400+ ratings on Amazon
Wyze Cam OG Telephoto
Back to the basics, with a huge leap forward.
The 2023 generation of Wyze Cam has arrived. Now with quicker live-streaming, 3X faster notifications, improved 2-way audio, and a 3x telephoto lens. Indoor/outdoor*.
Features
Features
Wyze Cam OG Telephoto:
3x Closer
27° FOV
IP65 Weatherproof
Indoor/Outdoor Security
1080p HD Color Night Vision
Specs
Specs
Color: White
Finish: Matte
Dimensions: 1.89 in x 1.89 in x 1.89 in (48 mm x 48 mm x 48 mm)
Weight: 4.1 oz (116 g)
Power Cable Length: 6 ft (1.8 m)
Ports: 1 micro USB
Power Adapter Input: Input - 110-240V (AC/DC) Output - 5V/1A
Night Vision: 4 IR LEDs (850nm)
Video FPS Wyze Cam OG Telephoto: Daytime - 20 FPS Nighttime - 10 FPS
Video Encoding: H.264
Video Resolution: 1920 x 1080 (1080p)
Image Sensor: CMOS-Starlight Sensor (1920 x 1080)
Digital Zoom: 8x
Field-of-View-Tele: 27°(DFOV), 23.6°(HFOV), 13.6°(VFOV)
Audio: Built-in Speaker & Microphone; Noise & Echo Cancellation
Local Storage: Supports up to 256 GB microSD in exFAT format
Wi-Fi: 802.11 b/g/n, 2.4 GHz Wi-Fi
Operating Temperature: -4°F - 131°F (-20°C - 55°C)
Storage Temperature: -40°F - 158°F (-40°C - 70°C)
Integrations: Alexa, Google Assistant, IFTTT
Mounting Method: Stand, wall mount (M4 screw), or ceiling mount (M4 screw)
Weather Resistance: Indoor and Outdoor (IP65)
In the box
In the box
Indoor Power Adapter
USB Cable
Wall Anchors
Wall Plate
Mounting Screws (M4)
Quick Start Guide
FAQ
FAQ
What is the difference between Wyze Cam OG Telephoto and the Wyze Cam OG standard?
There are two key differences: The telephoto camera has a 3x telephoto lens, while the standard OG camera has an integrated spotlight. Both are great cameras with all of the features you know and love. Use Wyze Cam OG to monitor your home with a wide angle lens. Use Wyze Cam OG Telephoto to clearly monitor points-of-interest that are further away.
Can I use Wyze Cam OG Telephoto on its own, without a Wyze Cam OG?
Yes, both cameras can be used as standalone cams. But we like using them both together - you get the OGās integrated spotlight, Wyze Cam OG Telephotoās closer details, and the ability to view the livestream of both cameras at the same time.
Is Wyze Cam OG Telephoto wireless or battery-powered?
No, Wyze Cam OG is not wireless or battery powered. It is powered via the included 6 ft USB cable.
Can I use Wyze Cam OG Telephoto outdoors?
Yes, Wyze Cam OG is IP65-rated and can be used both indoors and outdoors.
How many cameras can I stack together?
You can stack 2 total cameras together, in any combo! That could be a Wyze Cam OG and a Wyze Cam OG Telephoto, or two Wyze Cam OG cams, or two Wyze Cam OG Telephoto cams.
What is the resolution of Wyze Cam OG Telephoto?
1920 x 1080p Full HD.
What is the frame rate of Wyze Cam OG Telephoto?
Day: 20 frames per second (fps); Night: 15 fps.
Does Wyze Cam OG Telephoto support 5 GHz Wi-Fi?
No, Wyze Cam OG Telephoto only supports 2.4 GHz networks.
What is Color Night Vision?
Wyze Cam OG Telephoto is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night.
Is Wyze Cam OG Telephoto compatible with Wyze Web View?
Yes, Wyze Cam OG Telephoto is compatible with Wyze Web View.
Can I use Wyze Cam OG Telephoto on its own?
Yes, the telephoto cam can be used as a standalone camera, without a Wyze Cam OG. But we like using them both together - you get the OGās integrated spotlight, Telephotoās 3x closer details, and the ability to view the livestream of both cameras at the same time.
Yes, Wyze Cam OG Telephoto is IP65-rated and can be used both indoors and outdoors, rain or shine.
Day: 20 frames per second (fps); Night: 10 fps.
What cameras have the Picture-in-Picture functionality?
Only Wyze Cam OG and Wyze Cam OG Telephoto have Picture-in-Picture functionality.
Can I use Picture in Picture to view two Wyze Cam OGs or two Wyze Cam OG Telephoto cameras at the same time?
Yes. You can use Picture in Picture to view two Wyze Cam OGs or two Wyze Cam OG Telephoto 3x cameras at the same time. It is not limited to only Wyze Cam OG + Wyze Cam OG Telephoto viewing.
Are either Wyze Cam OG or Wyze Cam OG Telephoto Cam Plus Lite compatible?
No, neither camera is compatible with Cam Plus Lite. Cam Plus Lite only supports cameras released during or before April 2022.
Does Wyze Cam OG Telephoto have a spotlight?
No, only Wyze Cam OG has a spotlight.
Will the Wyze Stack Kit be available in Canada?
We are doing our best to release this in the upcoming months. Expected time frame would be Summer or Fall 2023.
Do Wyze Cam OG and Wyze Cam OG Telephoto Cameras take microSD cards for local storage?
Yes. Both cameras take all Wyze microSD cards up to and including 256GB microSD cards.
IP65 Indoor/Outdoor Security
3x Telephoto
Camera Lens
Motion Detection
Alerts
Meet Wyze Cam OG Telephoto.
The ultimate indoor/outdoor security cam featuring 3x Telephoto lens.
Capture the little things with 3x zoom.
Emphasize and bring faraway subjects closer. Deter potential bad guys with a 3x telephoto lens and a 90-decibel user-activated siren.
Watched a black and white movie recently? We haven't either, because every detail matters. That's why we've made Color Night Vision standard across all of our security cameras.
Color Night Vision with Starlight Sensor
Classic Night Vision
Get 3x faster motion notifications.
Upgraded two-way audio.
What was that? Better audio you ask? Yeah we hear you loud and clear. An upgraded microphone andĀ revamped speakerĀ provideĀ enhanced clarity.
Biscuits AND gravy. Rainbows AND unicorns. Jay-Z AND Beyonce. Local storage AND smarter security options. š
Supports all Wyze microSD cards, up to and including 256GB.
Two cameras, two views...
Wyze Cam OG is a wide-angle security camera to view the whole picture, but we also created Wyze Cam OG Telephoto that uses a 3x telephoto camera to magnify the details without losing image quality.
Captured with the Wyze Cam OG
