Wyze Handheld Vacuum
16,800Pa cleaning power from home to car
A powerful and compact cordless vacuum with a full accessory kit for spot cleaning anywhere from your car to your home. Whether it’s spills, pet hair, or just dust bunnies - there’s an attachment for that.
Features
Features
16,800 Pa Suction Power
The suction power of a tornado in a handheld, compact vacuum. Can absorb everything from fine dust mites to bread crumbs.
Brushless Digital Motor
Our 100,000 RPM motor is 3x better than motors with carbon brush loss.
Lightweight & Cordless
Use anywhere from the kitchen to your office to your car.
Attachments for Every Nook and Cranny
Included with your preorder, the flat nozzle, brush tool, crevice tool, and extension hose let you clean anywhere and everywhere.
Washable HEPA filter
Filters dirty or clogged? Simply rinse the HEPA filter and stainless steel prefilter screen with tap water and let dry.
30-min Cleaning Time
Clean for up to 30 minutes on a single charge.
Specs
Specs
Wyze Handheld Vacuum Device Details
Color
Black
Weight
19.8 oz
Battery and Charging
Charging Method
Type-C power cable
Charging input
5V-2A
Charging time
About 3 hours to 100%
Battery capacity
6,000 mAh
Rated voltage
10.8 V
Rated power output
120 W
Vacuum Operation
Dust cup volume
0.2 L
Noise level
73.8 dB(A)
Running time
30 mins in default mode
10 mins in max power mode
Suction power
9,000 PA in default mode
16,800 PA in max power mode
Recommended Temperature
Operating: -4°F - 140°F (-20°C - 60°C)
Charging: 32°F - 113°F (0°C - 45°C)
Storage: -4°F - 104°F (-20°C - 40°C)
Weather Resistance
None. Do not use outdoors.
In the box
In the box
- Wyze Handheld Vacuum x1
- USB Cable x1
- Charger x1
- Storage Bag x1
- Extension Hose x1
- Crevice Tool x1
- Flat Nozzle x1
- Attachment Adapter x1
- Brush Tool x1
- Quick Start Guide x1
FAQ
FAQ
How do I use my Wyze Handheld Vacuum?
1. Remove the vacuum from the packaging.
2. Fully charge the vacuum using the included Type-C power cable and charger. The status light will flash quickly when charged. Unplug the vacuum from power.
3. To turn on the vacuum and operate in default mode, long press the Power button for 2 seconds. For stronger suction, short press the Power button once.
4. To turn off the vacuum, long press the Power button again for 2 seconds.
Where can I use Wyze Handheld Vacuum?
Wyze Handheld Vacuum can be used on all dry surfaces to clean dry debris from dust mites to big crumbs. Ideal environments: home, car, office, etc.
Can it vacuum up liquids?
No, only use Wyze Handheld Vacuum on dry surfaces to clean dry debris.
Does the handheld vacuum come with any attachments?
Yes, all Wyze Handheld Vacuum orders come with 1 flat suction nozzle. But preorders come with 1 flat suction nozzle plus 1 brush tool, 1 crevice tool, and 1 extension hose.
Does Wyze Handheld Vacuum connect to WiFi?
No, Wyze Handheld Vacuum does not connect to WiFi. It is not an IoT device.
How do I clean the HEPA filter?
1. Rotate and remove the dust cup
2. Then rotate and remove the prefilter gauze.
3. Pull the HEPA filter out of the prefilter gauze and rinse it with tap water.
4. Once dry, reassemble the handheld vacuum.
How do I charge Wyze Handheld Vacuum?
Attach the included Type-C power cable to the vacuum and then attach the other end into an adapter compatible with 5V-2A. Then plug it the power adapter into a power outlet.
How long does it take to fully charge Wyze Handheld Vacuum?
About 3 hours from 0 to 100% battery.
How long does Wyze Handheld Vacuum operate when fully charged?
When fully charged, the handheld vacuum will work for up to 30 minutes of persistent use.
