1 of 3
Mount Wyze Sprinkler Controller anywhere, worry-free.
$59.99
  • Mount Wyze Sprinkler Controller anywhere, worry-free
  • IP65 fully weatherproof rating for outdoor use
  • 4 clasps and gridded cover for extra durability
  • Hardwire or outdoor outlet power
  • Compatible only with Wyze Sprinkler Controller
Features
Wyze Sprinkler Controller can be safely installed outdoors using a Wyze Weatherproof Sprinkler Controller Box. This secure outdoor enclosure protects your controller from the elements and from water damage.
- Mount Wyze Sprinkler Controller anywhere, worry-free
- IP65 fully weatherproof rating for outdoor use
- 4 clasps and gridded cover for extra durability
- Hardwire or outdoor outlet power
- Compatible only with Wyze Sprinkler Controller
Specs
- Color: Light Gray
- Finish: Matte
- Dimensions (H x W x D): 11.6 in x 9.5 in x 3.4 in
- Mounting Method: Screw-in, connect to Wyze Sprinkler Controller
- Weather Resistance: IP65 Weatherproof
In the box
FAQ
