1 of 10
Wyze Bulb Cam
Wyze Bulb Cam
Turn any light fixture into a security cam.
Style
It's a 2K smart security camera with Color Night Vision attached to the bottom of a 800 lumen LED smart bulb. This combo makes Wyze Bulb Cam the most convenient way to protect any outdoor space, all powered by any light fixture.
Features
- Video Surveillance. Smart Lighting. Combined. - A powerful security camera combined with a smart light bulb to make it an all-in-one outdoor security solution that's conveniently powered by a light fixture.
- Wide 160° View Sees More Space - Protect more space with a wide field of view. Clear 2K HD Resolution with WDR and Color Night Vision - See all details in full color, day or night. WDR (Wide Dynamic Range) balances dark and light spots in the same scene for a more even picture.
- Adjusts to Fit Most Light Fixtures - Manually extend, pan, and tilt the camera to find just the right angle you need. Dimmable 800 Lumen LED Bulb - No need to install a dimmer switch. Use the Wyze app to adjust the brightness with just a tap.
- Group Light Control with Wyze Accessory Bulbs - Auto-connect and synchronize the lighting of up to 5 Wyze Accessory Bulbs (sold separately) for full coverage smart lighting.
- Lighting Effects - Coming soon. Set the vibe with Firefly mode. Ward off intruders with flashing lights. Activate Music Mode and boogie till the sun comes up.
- 24/7 Local Recording with MicroSD Card* - Don't miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.
- Two-Way Audio - Speak to people and pets from anywhere right from your smartphone.
- Free Detection Feature - Get notified on your smartphone when motion is detected.
- AI Notifications and Descriptive Alerts - Customize your notifications and only get notified when People, Pets, Packages, and Vehicles are detected. Get a detailed alert of what's happening with Descriptive Alerts, available with Cam Unlimited Pro.
- Bluetooth® Setup - No need to scan QR codes. Enjoy hassle-free setup with Bluetooth®.
- Alexa, Google Assistant, and IFTTT Support - Convenience and customization at your fingertips with integrations like Amazon Alexa, Google Assistant, IFTTT, and Wyze Automations.
*MicroSD cards are sold separately.
Specs
Materials & Colors
Model: WYZECBC
Body: Plastic
Lens: Glass and Plastic
Bulb Base: Metal
Certifications: FCC, IC, UL, IP65
Telescoping Length: 1.18 in (3 cm)
Power
120V AC Input Standard E26 Socket Only
15 watts
Video
Resolution: 2K (2304 x 1296)
Field of View: 166° diagonal, 144° horizontal, 82.5° vertical
Frame Rate: Daytime: 20 FPS, Nighttime: 15 FPS
Functionality: Color Night Vision / IR Night Vision, Digital Zoom
Audio
Microphone: Built-in, digital
Siren: 95 dB at 4 in2-Way Audio
Lighting
Brightness: up to 800 lm
Color Temperature: 3000K Controls: Manual, Motion-Activated Light, Ambient Light, Schedule, Wyze Automations
IR Lights: 4x 850nm
Storage and Alerts
Alerts: Push notifications, Motion Warning
Cloud Storage: stored in the AWS cloud (Wyze Service subscription required)
Local Storage:
Supports 8 GB, 16 GB, and 32 GB microSD cards in FAT32 format
Supports up to 256 GB microSD cards in exFAT format
Connectivity and Compatibility
OS Requirements: Android 7.0+ or iOS 14.0+
Wi-Fi: IEEE 802.11 b/g/n 2.4 GHz, Wi-Fi 6
Bluetooth®: Bluetooth® Low Energy (BLE), Bluetooth® 4.2Linking: Up to 5 Wyze Accessory Bulbs
Weather and Temperature
Weather Resistance: Camera portion: IP65
Bulb portion: UL Damp
Operating Temperature: -4°F - 122°F (-20°C - 50°C)
Storage Temperature: -40°F - 176°F (-40°C - 80°C)
Warranty
1-year product warranty
In the box
1x Wyze Bulb Cam
1x “Do Not Turn OFF” Sticker
1x Quick Start Guide
FAQ
Q: Can I use Wyze Bulb Cam outdoors?
A: Yes, the camera part of the bulb camera is IP65 weatherproof and can be installed in outdoor sconces. However, most socket adapters are not waterproof. Please keep the socket connection from having direct contact with water.
Q: Does Wyze Bulb Cam support local storage?
A: Yes! Wyze Bulb Cam has a microSD card slot for local storage, and you can record 24/7 and store videos locally. It supports microSD cards up to 32GB in FAT32 and up to 256GB in exFAT format.
Q: Can I pan and tilt Wyze Bulb Cam from the Wyze app?
A: No, the camera position must be manually adjusted.
Q: Can I change the brightness of the bulb?
A: Yes, Wyze Bulb Cam and Wyze Accessory Bulb are dimmable via the Wyze app. The brightness can be set up to 800 lumens, and has an Ambient Light mode which provides constant, low-level ambient lighting until motion is detected and automatically switches to increased brightness.
Q: Can I change the color temperature of the bulb?
A: No, Wyze Bulb Cam and Wyze Accessory Bulb’s color temperature are fixed at 3000K and cannot be changed.
Q: Does Wyze Bulb Cam support 5 GHz?
A: No, it only supports 2.4 GHz networks.
Q: Can I sync Wyze Bulb White/Color with a Wyze Bulb Cam?
A: Wyze Bulb Cam supports Wyze Automations with both bulb cameras and Wyze Bulbs. For the best experience and lowest latency though, we recommend pairing Wyze Accessory Bulbs to your Wyze Bulb Cam.
Q: I have a very large sconce. Will Wyze Bulb Cam fit?
A: It fits most sconces with an inner depth of less than 7.87 in (20 cm), from socket base to sconce edge. For larger sconces, we recommend using a Wyze Lamp Socket and Wyze Cam v4.
Q: Are these devices compatible with Wyze Lamp Socket?
A: We recommend installing Wyze Bulb Cam and Wyze Accessory Bulb directly into the socket and not the Wyze Lamp Socket accessory.
Manually extend, pan, and tilt the camera to find just the right angle.
Traditional lightbulbs look boring. We built this bulb to look modern and classy (just like you). Customize the brightness on these long-lasting LED bulbs to achieve the perfect lighting.
Works with Wyze Accessory Bulb
Meet the sidekick that's full of bright ideas. It's 800 lumens, dimmable, and works exclusively with Wyze Bulb Cam.
Enhanced Group Light Control
Auto-connect up to 5 Accessory Bulbs for full coverage smart lighting. Customize brightness and set schedules. Motion-activated lights? Yeah, they can do that too!
Don’t miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.
  • Two-Way Audio
  • Detection Features
  • AI Notifications and Descriptive Alerts
  • Lighting Effects + Siren
    Flashing lights and a built-in siren will scare people away faster than a multi-level marketing invite.
Installation as easy as...
Brilliant setups
  • Accessory Bulb
  • SD Card
