Wyze Wi-Fi 6 Mesh Router
Wi-Fi is finally easy.
101 in stock
Features
Features
Industry-Leading Wi-Fi 6—Up to 3 Gbps Wi-Fi speeds, with 1 Gbps internet speeds across 50+ devices per router. Easily stream 4K video, video conferences, and gaming at the same time, all while running dozens of smart devices, too.
Eliminates Dead Spots and Buffering—Each router covers up to 1500 sq. ft. and intelligently adapts to its place in your home, connecting with other Wyze Mesh Routers to create a blanket of seamless Wi-Fi coverage.
More Devices Than Ever—Connect 50+ devices per router, and expand your coverage and number of devices at any time by adding more Wyze Mesh Routers to your network.
Wyze App Control Center—Control your network settings intuitively and easily from anywhere with the Wyze app. Set parental controls, prioritize important devices, check the status of all your routers, and more—all from a single app.
Security by Firedome—Wyze Mesh Router’s security is powered by Firedome, an advanced security software agent that protects every device connected to the router from the world’s most dangerous security threats.
Wired Ethernet Backhaul—Each Wyze Mesh Router supports wired Ethernet backhaul for faster speeds on any router, and has two LAN ports to extend wired connections to any room of your home.
Sets Up in Minutes—Use the Wyze app to plug in, position your routers, and get online quickly.
Specs
Specs
Color: White
Finish: Matte
Wi-Fi Bandwidth: AX3000
Coverage: Up to 1500 sq. ft. each
Devices Supported: 50+ each
Technology: Wi-Fi 6 (802.11ax); Wi-Fi 5 (802.11ac); Wi-Fi 4 (802.11n); 802.11a; 802.11g; 802.11b; 802.15.4
CPU: ARM Cortex A53 Dual-Core 1 GHz
Flash: 128 MB SPI NAND Flash
RAM: DDR3L 512 MB
Radio Configuration (per mesh node): 2.4 GHz (ax 2x2) + 5 GHz (ax 2x2)
Antennas (per mesh node): 4
Frequency: 2.4 GHz, 5 GHz
Channel Width: 20 MHz, 40 MHz, 80 MHz, 160 MHz
Wi-Fi Data Rate: 802.11ax (2.4 GHz): 288 Mbps x 2 = 576 Mbps 802.11ax (5 GHz): 1200 Mbps x 2 = 2400 Mbps
Hardware Accelerator: Dedicated Wi-Fi Accelerator; Dedicated Routing Performance Accelerator
Ports: 1 x 1 Gbps WAN; 1 x 1 Gbps LAN; 1 x DC; 1 x Reset Button
Provisioning Technology: Bluetooth® Low Energy 5.1
Wireless Security: WPA3-PSK (Personal Mode); WPA2-PSK (AES); WPA-PSK (AES)
Power: DC 12V 1A
Temperature Rating: 32°F ~ 104°F (0°C ~ 40°C)
Humidity: Up to 90% RH, Non-condensing
Certifications: FCC, IC
Operation Modes: Router Mode; Bridge Mode (Auto ISP Router Passthrough); Auto WAN/LAN Port Sensing
In the box
In the box
1-Pack
Wyze Mesh Router x1
3' Category 6 Ethernet Cable x1
Power Adapter x1
Quick Start Guide x1
2-Pack
Wyze Mesh Router x2
Power Adapter x2
FAQ
FAQ
What are the key differences between Wyze Mesh Router and Pro?
Coverage area, bandwidth, internet speed supported, and number of devices supported are the main differences between the two. Check out the table above for more details.
What are the basic requirements for Wyze Mesh Router?
You’ll need:
1) Active Internet service from your local ISP.
2) An existing modem.
3) A smartphone with active mobile data service for setup.
Where’s the best place to put my mesh router?
The best place to put the router is in a central location, away from large appliances, and with good “line of sight” visibility to the main areas of your home.
