1 of 6
Wyze Cam v3 Spotlight Kit
Maximize your Wyze Cam v3 by adding a spotlight.
$24.99 $24.99
Headlamps! They're not just for spelunkers and middle-aged joggers, folks. They're for Wyze Cam v3! And who's to say Wyze Cam v3 isn't a spelunking forty-something who likes to jog. Did you even bother to ask? Do you even care? No. You just want your precious stuff watched. Well, fine. Wyze Cam v3 can watch it even better with this state-of-the-art, motion-activated, IP65 rated headlamp.
Features
- Toggle on and off manually using the Wyze app.
- Automate using Rules in the Wyze app.
- Switch between low and high brightness levels.
- Control with 3rd party integrations such as IFTTT.
User Cases:
- Turn on the light automatically when motion is detected using Rules.
- Automatically turn on the light at night using - Rules for better visibility, then automatically turn it back off.
- Use low brightness for enhanced indoor use, then bring your cam outside and switch to high brightness for enhanced outdoor use.
Specs
Lumens: 70 lumens
Angle: 130 degrees
Power supply: 5V 1A
Dimension: 21.5*55.8*34.4mm
Connection: Micro USB
Rating: IP65
Number of LEDs: 5
Light temperature: 4000-5000K
Operating conditions: -4°F to 131°F (-20°C to 55°C)
Warranty: 1 year
In the box
- Spotlight x 1
- USB cable splitter x 1
***Wyze Cam v3 SOLD SEPARATELY
FAQ
Does the Wyze Cam v3 Spotlight Kit work with other Wyze cameras?
No. It is designed specifically to work with the Wyze Cam v3.
Does the Wyze Cam v3 Spotlight Kit come with a Wyze v3 Camera?
No. This is an add-on accessory for the Wyze Cam v3 which is sold separately.
With a beam of light, intruders take flight.
Friends and unwanted guests alike take center stage when the light is triggered by motion, custom Rules, or schedules.
Pierce through darkness.
From friends to unwanted guests, visitors take center stage when the light is triggered by motion, custom Rules, or schedules.
Lights up in any weather.
IP65 weather and dust resistance lets you place your camera anywhere to see everything inside and out.
  • Rules and Automations
    Wyze Cam Floodlight is fully integrated into your smart home ecosystem. Use a variety of automations and advanced settings from Vacation Mode to Rules to make it fit your needs.
  • Two-Way Audio
    Don’t just imply intruders are unwelcome with your bright floodlights. Make it explicit with two-way audio! Or strike up a conversation! There are stranger ways to make new friends.
1 of 2
