1 of 7
3,200+ ratings on Amazon
Put the outside world on mute
Color
Style
$109.99 $109.99
Like a symphony playing just for you.
Features
Hybrid Active Noise Cancellation
40dB of noise reduction to put the outside world on mute.
Wyze Headphones use hybrid active noise cancellation through 2 feedback microphones and 2 feed-forward microphones.
Transparency Mode
Transparency mode lets the outside world in and amplifies your surroundings. It's so clear, it's as if you’re not even wearing headphones.
Quick Conversation Mode
Have a quick chat without removing your headphones.
Simply cover the right earcup with your hand to quiet your audio so you can have a clear conversation, conveniently.
Dual Bluetooth Device Connection
Connect to your devices, wirelessly with Bluetooth 5.0.
Wyze Headphones come with the newest version of Bluetooth, which support dual device connection. Stay connected to your phone while listening on your computer, too.
Auto Pause
Wyze Headphones hit pause for you.
Have to take your headphones off for a second? They'll pause your content for you, automatically. When you put them back on, the content turns back on, too.
Touch Controls
Your headphones come with built-in touch controls so you can manage what you're listening to without looking at your phone. Tap twice for Alexa, and cover to enter Transparency Mode.
20-Hour Battery Life
Keep the beat going on and on and on…
Enjoy 20 hours of battery life when listening to music or taking calls while connected via Bluetooth. That’s with noise cancellation turned on.
Quick Charge
10 minutes = 4 hours.
Plug your Wyze Headphones in for 10 minutes, and keep your music playing 'til the workday is done.
Alexa Built-in
Ask Alexa for the weather, to play music, and virtually anything else with a double-tap of your right earcup, no Echo speaker required. You don’t even have to say “Alexa!”
Specs
Headphones Weight and Materials
Weight
9.9oz
Headband material
Multilayer composite of stainless steel, EVA foam, and plastic, covered in protein leather
Earcup cover material
ABS plastic and PC with special coating for touch gestures
Ear cushion material
Memory foam covered in protein leather
Bluetooth Specification
Bluetooth range
33 ft (10 m)
Bluetooth version
Bluetooth 5.0
Bluetooth codec
SBC, AAC
Multiple device connection
Supports two device connections at the same time
Speaker
Driver dimensions
40 mm dome type driver (copper wire voice coil)
Magnet material
Neodymium
Diaphragm
High transient dual TPU composite diaphragm
Frequency response over Bluetooth
20 - 20,000 Hz (44.1 kHz sampling rate)
Frequency response over line-in
20 - 38,000 Hz
Sensitivity
113 dB/mW @1 kHz
Total harmonic distortion
<0.5% 1 mW/1kHz
Impedance
32 Ω
Battery
Charging method
USB Type-C
Battery life
Up to 20 hours of music or call with high noise cancellation
Charging time
Around 2 hours
10-Minute quick charge
Up to 4-hour playback time
Charging temperature
41 - 95 ºF (5 - 35 ℃)
Battery type
Lithium-ion rechargeable battery
Battery capacity
1,000 mAh DC 3.7V
Microphones
6 total microphones
4 microphones for active noise cancellation
2 microphones for voice pickup
Voice microphones
Sensitivity
-32 dB at 1kHz
Directivity
Omnidirectional
SNR
74
Frequency response
50 - 10,000 Hz
Impedance
2.2 kΩ
Control Input
Power/Bluetooth button
Single press to turn on and off
Press and hold to enter pairing mode
Noise cancellation button
Single press to switch between noise cancellation modes
Volume +/- buttons
Single press to adjust volume
Play/Pause button
Music playback: single press to play/pause, double-press to skip forward, triple-press to skip backward
Call: single press to start/end the call, press and hold to reject a call
Voice assistant: press and hold to activate voice assistant
Touchpad
Double-tap to activate the voice assistant, or mute and unmute in calls
Cover to enable Quick Conversation mode
Environment
Operating environment
31 - 104ºF (0 - 40℃), humidity < 95%
Storage and transporting environment
-4 - 140ºF (-20 - 60℃), humidity < 95%
In the box
- Wyze Headphones x1
- USB Type-C Cable x1
- Carrying Pouch x1
- Audio Cable x1
- Quick Start Guide x1
FAQ
What is the expected battery life?
