Wyze Surge Protector
Power for the modern home.
Features
Features
- 3 USB ports, total 5V/3.1A, each 5V/2.1A max.
- 3-outlet surge protector with 268 joules suppression rating
- 15A Overload Protection: Product will automatically switch off when current reaches its limit and a manual reset is required for reuse.
- Flame retardant up to 1,380℉ (750℃)
20µA ground fault protection
- Outlets tested to be plugged in over 10,000 times
- Right-angle flat plug
- 4 non-slip rubber pads located on the bottom of the surge protector to prevent unwanted movement.
- Soft-white LED light indicator
- 4ft Power Cord (14 AWG)
- Specifications: AC 15A, 125V, 60Hz, 1875W
- Low profile design: 8.58″ (L) x 1.61″ (W) x 1.02″ (H)
- 12-month Wyze warranty
- UL and FCC certified
Specs
Specs
- 3 USB ports charge all of your devices simultaneously
- Right-angle flat plug fits behind furniture and into tight spaces while remaining securely in the wall
- 268J surge protector safeguards against power surges for small devices
- Recommended for smart cameras, smartphones, personal computers, and small appliances
- This is a non-internet connected device
In the box
In the box
- Wyze Surge Protector 1x
- Quickstart Guide 1x
FAQ
FAQ
Does this connect to the Internet?
