1 of 8
Wyze Buds Pro
Wyze Buds Pro
Welcome to a quieter world with Active Noise Cancellation
$114.99
Wyze Buds Pro is more than just a bud; it's a professional bud. It gets paid to bud. It takes its budship to a level that the casual buds, the weekender and hobbyist buds, can't understand. Active noise-cancelling. Three voice-isolating microphones. An 18 hour battery life. Wireless charging. Cheap. Yeah, that's right. Cheap. Wyze Buds Pro has elevated its professional budship to a level that does not require financial validation. It buds for the love budding! The way budding was meant to be.
Features
40dB Active Noise Cancellation (ANC)
40 decibels(dB) of noise reduction to mute the world. Wyze Buds Pro uses state-of-the-art hybrid active noise cancellation through 2 feedback microphones and 2 feedforward microphones. Additionally, Wyze Buds Pro reduces wind noise by 10dB.
6 Microphone Voice System
6 directional microphones work together to capture your voice so the person you're talking to can hear you crystal clear.
Up to 18 Hours of Battery Life
Get up to 18 hours of music playback time in one charge. Wyze Buds Pro plays up to 4.5 hours with noise cancellation on and up to 6 hours with noise cancellation off. The charging case provides up to 13.5 hours of charge for music playback.
Wireless Charging
Charge your Wyze Buds Pro wirelessly with Qi-certified wireless chargers. Make the most out of your wireless product.
Transparency Mode
Hear what's happening around you while the music's playing. Transparency Mode lets you hear the surrounding environment as if you are not wearing your earbuds. Listen to your family or safely listen to music near traffic.
Specs
Earbuds Weight and Materials
Earbud dimensions
1.19" x 1.00" x 0.87"
Case dimensions
2.57" x 1.85" x 0.98"
Earbud weight
0.19 oz each
Case weight
1.47 oz
Earbud materials
Silicone
Case materials
Plastic
Bluetooth Specification
Bluetooth version
Bluetooth 5.0
Bluetooth codec
SBC, AAC
Device connection
Single device connection
Speaker
Driver dimensions
10 mm dynamic driver
Frequency range
20 - 20,000 Hz
Total harmonic distortion
<0.7% 1 mW/1kHz
Sweat and weather resistance
IPX4 sweat and weather resistant
Battery Life
Earbuds
ANC On: Up to 4.5 hours
ANC Off: Up to 6 hours
Case
ANC On: Up to 13.5 hours
ANC Off: Up to 18 hours
15-minute quick charge
Up to 1 hour of playback time.
Wired and wireless charging
Wyze Buds Pro allows you to charge with either a USB Type-C cable or a Qi-certified wireless charger.
Charging Time
Earbuds: Around 1.5 hours of charging time
Case: Wired Around 3 hours
Case: Wireless Depends on the charger
Operating and Storing Environment
Operating Temperature: 5°F - 122°F with 90% Relative Humidity
Storage Temperature: -13°F - 131°F
In the box
- Wyze Buds Pro x1
- Charging Case x1
- USB Type-C Cable x1
- Silicone Ear Tips x3
- Quick Start Guide x1
FAQ
What is the difference between Wyze Buds Pro and Wyze Buds?
Wyze Buds Pro is a pro model with premium features like Active Noise Cancellation (ANC) and wireless charging. Wyze Buds, will meet your everyday needs with longer battery life and a more compact case.
Can I use just the left or the right earbud?
Yes, you can use a single earbud for your music and calls. You will need both earbuds to update your Wyze Buds Pro settings in the Wyze app.
What is the expected battery life?
The earbuds provide up to 4.5 hours of playback time in a single charge with Active Noise Cancellation turned on, and provide up to 6 hours of playback time in a single charge with Active Noise Cancellation off. The charging case provides up to 13.5 hours of music playback time.
Does Wyze Buds Pro work without the Wyze app?
Yes, you only need a Bluetooth connection to use the earbuds. If you want to use more advanced features, like customizing the touch controls and setting up your voice assistant, you'll need the Wyze app.
Can I connect Wyze Buds Pro to two devices at the same time?
No, Wyze Buds Pro can only connect to one device at the same time.
How do I set up my Wyze Buds Pro?
Download the Wyze app, and click the + plus sign > Add Device > Lifestyle > Wyze Buds Pro. Follow along in the app to set up your new earbuds.
Can you customize the EQ of Wyze Buds Pro?
No, Wyze Buds Pro uses Adaptive EQ to automatically adjust the sound.
What kind of noise canceling do they use?
Wyze Buds Pro uses hybrid active noise canceling through 2 feedback microphones and 2 feed-forward microphones, with max 40dB noise reduction depth.
Can you adjust the noise canceling levels?
Yes, you can switch between ANC On, ANC Off, and Transparency Mode in the Wyze app and on the earbuds themselves.
Do they produce mono, stereo, or surround sound?
Wyze Buds Pro produce stereo sound.
What kind of battery do they use?
Lithium ion battery.
Are they compatible with gaming consoles and Bluetooth-capable computers?
Yes, Wyze Buds Pro can connect to Bluetooth-capable devices like gaming consoles and computers.
