatically adjust their color temperature for optimal lighting or manually adjust in the Wyze app.
App and Voice Dimmable
Dial in the perfect brightness via app or voice control.
Sleep Routines
Wake up or fall asleep to custom lighting routines that gradually illuminate or darken with time.
High CRI
Color Rendering Index (CRI) measures how close a lightbulb’s light is to natural sunlight. A 90+ CRI rating means colors will look more natural under its light vs competitors which are often have a CRI of ~80.
Easy Setup
Set up multiple Wyze Bulbs simultaneously with the Wyze app. No complicated WiFi switching required.
Group Control
Group multiple bulbs together to control them all at the same time or individually.
Vacation Mode
When enabled, your lights automatically turn on/off according to a variable schedule to make it appear like you’re home when you’re away.
Automations & Schedules
Schedule lights to turn on/off at specific times or use Wyze devices to trigger custom light actions.
Voice Control
Control Wyze Bulb White with Alexa or Google Assistant.
Specs
Specs
Dimensions
4.6 in x 2.4 in x 2.4 in
Weight
.31 lbs
Lumens
30-800
Color Temperature
2700k - 6500k
90+
Beam Angle
230°
Power
9.5 watts
Working Voltage
AC 120V~60 Hz
Bulb Shape
A19
Base Type
E26
Life Expectancy
25,000 Hours
Communication Mode
802.11 b/g/n, 2.4GHz, Bluetooth
Integrations
Alexa, Google Assistant, IFTTT
Weather Resistance
Suitable for damp locations
Not for use in totally enclosed luminaires
Operating Temperature
-4°F - 104°F
Operating Humidity
0-85%
Certifications
CUL
UL
FCC
IC
CA Title 20
Prop 65
In the box
In the box
Wyze Bulb White x 4
Quick Start Guide x 1
FAQ
FAQ
What are the differences between the original Wyze Bulb and Wyze Bulb White?
Wyze Bulb White is the second generation of or original Wyze Bulb. We’ve made it faster and easier to set up bulbs, even allow you to set up multiple bulbs at the same time. We’ve also made it possible for Wyze Bulb White to get more dim than the original Wyze Bulb, increased the life expectancy, increased CRI, and made other minor improvements.
Can I use Wyze Bulb White with a dimmer switch?
Wyze Bulb White should only be dimmed from the Wyze app or via a voice assistant. We do not recommend installing Wyze Bulbs on a dimmer switch, but if you must, make sure the switch is at full power.
Can I use Wyze Bulb White outside?
Wyze Bulb White is rated for use in damp locations, but shouldn’t be directly exposed to the elements or used in a fully enclosed luminary.
Do I need a hub for Wyze Bulb White v2?
Nope! Just a 2.4GHz WiFi connection.
