1 of 5
Wyze Watch 44mm
Wyze Watch 44mm
The go-anywhere smart watch.
Low stock
$44.99
⚠️ Final sale. Item not eligible for exchange or return.
Stay connected to what matters. Check your phone's notifications and your blood oxygen saturation with Wyze Watch 44mm's compact 1.44” screen. It's all wrapped up in an aluminum frame so light that you might forget you have it on.
Features
1.4 Inch Touch Screen
Blood Oxygen
All Aluminum Alloy Frame
A Shortcut to Wyze Shortcuts
Mix and Match Designs
Personalize Your Pixels
Water Resistant up to 2 Meters
Heart Rate Tracking
Sleep Monitoring
9 days of Battery Life
Specs
Color
Black
Materials
Screen: 2.5D glass
Body: Aluminum alloy
Bottom body: ABS + Pet
Strap: Silicone (Black)
Dimensions
Watch body: 44 mm (L) x 36 mm (W) x 11.7 mm (D)
Strap: Silicone: 160-240 mm x 22 mm
Weight
42 g
Display
Size: 1.75 TFT LCD
Screen Resolution: 320 x 385 pixels
Color: 16-bit color
Touchscreen: Yes
Battery
Battery capacity: 300 mAh
Charging time: 2.5 hours
Battery life: 9 days
Standby: 60 days
Charger: Magnetic charging, 0.7 m cable
Performance
MCU: 96 MHz
RAM: 512 KB
External Flash: 16 MB
Sensors
PPG Heart Rate Sensor: Yes
Blood Oxygen Sensor: Yes
Acceleration Sensor: Yes
Vibration Motor: Yes
Connectivity
Bluetooth 5.0
Weather Resistance
IP68 Waterproof
Warranty
1-Year
In the box
Wyze Watch 44mm x1
USB Charging Cable (0.7m) x1
Black Silicone Strap x1
Quick Start Guide x1
FAQ
How long does the battery last under normal use?
Wyze Watch can run up to 9 active days on a charge!
Is the Wyze Watch compatible with wireless charging?
No, Wyze Watch uses a magnetic charger.
What type of straps are used on Wyze Watch?
Both sizes of Wyze Watch use 22mm quick release watch straps.
What is the included strap made of?
The included strap is made of silicone.
What personal or biometric information is collected by the Wyze Watch?
Heart rate, step count, blood oxygen, sleep tracking info, calories burned, blood oxygen level, and accelerometer info. There is also voluntarily provided information such as weight, height, etc. that we will ask for during setup for accurate fitness information.
How long will it take to fully charge my watch battery from 0%?
It takes about 2.5 hours for a full charge.
How do I reset my watch?
Press and hold the button on the side, then tap reset on the screen.
How does my watch track my heart rate?
Your Wyze Watch will automatically measure your heart rate periodically, but you can also initiate a manual heart rate reading from your watch.
How does the blood oximeter measurement work?
The back of the watch has an LED cluster which emits two wavelengths of light. Combining the information that they each collect, the watch screen shows your blood oxygen saturation level.
How can I control my Wyze devices using Wyze Watch?
Wyze Watch supports running Shortcuts that you have set up in your Wyze app. Please see the section “What are Shortcuts?” on our Support site for more information.
  • Compact Size (1.44 Inches)
  • Blood Oximeter
  • Lightweight Aluminum Alloy Frame
  • 9-day Battery Life
A window to better wellness.
In just a few taps, you can check for drops in your blood oxygen saturation - one of the early signs of serious health risks. Also track steps, heart rate, and other fitness information right from your wrist.
Wyze Watch 44mm displays your phone's notifications to save you from digging in your pocket or purse to check a message.
Travel without another charger in your bag.
With up to 9 days of battery life, you have one less thing to worry about when you’re heading out on your latest adventure.
See even more than before.
With a high-density square display, you’ll be able to read and see more than you ever could with a fitness band.
1.44-Inch Screen Size
Show off your personal style.
Be bold and make a statement or help your watch blend in. The choice is yours with over 35 customizable watch faces and six 22mm quick-release straps to choose from.
35+ Customizable Watch Faces 6 Quick-Release Straps
By your side no matter the conditions.
Dust, rain, or sweat? No problem. IP68 weather and water resistance means there’s no need to worry about the elements - whether you’re out and about or just doing the dishes.
A shortcut to your Wyze Shortcuts.
Control your Wyze devices using the Shortcuts you know and love from the top of your Wyze app. Lights, cams, robot vacuums, and more are at your fingertips.