Up to 20 hours of music playback and call time.
Do the headphones work without the Wyze app?
Yes, all you need is a Bluetooth connection to use the headphones. If you want to use more advanced features, like touch controls and the equalizer, you will need the Wyze app.
Are Wyze Headphones wireless?
Yes! Wyze Headphones are wireless and connect via Bluetooth, but can also be used with the included 3.5mm headphone jack.
How do I set up my Wyze Headphones?
Download the Wyze app, and click the plus sign + > Add Device > Wyze Headphones. Follow the setup instructions.
Do Wyze Headphones come with a case or pouch?
Yes, they include a cloth carrying pouch.
Can you adjust the audio levels?
Yes, you can control the bass, mids, highs, and more using the equalizer in the Wyze app.
What kind of noise cancelling do they use?
Hybrid active noise canceling through 2 feedback microphones and 2 feed-forward microphones, with a 40dB noise reduction depth.
Can you adjust the noise cancelling levels?
Yes, you can switch between High ANC, Low ANC, and Transparency mode in the Wyze app and on the headphones.
Do they produce mono, stereo, or surround sound?
Wyze Headphones produce stereo sound.
What kind of battery do they use?
A DC 1000mAh lithium ion battery.
Are they compatible with gaming consoles and Bluetooth-capable computers?
Yes, Wyze Headphones can connect to Bluetooth-capable devices like gaming consoles and computers.
See how real people react to Wyze Headphones
You’ll think the rest of the world is standing still.
40dB Quick On/Off Hybrid Active Noise Cancellation (ANC).
Equipped with four noise-cancelling microphones and an ultra-fast processor, outside noise is reduced to a whisper so you can stay focused while the world buzzes around you.
For when you want to break the silence.
Transparency Mode
Outside sounds are amplified through your headphones with just a touch so you can listen for your coffee order while enjoying music.
Wear Detection
Audio automatically pauses when your headphones are removed and resumes when they’re put back on saving your spot in the song and battery.
Quick Conversations
Gently touching your right earcup pauses audio and enables Transparency Mode allowing you to join a conversation at a moment’s notice without taking your headphones off.
Your own private symphony.
World-class engineering and proprietary AI meets precision-tuned premium hardware. Prepare for an audio experience normally reserved for the “top shelf” brands.
Dual TPU Composite
Diaphragm Drivers.
Deep bass, stable mids, and crisp highs brought to you by
dual 40mm drivers and a range of frequencies up to 38kHz transport you to the front row of your favorite concert.
In short, these headphones mean business.
Customize the perfect listening experience in the Wyze app.
Create and save your own adjustments and custom preferences or choose from premade selections optimized for music, movies, gaming, and more.
So comfy you'll forget you're wearing them.
Responsive memory foam and elongated earpads delicately embrace the ear for a superior, fatigue-free fit.
Intuitive touch and tap.
Use the controls located on your headphones to answer calls, adjust volume, activate your voice assistant, or pause/play/skip tracks.
Collapsible content
Answer calls without touching your phone
Your voice is now your light switch. Command your lights with your voice by asking Alexa or Google Assistant to turn them on/off, adjust brightness, or change color.
Be heard clearly in a room full of chatter
Dual voice-isolating microphones.Dedicated microphones isolate your voice from surrounding chatter so your voice is crystal clear on calls.
Move freely and stay connected
With Bluetooth 5.0 and two connected devices at once.Roam around your home or office with fully wireless headphones that can connect to two devices at once. Jump from music on your laptop to incoming calls on your phone without resetting your Bluetooth connection.
Access music, weather, and more with voice assistants
Use Amazon Alexa built-in or your device’s native voice assistant (Siri, Google Assistant, Bixby).Leave your phone in your pocket and ask Alexa or your phone’s native voice assistant to access information, set reminders, play music, and more all with your voice.