How many Wyze Mesh Routers can I have on my mesh network?
In theory, you can add as many Mesh Routers to your network as you'd like. But we recommend no more than 10 mesh routers on the same network.
How many mesh routers do I need?
It depends on how much area you need to cover! But here’s a tip: One Wyze Mesh Router System (2-Pack) can cover up to 3,000 square feet while a Wyze Mesh Router Pro System (2-Pack) can cover up to 4,000 square feet.
Can I add different Wyze Mesh Router models to my network?
No, you cannot mix and match different mesh routers on the same network. For optimal coverage, capacity, and performance, choose only one type to install.
Can I use Wyze Mesh Router with my existing router?
Yes, though we recommend you replace your old router with a new Wyze Mesh Router. In some cases, your ISP may provide an all-in-one router and modem combo that cannot be replaced.
Do I need to upgrade my wireless client to use Wi-Fi 6?
No, because Wi-Fi 6 is backwards compatible to older Wi-Fi standards. This means your older devices will still work.
Does Wyze Mesh Router and the Pro version support wired-backhaul?
Yes, thanks to Wyze Intelligent Mesh, the mesh router automatically optimizes the backhaul path regardless of if it's a wired or Wi-Fi connection.
Is Wi-Fi 6 backwards compatible with older Wi-Fi standards?
Yes, Wi-Fi 6 (IEEE802.11ax) works with legacy standards as follows:
• IEEE802.11b — Wi-Fi 1 (2.4 GHz)
• IEEE802.11a — Wi-Fi 2 (5 GHz)
• IEEE802.11g — Wi-Fi 3 (2.4 GHz)
• IEEE802.11n — Wi-Fi 4 (2.4 GHz & 5 GHz)
• IEEE802.11ac — Wi-Fi 5 (5 GHz)
Wi-Fi 6/ Dual-Band
Gigabit Internet Speeds
50+ Connected Devices per Router
1500 Sqft of Coverage per Router
Everywhere coverage. Everywhere speed.
Wi-Fi setup has never been so easy.
Is your router built to manage today's smart home?
Yesterday's routers can only handle so many devices at once. The rest wait their turn. Wyze Wi-Fi 6 Mesh Router is built for today's smart home and can support multiple devices, all at once.
Fast doesn't mean what you think it means.
Internet speed is more than just "How fast?" In today's smart homes, "How many?" is just as important. Each Wyze Mesh Router can keep 50+ devices at top speed, all at once, with no waiting in line.
Listen to these experts explain the benefits of Wi-Fi 6.
Prioritizes important devices.
"If one person in your home is streaming a movie and another is checking social media on a phone, Wi-Fi 6 allows a router to assign channels to each device based on when it needs it most."
Improved battery life.
"Wi-Fi 6 allows devices to plan out communications with a router, that means less drain on batteries and improved battery life in turn."
Wired or Wireless Expansion.
Each Wyze Mesh Router includes two Ethernet ports and supports wired backhaul.
The additional ports can expand wired connections to any room of your home, for even faster internet speeds.
The best components for the best router.
Optimized antenna. Stronger power amplifier. A bigger processor with more memory. And mountains of testing and data to confirm its speed, range, and stability.
Plus no trade-offs between great features and a sleek look.
Wyze Wi-Fi 6 Mesh Router is better because it's built better. A first class product, made of first class parts, with a first class look.
Complete network control in the Wyze app
Network at a Glance
Test your internet speed any time, right in the Wyze app. And quickly assess the health of your network, including the status of each router and the status/identity of each connected device.
Device Management
Know exactly which devices are connected to your network and how they're connected. Group them, name them, and manage their access.
Security
Manage Wi-Fi and Guest Network access and receive free cyber-threat-prevention services provided by Firedome, including daily reports of the number of threats, blocked threats, threat origins, and threat types.
Take back your internet.
You're not beholden to that crappy internet company router, and you're likely paying five to ten times what it's worth.
