1 of 6
Wyze Buds
Wyze Buds
Your body-rocking audio partner from home to gym.
$79.99
⚠️ Final sale. Item not eligible for exchange or return.
Features
Premium Sound Quality
A 10.5 mm audio driver serves up powerful bass and high-resolution sound for music and calls. A molded enclosure ensures your bass beats hit hard.
4-Microphone Voice System
Two directional mics per bud separate your voice from the noise, so you are heard loud and clear.
Up to 27 Hours of Battery Life
Wyze Buds last up to 7 hours on a single charge - 2 hours longer than most earbuds. Plus, get up to 20 hours more in the charging case. 15-minute quick charge in the case provides up to 2 hours of playback.
Comfort with 5 Sizes of Silicone Ear Tips
Wyze Buds come with 5 sizes of silicone tips in XS, S, M, L, and XL, to make your ears comfortable all day long.
Wyze Buds Limited Edition Electric Green (SOLD OUT) comes with 3 sizes of silicone tips in S, M, and L, and two electric green ear tips in S and M.
Customizable EQ
Tune Wyze Buds to your liking by adjusting the equalizer in the Wyze app. Create and save your own custom preferences or choose pre-made selections that optimize for music, sport, voice, and more.
Auto Pause
Sensors recognize when Wyze Buds are in your ear and automatically play/pause your music like a bookmark for your bass drop.
Custom Touch Controls
Tap to pause, play, skip tracks, and answer calls without digging out your phone. Assign custom gestures in the Wyze app.
Alexa Built-in* and Voice Assistants
Instantly connect to Amazon Alexa to play your favorite music, check the weather, get the news, and more. Compatible with your phone’s native smart assistant (Siri, Bixby, Google Assistant).
Alexa is optimized for smartphones running Android 6+. iOS requires the Alexa app to be running in the background.
Specs
Earbuds Weight and Materials
Earbud dimensions
1.04 in x 0.81 in x 0.89 in
Case dimensions
2.25 in x 1.07 in x 1.75 in
Earbud weight
0.17 oz each
Case weight
1.20 oz
Earbud materials
Plastic with silicone ear tips
Case materials
Plastic
Sweat and weather resistance
IPX5 sweat and
weather resistant
Speaker
Driver dimensions
10.5 mm dynamic driver
Frequency range
20 - 20,000 Hz
Total harmonic distortion
<1% 1 mW/1kHz
Audio Latency
~170ms
Bluetooth Specifications
Bluetooth version
Bluetooth 5.0
Bluetooth codec
SBC, AAC
Device connection
Single device connection
Battery Life
Earbuds
Up to 7 hours of playback time
Case
Up to 20 hours of playback time
15-minute quick charge - Up to 2 hours of playback time
Charging
Charge with a USB Type-C cable
Charging Time
Earbuds ~1 hour of charging time
Case ~1 hour of charging time
Operating and Storing Environment
Operating Temperature
32°F - 104°F (0ºC - 40ºC) with 85% Relative Humidity
Storage Temperature
-13°F - 131°F (-25ºC - 55ºC)
In the box
- Wyze Buds x1
- Charging Case x1
- USB Type-C Cable x1
- Silicone Ear Tips x5 (5 Sizes)
- Quick Start Guide x1
FAQ
What is the difference between Wyze Buds and Wyze Buds Pro?
Wyze Buds provide you with your everyday needs, like longer battery life and a more compact case. Wyze Buds Pro is an upgraded model, with premium features like Active Noise Cancellation (ANC) and wireless charging.
Can I use just the left or the right earbud?
Yes, you can use a single earbud for your music and calls. You will need both earbuds to update your Wyze Buds settings in the Wyze app.
What is the expected battery life?
Up to 27 hours. The earbuds provide up to 7 hours of playback time on a single charge. The charging case provides up to 20 hours of music playback time.
Are Wyze Buds comfortable enough to wear all day?
Yes, Wyze Buds come with 5 sizes of silicone ear tips to fit your ears comfortably.
Will Wyze Buds work without the Wyze app?
Yes, you only need a Bluetooth connection to use the earbuds. If you want to use more advanced features, like customizing the EQ, touch controls, and setting up your voice assistant, you'll need the Wyze app.
Can I connect Wyze Buds to two devices at the same time?
No, Wyze Buds can only connect to one device at a time. You can switch devices by pressing the Pairing button on the charging case. Wyze Buds can remember up to 8 devices.
Can I use Wyze Buds with Amazon Alexa?
Yes, Alexa is built-in to the buds. The feature is optimized for Android, though. If on iOS, you must force close the Wyze app and keep the Amazon Alexa app running in the background to use Alexa.
How do I set up my Wyze Buds?
Download the Wyze app, and click the + plus sign > Add Device > Lifestyle > Wyze Buds. Follow along in the app to set up your new earbuds.
Can I customize the EQ of Wyze Buds?
Yes, tune Wyze Buds to your liking by adjusting the equalizer in the Wyze app. Create and save your own custom preferences or choose pre-made selections that optimize for music, movies, voices, gaming, and more.
Can I customize the touch controls of Wyze Buds?
Yes, customize the touch controls for your Wyze Buds in the Wyze app.
What is Transparency Mode?
Transparency Mode lets you hear the surrounding environment as if you are not wearing your earbuds. Listen to your family or safely listen to music near traffic.
Do they produce mono, stereo, or surround sound?
Wyze Buds produce stereo sound.
What kind of battery do they use?
Lithium ion battery.
Can I use third-party ear tips?
We don’t recommend it. The charging case is molded for Wyze Buds with the original ear tips. Third-party ear tips may not fit into the charging case.
Can I charge Wyze Buds with wireless chargers?
No, Wyze Buds can only be charged with a USB-C cable. If you are looking for earbuds with premium features like wireless charging, check out our Wyze Buds Pro!
Are they compatible with gaming consoles and Bluetooth-capable computers?
Yes, Wyze Buds can connect to Bluetooth-capable devices like gaming consoles and computers. But be sure to check your other device’s compatibility.
10.5mm audio drivers deliver bone-rocking bass from lace up to cool down.
Wyze buds are engineered to deliver an intensified, bass-driven sound to help propel you toward your fitness goals.
Choose the perfect fit so you can keep moving.
Keep moving with phone-free touch controls.
Keep the interruptions to a minimum with customized smart touch controls that don't skip a beat. Tap twice to play/pause. Tap three times to activate the voice assistant.
  • Wyze Buds
    -30 dB passive noise reduction
    -Up to 27 hrs of battery life
    -4-microphone system
  • Wyze Buds Pro
    -40 dB active noise cancellation
    -6 microphone system
    -Wireless charging
    Learn More
