Wyze Watch 47c
Wyze Watch 47c
Features
Features
1.75-Inch Touch Screen
Size matters when it comes to a smart watch screen. Read email previews, texts, and other notifications with plenty of space.
New Friendly Watch Faces
That massive 1.75-inch screen comes with a beauteous batch of fantastic new faces.
Blood Oxygen
A drop in blood oxygen saturation can be a sign of serious health risks. A crystal glass casing and a pair of infrared LED clusters can measure it whenever you’d like, right on your wrist.
All Aluminum Alloy Frame
A Shortcut to Wyze Shortcuts
Raise your wrist and tap to control your Wyze ecosystem.
Personalize Your Pixels
Match your watch face to your style using unique combinations of background images, clock styles, and colors.
Water Resistant up to 2 Meters
IP68-rated weatherproof. Fit to withstand dust, dirt, and sand, as well submersion up to a maximum depth of 2 meters underwater for up to 30 minutes.
Heart Rate Tracking
Keep an eye on your heart rate from the comfort of your wrist while browsing your trends in the app.
Sleep Monitoring
Rest easy and check your sleep duration, depth, and position once you wake up.
Steps Counting
Keep up the pace and check out your progress using your watch and the in-app tracker.
9 days of Battery Life
With battery capacity up to 300mAh, you’ll get through your week with plenty of charge to spare. Need more juice? Recharge fully from 0% in about 2.5 hours.
Specs
Specs
Wyze Watch 47mm C Device Details
Color
Classic Black.
Materials
Screen: 2.5D glass
Body: Aluminum alloy
Bottom body: ABS + Pet
Strap:
- Silicone (Classic Black)
Dimensions
Watch body: 46.8 mm (L) x 38.9 mm (W) x 11.9 mm (D)
Strap:
- Silicone: 160-240 mm x 22 mm
- Nylon: 145-230 mm x 22 mm
Weight
46.6 g
Display
Size: 1.75 TFT LCD
Screen Resolution: 320 x 385 pixels
Color: 16-bit color
Touchscreen: Yes
Battery
Battery capacity: 300 mAh
Charging time: 2.5 hours
Battery life: 9 days
Standby: 60 days
Charger: Magnetic charging, 0.7 m cable
Performance
MCU: 96 MHz
RAM: 512 KB
External Flash: 16 MB
Sensors
PPG Heart Rate Sensor: Yes
Blood Oxygen Sensor: Yes
Acceleration Sensor: Yes
Vibration Motor: Yes
Connectivity
Bluetooth 5.0
Weather Resistance
IP68 Waterproof
Warranty
1-Year
In the box
In the box
- Wyze Watch 47 C x1
- Magnetic USB Charging Cable (0.7m) x1
- Strap x1 (Classic Black)
- Quick Start Guide x1
FAQ
FAQ
Is the firmware different in Wyze Watch 47mm C?
No, the firmware is the same as the original Wyze Watch 47mm. There are no new functions.
Can I purchase the new straps separately?
No, individual straps for this version are not available. Because of limited quantities, the straps are sold exclusively with Wyze Watch 47mm C.
What color combinations does the watch come in?
- Classic Black: Black frame with a black silicone strap.
Can I use the new watch faces on my current Wyze Watch 47mm?
No, the new watch faces are exclusive to Wyze Watch 47mm C.
Does it support wireless charging?
No, it uses an included magnetic charger and does not work with wireless chargers.
Can I make or take phone calls with this watch?
You can accept and deny incoming calls using your Wyze Watch, which works great if you’re wearing Wyze Headphones or Wyze Buds. However, Wyze Watch does not have a built-in microphone or speaker.
Does it support NFC payments?
No, it does not support contactless payments or NFC.
Does it support cellular data or GPS?
No, it does not support cellular data or GPS. It works via Bluetooth-only.
What are the different straps made of?
Silicone for Classic Black.
What does the C stand for?
It stands for both Color and Classic. Maybe we should call it C².
